    3DS emulator for Pi users based on "Borked 3DS"
    nintendo 3dspi 4pi5borked 3dsx86-64
    119 Posts 9 Posters 26.0k Views
    • roslofR
      roslof @gvx64
      @gvx64 said in 3DS emulator for Pi users based on "Borked 3DS":
      It's good keep in mind that Vulkan works at least somewhat. Most games have weird rendering artifacts under Vulkan but there may be some games (that I haven't come across yet) that work better under Vulkan than GLES currently.
      All very good info. I also noticed that when Full Screen mode is much slower than when the UI is displayed. The opposite is true for Dolphin. Was going to report that some games were slower under OpenGL, but it was just the Full Screen mode. :)
      Starting to get used to the nuance now.
      Having a ball with this one.
      • ExarKunIvE
        ExarKunIv @DTEAM
        @DTEAM open a PR on my repo. I'm not by a computer to do big changes. It will be next week before I'm in front of a computer again
        • FollyF
          Folly
          @gvx64 @roslof
          I added both your changes to the script.
          I will probably will change the script so -DDYNARMIC_USE_BUNDLED_EXTERNALS=OFF
          will only be added when compiling for rpi.
          Will have a look later.
          roslofR 1 Reply Last reply Reply Quote 1
          • DTEAMD
            DTEAM @gvx64
            @roslof With Vulkan, the only playable one tested for now is MarioKArt. Vulkan works well on a computer with that emulator. The Vulkan version under MESA is to low on a Pi for now.
            Another thing, I don't remember wich one , but one of the audio settings affect the performance (big impact).
            • roslofR
              roslof @Folly
              @Folly said in 3DS emulator for Pi users based on "Borked 3DS":
              @gvx64 @roslof
              @gvx64 does adding the prefix env MESA_EXTENSION_OVERRIDE="GL_OES_texture_buffer" to es_systems.cfg still provide benefit?
              I noticed that it's still in the fork README.md, but does not appear in the latest RetroPie script. Specifically:
              <command>env MESA_EXTENSION_OVERRIDE="GL_OES_texture_buffer" /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ 3ds %ROM%</command>
              Cheers!
                gvx64 @roslof
                @roslof Yes, THANK YOU for reminding me, I totally forgot about this important point. GL_OES_texture_buffer is a GLES 3.2 extension that the Pi partially supports - well enough for Borked3DS-rpi to take advantage of it. @Folly , can we please replace the addEmulator line with the following on your install script:
                    addEmulator 1 "$md_id-roms" "3ds" "env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer $launch_prefix$md_inst/borked3ds %ROM%"
                This should hopefully get environment variable specified in /etc/emulationstation/es_systems.cfg at time of install and so it should get set whenever users launch Borked3DS-rpi from within emulationstation (please let me know if it does not work). Note that the easiest way to check to see if the environment variable is functioning as expected is to check the log after running Borked3DS-rpi and look for the following message:
                GL_OES_texture_buffer is available, utilizing primary code path
                present in the log means that it the env variable assignment is working properly while,
                GL_EXT_texture_buffer not available, falling back to 2D texture LUTs
                means that it is not working and that there is something wrong.
                As you can see there is also a fallback path that myself and rtiangha introduced that functions in the event that GL_OES_texture_buffer env var is not specified that seems to work fine but it provides less GPU acceleration. Theoretically, enabling texture buffers should make Borked3ds faster. Practically speaking, I didn't see much a difference enabling texture buffers on the Pi4 but it might make more of a difference on a Pi5 with its faster gpu. In any case, I would just specify the environment variable in the install script, make sure that it is in /etc/emulationstation/es_systems.cfg and then leave it at that - texture buffers are the default functionality for the emulator and it stands to reason that it is possibly more stable than the fallback path which has had less testing.
                • FollyF
                  Folly
                  Committed improvements can be viewed here.
                  Script needs to be checked and tested again.
                  • roslofR
                    roslof @Folly
                    Thank you again Folly!
                    For me, when the emulator.cfg line is prepended env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer runcommand seems to have a hard time. Guessing something to do with number of parameters since we're adding one?
                    Viewing /dev/shm/runcommand.log yields the following error before kicking back to ES:
                    Parameters:
                    Executing: env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds "/home/pi/RetroPie/roms/3ds/Angry Birds Star Wars (USA) (En,Fr,Es,Pt).3ds"
                    env: ‘XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds’: No such file or directory
                    So I removed the environment variable from emulators.cfg and added it to es_systems.cfg in this location (which I believe was @gvx64's or @DTEAM's original idea:
                    <command>env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer /opt/retropie/supplementary/runcommand/runcommand.sh 0 _SYS_ 3ds %ROM%</command>
                    This yielded the correct log information in ~/.local/share/borked3ds-emu/log is specified by @gvx64: GL_OES_texture_buffer is available, utilizing primary code path
                      gvx64 @roslof
                      @roslof OK, that wasn't supposed to happen. Thanks for letting me know. I will need to do some additional investigation to figure out how to get the install script to add the env var to /etc/emulationstation/es_systems.cfg. I haven't seen it done in any other examples scripts and so I will have to do some digging.
                      • FollyF
                        Folly
                        @gvx64 @roslof
                        I think the runcommand didn't work because it was missing a semicolon.
                        The env part is a command not an option, by adding the semicolon, I think, it should work now.
                        The change can be viewed here.
                        @roslof
                        If you want you can test only the configure part by doing the following commands.
                        cd RetroPie-Setup
                        sudo ./retropie_packages.sh borked3ds configure
                        That should only install the new runcommands.
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          Found that it should be possible to add a configuration gui to the script.
                          I tested the "function gui_retroarch" from retroarch.sh and renamed it and placed it in the script.
                          It will then add an option for borked3ds in the configuration / tools menu.
                          This means that if we I create a function called "function gui_borked3ds" we can work from there,
                          and it should be possible to create something similar as the mamedev.sh script.
                          • DTEAMD
                            DTEAM @Folly
                            This is a good news.
                            In the PS2 script from Retropie Extra, they have write config settings at the end of the script.This is another example to preset the GUI.
                            FollyF 2 Replies Last reply Reply Quote 1
                            • FollyF
                              Folly @DTEAM
                              @DTEAM said in 3DS emulator for Pi users based on "Borked 3DS":
                              Depending of what we want to add that's indeed a way of adding config settings quite easily.
                              However if we want to add other or more stuff a gui could come in handy.
                              Examples could be :
                              • predefined gamelists
                              • cheats
                              • joystick configs
                              just naming a few ideas.
                              • roslofR
                                roslof @Folly
                                Cheers, Folly. I'm having the same basic issue with the modification. For what it's worth, here are the contents of emulators.cfg post-change:
                                borked3ds-ui = "env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer;XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds"
                                borked3ds-roms = "env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer;XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds %ROM%"
                                default = "borked3ds-roms"
                                This is what runcommand is executing:
                                Executing: env MESA_EXTENSION_OVERRIDE=GL_OES_texture_buffer;XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds "/home/pi/RetroPie/roms/3ds/Angry Birds Star Wars.3ds"
                                and here is the bottom of runcommand.log:
                                _=/usr/bin/env
                                /opt/retropie/supplementary/runcommand/runcommand.sh: line 1329: XINIT-WMC:/opt/retropie/emulators/borked3ds/borked3ds: No such file or directory
                                For now, on my local device, will revert to having the env command in es_systems.cfg and remove it from emulators.cfg (which works fine).
                                • FollyF
                                  Folly
                                  @roslof
                                  @DTEAM @ExarKunIv @gvx64
                                  Do you have the same issue ?
                                  Edit :
                                  Turned off the launch_extension until there is a better solution.
                                  • FollyF
                                    Folly @DTEAM
                                    @DTEAM
                                    I added the basic structure for adding a Configuration/Options menu (also viewable from the main Configuration/Tools menu).
                                    You can view the commit here .
                                    Try to play with it and see how it works.
                                    The "build_menu" code is basically code from the docsview script.
                                    I also use that for the mamedev script, with the addition for showing and running stuff that is placed inside a CSV.
                                    Here I used the special char □ as comma so commas can be used in the CSV.
                                    If you somehow need to add " in the commands then use a backslash in front of it.
                                    Let me know if you can work with that.
                                    • DTEAMD
                                      DTEAM @Folly
                                      @Folly
                                      It works, we can see options 1 to 4 . Maybe we could start (option 1 = pi5/pi4 settings and option 2 cheat codes) I didn't test a cheat code yet with that emulator. Here's a forum about it . I don't see sites with all the cheat codes ready to go. For Joystick, is there a way to match ES settings like Lr emulators?
                                      • FollyF
                                        Folly @DTEAM
                                        @roslof
                                        I have no games (many games) issue on my side for Pi5. It's probably un 3d parameter selected in the graphic options menu
                                        If you go in
                                        /home/pi/.config/borked3ds-emu
                                        here's my settings
                                        qt-config.ini
                                        sdl2-config.ini
                                        Game language is set to french. Youwill have to change it
                                        You are talking about changing these ini files depending on rpi4 and rpi5 right ?
                                        We might be able to do that without adding full ini-files.
                                        If possible a good idea would be to change just the settings needed for that specific platform.
                                        Something like this (copied from mame.sh) :
                                               iniConfig " " "" "$temp_ini_mame"
                                               iniSet "rompath"            "$romdir/$system;$romdir/arcade;$biosdir/$system"
                                               iniSet "hashpath"           "$md_inst/hash"
                                        Edit :
                                        Using the the cheat messages, from your link, to show up in the menu are likely not possible as the messages seem to be encrypted and only viewable in a browser.
                                        Don't know, we should do one by one thing, otherwise it's too much ;-)
                                        Btw.
                                        About the config files.
                                        If needed, we can use curl to get the raw files from pastebin.
                                        • FollyF
                                          Folly @DTEAM
                                          @DTEAM
                                          Just made some working code to edit the qt-config.ini file.
                                          "□Enable Gles□□iniConfig \"=\" \"\" \"/home/$user/.config/borked3ds-emu/qt-config.ini\";iniSet \"use_gles\" \"true\"□□□□□printMsgs dialog \"NO HELP\"□"
                                          "□Disable Gles□□iniConfig \"=\" \"\" \"/home/$user/.config/borked3ds-emu/qt-config.ini\";iniSet \"use_gles\" \"false\"□□□□□printMsgs dialog \"NO HELP\"□"
                                          The functions are explained in the inifuns.sh script.
                                          Another example would be :
                                          "□Overwrite qt-config.ini from pastebin□□curl https://pastebin.com/raw/KXEmXpjQ > \"/home/$user/.config/borked3ds-emu/qt-config.ini\"□□□□□printMsgs dialog \"NO HELP\"□"
                                          Seems the user right are still "pi", but it might be that we need to add chown to the command in order to keep the correct rights.
                                          • FollyF
                                            Folly
                                            Added a useful config option.
                                            R 1 Reply Last reply Reply Quote 2
