    3DS emulator for Pi users based on "Borked 3DS"
    nintendo 3dspi 4pi5borked 3dsx86-64
    108 Posts 7 Posters 14.5k Views
    • DTEAMD
      DTEAM @Folly
      @Folly @gvx64
      This doesn't work well. A simpler solution could be to have an option to set the font and UI size. Previously, my UI was smaller. I played with some font settings, but the UI doesn't handle this well.
      The problem is that I can't access the bottom of the menu where you can set the graphics options, so I can't click OK to apply my settings. It used to work fine, but I needed a magnifier to see the menu on my small screen.
      Perhaps the emulator retrieves the Pi internal settings during software installation. Perhaps if I change the font settings of the Raspi UI and reinstall the emulator, everything will be fine.
      FollyF G 2 Replies Last reply Reply Quote 0
      • FollyF
        Folly @DTEAM
        @DTEAM said in 3DS emulator for Pi users based on "Borked 3DS":
        @Folly @gvx64
        Can I conclude that adding the option to the script worked and that it's compiled with the option -DCONFIG_SCROLLABLE=ON , but you still have some troubles ?
        I can't help you with the added option in Borked, you should ask @gvx64.
        • DTEAMD
          DTEAM @Folly
          @Folly said in 3DS emulator for Pi users based on "Borked 3DS":
          yes
            gvx64 @DTEAM
            @DTEAM Are the scroll bars showing up in your configuration windows? If not, is it possible that the cmake flags didn't work?
            It would help to see a photo of exactly what the problem is, as I am having difficulty understanding it. On my Pi, the configuration menu is a fairly small window that doesn't come close to filling the whole screen. Also, I can click and drag the menu border to change its size. In the default layout, the text spacing adjusts to fill whatever available space there is inside the window.
            • DTEAMD
              DTEAM @gvx64
              @gvx64
              At the bottom of the second picture, the box of the Advanced tab stop just after 0.000 ms and it's not possible to go below that.
                gvx64 @DTEAM
                @DTEAM After investigating further, the problem is on my end. I am going to re-work it and try posting a new commit. Is the problem limited to the Graphics -> Advanced tab or are there others? I believe that the System tab already has scrolling bars enabled.
                • DTEAMD
                  DTEAM @gvx64
                  @gvx64 said in 3DS emulator for Pi users based on "Borked 3DS":
                  It's others. For some, you have the scroll bar, but even if you scroll down, you don't have access to all the options. I'll try to give you a more detailed overview tomorrow.
                  • DTEAMD
                    DTEAM @DTEAM
                    @gvx64
