    3DS emulator for Pi users based on "Borked 3DS"
    nintendo 3dspi 4pi5borked 3dsx86-64
    119 Posts 9 Posters 26.0k Views
      Retrodade @Folly
      @Folly Question, I just tried instaling Borked 3DS on my pi5 and I got could not successfully (home/pi/Retropie-setup/setup/temp/build/borked3ds/build/bin not found) How I solve this? thanks
      • FollyF
        Folly @Retrodade
        @Retrodade
        What kind of distro version are you running and is it 32 bit or 64 bit ?
        Can you add your log to pastebin ?
          Retrodade @Folly
          @Folly pi5 64bit, where is the log? i went to look at dev/shm i dont see any error logs, must be another location? thanks
          • FollyF
            Folly @Retrodade
            @Retrodade said in 3DS emulator for Pi users based on "Borked 3DS":
            In /dev/shm you can only find the runcommand.log and not the RetroPie-Setup logs.
            RetroPie-Setup gzipped logs are here :
            /home/pi/RetroPie-Setup/logs
            Find the one from when you tried to install Borked.
            It should be the latest, if you didn't do anything else..
            These logs can be read with the command zcat, like suggested by @gvx64 in post 6.
            Pipe to the command more to pause the output like this :
            zcat '/home/pi/RetroPie-Setup/logs/rps_2025-xx-xx-xxxxx.log.gz'|more
            (use "enter" and "q" to see next line or to quit)
            To get the .log file you can either unzip the file like this :
            gzip -d '/home/pi/RetroPie-Setup/logs/rps_2025-xx-xx-xxxxx.log.gz'
            Or redirect the output of zcat to a new file :
            zcat '/home/pi/RetroPie-Setup/logs/rps_2025-xx-xx-xxxxx.log.gz' > mylog.log
            • FollyF Folly referenced this topic on
              Retrodade
              Installing dependencies for 'borked3ds' : 3DS Emulator borked3ds
              /home/pi/RetroPie-Setup/tmp/build/borked3ds /home/pi
              Getting sources for 'borked3ds' : 3DS Emulator borked3ds
              Already on 'master'
              Your branch is up to date with 'origin/master'.
              Already up to date.
              HEAD is now in branch 'master' at commit '1d680a076d3e2fdd652f17f65430ffe50bdee49d'
              /home/pi
              Building 'borked3ds' : 3DS Emulator borked3ds
              /home/pi/RetroPie-Setup/ext/RetroPie-Extra/scriptmodules/emulators/borked3ds.sh: line 57: cd: /home/pi/RetroPie-Setup/tmp/build/borked3ds/borked3ds: No such file or directory
              mkdir: cannot create directory ‘build’: File exists
              CMake Error at CMakeLists.txt:2 (cmake_minimum_required):
              CMake 3.26 or higher is required. You are running version 3.25.1
              -- Configuring incomplete, errors occurred!
              Error: could not find CMAKE_PROJECT_NAME in Cache
              Could not successfully build borked3ds - 3DS Emulator borked3ds (/home/pi/RetroPie-Setup/tmp/build/borked3ds/build/bin not found).
              /home/pi
              Log ended at: Tue Jun 24 03:09:27 PM BST 2025
              Total running time: 0 hours, 0 mins, 4 secs
              i tried a second time, it wouldn't let me this is the log thanks
              DTEAMD FollyF 2 Replies Last reply Reply Quote 0
              • DTEAMD
                DTEAM @Retrodade
                You must update your CMAKE version
                • FollyF
                  Folly @Retrodade
                  @Retrodade
                  Seems you used @DTEAM modulescript.
                  @DTEAM is correct, then you need to use a newer cmake version.
                  If you use my modulescript then a newer cmake is downloaded and used to build Borked.
                  Try to clean the source folder fists so you know that the latest source is cloned.
                  Tip read post 1.
                  • FollyF
                    Folly
                    @Retrodade
                    Any luck ?
                    • FollyF
                      Folly
                      This is a trial to reduce and improve the code to make regular use of doublequoting inside the array with csv data.
                      Edit:
                      Another commit added.
                      • DTEAMD
                        DTEAM @gvx64
                        Hi @Folly, can you do this with your latest version, please? I'd rather you add your own script to it as a pull request because it's your work.
                        @ExarKunIv said in 3DS emulator for Pi users based on "Borked 3DS":
                        @DTEAM adding this script ( Changed it over to Follys version ) to my Repo. for ease of installing
                        if you want to do pull requests when things change you can. if not i will update it as i see them here.
                        • FollyF
                          Folly @DTEAM
                          @DTEAM
                          @ExarKunIv already updated so nothing to be done for now ;-).
                          • FollyF
                            Folly
                            Just a warning about installing Borked.
                            Noticed yesterday that mame would not compile.
                            Seems that installing the dependancies for Borked will most likely break some of the QT5 install that is needed for compiling mame.
                            Once I installed a fresh OS, mame would compile correctly.
                            I don't have evidence but it's likely the cause.
                            Not sure if removing the installed dependancies will cure it, so be careful, you have been warned !
                            roslofR 1 Reply Last reply Reply Quote 1
                            • roslofR
                              roslof @Folly
                              @Folly said in 3DS emulator for Pi users based on "Borked 3DS":
                              Thank you for the warning, @Folly
                              Good news is that I did work with the script and upgraded dependencies, but was able to successfully compile lr-mame 0.278. I suspect that you also did a lot more experimentation than some of us, but I also suspect the general state of things for lr-mame is actually good to go.
                              • DTEAMD
                                DTEAM @gvx64
                                @gvx64
                                Hi gvx64, I found a small bug in the user interface. In the configuration menu (configure..), a dialog box with all the options, such as graphics, appears. This box does not have a side scroll bar. So, when I use it on a small screen (e.g. 7.5 inches), I cannot access the lower options. Is it easy to add a scroll bar?
                                DTEAMD G 2 Replies Last reply Reply Quote 0
                                • DTEAMD
                                  DTEAM @DTEAM
                                  This post is deleted!
                                    gvx64 @DTEAM
                                    @DTEAM I can take a look at it when I get the chance. It shouldn't be too hard to add a scrollbar to the config menu (hopefully that statement doesn't come back to haunt me).
                                    I am still working on correcting the black box in Fire Emblem Awakening. This has been a real pain to deal with and I have been working on it for over a month now. Just out of curiosity, have you seen this problem in any other games? It's a fairly sizeable black box in the bottom right corner of the top screen and it really obstructs gameplay. I have found a solution but it is currently non-optimal and involves a heavy performance hit in the game.
                                    • DTEAMD
                                      DTEAM @gvx64
                                      @gvx64 said in 3DS emulator for Pi users based on "Borked 3DS":
                                      No , but I can do more test
                                        gvx64 @DTEAM
                                        @DTEAM OK, I implemented the configuration menu scroll-bar as an experimental feature. You should be able to enable it if you add the following cmake flag to your build script:
                                        -DCONFIG_SCROLLABLE=ON
                                        I have left this flag disabled by default in the CMake file because I am not sure that normal users with conventional screen size will benefit from the scroll bar. This feature does make you scroll to use the config menus whereas in the default implementation the text spacing auto adjusts which I think is preferable for most screens.
                                        Please give it a try and please let me know if this works OK for you. I can make changes as needed.
                                        Also, the Fire Emblem patch is live. The black box is gone but there is a 10-20% performance hit in the battle screens that was necessary to get rid of the black-box as I am forcing fallback to the software renderer for short periods of time. It's not optimal but I believe that the performance hit is vastly preferable to having a massive black box occupying what feels like 1/8th of the screen. There are some remaining rendering issues but they are relatively minor and I feel that the game is at least reasonably playable on GLES in the current state on an overclocked Pi4.
                                        I did notice similar boxes in Smash 3DS and I am guessing that it might be a similar problem as with Fire Emblem. This patch is Fire Emblem specific and will not help with Smash. Smash 3DS is utterly unplayable on my Pi4, due to it being a fighting game with slow-down, and I doubt that it will even be playable at full-speed on a Pi5 and so I probably will not invest time into fixing those boxes. If somebody really wants to play Smash 3DS on the Pi they can do so using Vulkan as there are no boxes and the usual Vulkan rendering issues aren't too noticeable with this game.
                                        I would like to work next on seeing if I can get the hardware acceleration setting to work under GLES as I believe there is a chance (albeit a small chance) that there could be performance improvements with this feature. Once I am finished this task I also want to look into something that will let users map the mouse cursor to a gamepad analog stick. There actually already may be something available that does this: xdotool. Assuming that this tool works, what I recommend doing is seeing if we can launch this tool for a specific emulator core in the emulationstation startup script: /opt/retropie/configs/all/runcommand-onstart.sh as a background process. There will be some overhead and so we should really only launch this utility when touch screen controls are specifically needed (especially for Pi4 users). It should be fairly simple to have the script initiate the background process for this specific core emulator option and then have the process killed for all other options/emulator platforms. If somebody else wants to take this on and investigate xdotool (or similar utility) please feel free to (there probably shouldn't much coding involved apart from the bash script), otherwise this task will remain in my queue.
                                        DTEAMD 2 Replies Last reply Reply Quote 1
                                        • DTEAMD
                                          DTEAM @gvx64
                                          Thanks . I'll test it
                                          NEW EDIT
                                          Hi @Folly . I added it in the script and it doesn't work. Maybe I didn't add it at the good place or properly. Could you help me on that one please. If it works, it could be interesting to add it in you configuration options (options 1 to 4).
                                          • FollyF
                                            Folly @DTEAM
                                            @DTEAM said in 3DS emulator for Pi users based on "Borked 3DS":
                                            NEW EDIT
                                            I think you should add it in line 75 , after OFF and add space.
                                            Let me know if it works.
