    RetroPie recommended x86-x64 system? Also, questions about Rpi5 vs 4
    retropie x86raspberry pi 4braspberry pi 5
    2 Posts 2 Posters 486 Views
      BigGold
      I have a nice install of Retropie on my Rpi5, but i was looking to install it on other hardware.
      I don't really play anything beyond a PS1, so I was wondering if it would be possible to run it on a core2duo system with integrated graphics or possibly a AMD HD 5000 series card for the ability to use a tv via component. would 2gb suffice or should i be looking at a more powerful setup?
      I am also looking to downgrade to a Raspberry pi 4 because there's a nice hat that i would like to use,
      is there any performance difference between the 2?
      Thanks!
      • mituM mitu moved this topic from General Discussion and Gaming
        mitu Global Moderator @BigGold
        @BigGold said in RetroPie recommended x86-x64 system? Also, questions about Rpi5 vs 4:
        A Core2 Duo system is waay too old to be a recommended system. If you're looking to 'downgrade', then a Pi4 would be perfectly fine.
