    crt-pi shader users - reduce scaling artifacts with these configs in lr-mame2003, lr-fbalpha, lr-nestopia (and more to come)
    crt-pi shadercrt-picrt-pi-verticalshaderslr-mame2003
    385 Posts 42 Posters 326.2k Views
      Dochartaigh @dankcushions
      So you all are speaking French to me ;) (no offense to the French!), so how would I go about updating to the new CRT-Pi shader? I'm assuming jut updating from source won't do it...?
      Do I update my CRT-Pi.glslp or .glsl files I've tweaked settings in before with that new code?
        dankcushions Global Moderator @Dochartaigh
        @Dochartaigh said in crt-pi shader users - reduce scaling artifacts in lr-mame2003/lr-fbalpha (horizontal AND vertical games):
        i've not updated the shader at all. this is just configuration files that adjust the screen resolution so the shader is more effective. i'm not sure what version of retropie included the shader and the version of retroarch that supports overrides, but 4.1 and up should be definitely ok.
        • caver01C
          caver01 @dankcushions
          @dankcushions Here's what I mean:
          Say you are scaling a vertical game that runs natively at 224x288 (AR=.77) for a display that is 1920x1080.
          Option 1: Scale to 3x you get 672x864, and you stretch Y, so: 672x1080 (AR=.62)
          This option has some vertical stretch to overcome the 216 pixels shy of 1080.
          Option 2: Scale to 4x you get 896x1152, and you compress Y so: 896x1080 (AR=.82)
          This option has some vertical compression (or horizontal stretch if you want to say it that way) because you have to overcome only 72 pixels of vertical overage.
          Option 2 has less distortion than option 1 (assuming square pixels are desired).
          Now that I have this example, it strikes me that on real arcade CRTs, the game might have been adjusted to fill the screen, so the goal would be to find the x-integer that lands you as close to 4:3 as possible, with Y scaled up or down to match the display resolution.
            dankcushions Global Moderator @caver01
            @caver01 said in crt-pi shader users - reduce scaling artifacts in lr-mame2003/lr-fbalpha (horizontal AND vertical games):
            Option 2 has less distortion than option one (assuming square pixels are desired).
            my script would use option 2 here, because the aspect ratio (.82) is closest to the native one (.77)
            yeah i use the actual aspect ratios of the displays that these games ran on (which has been collated by @UDb23 here) in my calculations. eg, for a CPS2 game I would target the DAR of 4:3, rather than the PAR, which is closer to widescreen. almost all arcade games are really 4:3 or 3:4.
              Pyjamarama
              Thank you @dankcushions for your work!!
              I have an issue thought. The vertical games in MAME2003 (I haven't tested FBAyet)are very very narrow. I am using a quite new Samsung 1080p TV.
              I pasted inside my PetroPie mame roms and executed
              python crt-pi-configs.py mame2003 1920 1080
              and too the folder to /opt/retropie/configs/all/retroarch/config/
              http://www.ultraimg.com/image/VVX3
              I was checking the config
              # Place in /opt/retropie/configs/all/retroarch/config/MAME 2003/
              video_shader_enable = "true"
              video_shader = "/opt/retropie/configs/all/retroarch/shaders/crt-pi-vertical.glslp"
              # To avoid horizontal rainbow artefacts, use integer scaling for the width
              aspect_ratio_index = "22"
              custom_viewport_width = "224"
              custom_viewport_height = "1080"
              custom_viewport_x = "848"
              custom_viewport_y = "0"
              The display does seem to be 224 * 1080...very spaghetti...surely not correct
              Horizontal games got a lot prettier but I miss things on top and bottom
              http://www.ultraimg.com/image/VVX6
              The config is again a bit strange (1200?)
              video_shader = "/opt/retropie/configs/all/retroarch/shaders/crt-pi.glslp"
              custom_viewport_width = "1920"
              custom_viewport_height = "1200"
              custom_viewport_x = "0"
              custom_viewport_y = "-60"
              Any help appreciated
                dankcushions Global Moderator @Pyjamarama
                @Pyjamarama said in crt-pi shader users - reduce scaling artifacts in lr-mame2003/lr-fbalpha (horizontal AND vertical games):
                why did you run the script? i already generated the cfgs for 1080p. i suggest using the ones i generated first, then let me know if there's still a problem.
                  Pyjamarama
                  You r right! Excellent result! Kudos!
                  • RumblinBuffaloR
                    RumblinBuffalo
                    @dankcushions
                    Appreciate your efforts and updates/postings. Lots of educational reading here - trying to keep up.
                    On a fresh RetroPie 4.1 setup, I've read and followed everything above and have placed the .cfg files into the \Mame 2003\ folder and they are working as advertised. I can see the override is enabled and the vertical shader is being used.
                    However, I am not 100% certain with regards to the scaling. Using the pacman, dkong etc. as an example, on my display (1920x1080) the game fills the screen vertically, but appears to stretch maybe 10%-15% wider than the "core provided" ratio (which I believe is 3:4). Is this by design (a result of the script that generates the scale), or have I missed a setting someplace that would allow me to retain the core aspect ratio?
                    I know you've discussed the scaling being slightly inaccurate above but this seems greater than what you've discussed above?
                      All - I noticed a bug in my last set of cfgs and have updated them! There was some incorrect ratios used. Please re-download, sorry!
                        dankcushions Global Moderator @RumblinBuffalo
                        @RumblinBuffalo said in crt-pi shader users - reduce scaling artifacts in lr-mame2003/lr-fbalpha (horizontal AND vertical games):
                        @dankcushions
                        Hmm, this might be related to the bug I just fixed, so please re-download the files. Here is what pacman looks like at the moment:
                        The resolution is 896x1080, which is a 0.83 ratio. Compare that to the actual ratio, which is 3:4 (0.75) and it's pretty close. 10-15% wider (or narrow) is probably about right for most cases.
                        bear in mind that my algorithm tries to get the closest integer scaling on one axis, so it will rarely be at the exact proper aspect ratio, but it will have no horrible scaling artefacts along that axis.
                        EDIT: updated image and calculation due to silly bug!
                        RumblinBuffaloR 1 Reply Last reply Reply Quote 0
                          another bug!! this time with the vertical games. sorry :( updated the files AGAIN! i'll need to update my pacman calculations/image above, also.
                          • caver01C
                            @dankcushions I know it must be tedious to regenerate and re-up the files, but I think your clever insight about how integer scaling on a single dimension is all you need to clean up the artifacts is worth the 'bump' to give this post more visibility!
                              @caver01 thanks :) it's not quite perfect - you'll still get banding with vertically scrolling games/backgrounds. eg, the intro to street fighter II. however, to eliminate those you've no choice but full integer scaling, with top/bottom borders, and you don't need my configs for that :)
                              it'll be nice when 4k is the standard:
                              • 240 (common CRT height) divides exactly into 2160
                              • 224 (another one) x 9 = 2016 leaves only a 7% border
                              compared to 1080p
                              • 240 x 4 = 960, 12% border
                              • 224 * 4 = 896, 17% border
                              • caver01C
                                @dankcushions Ouch. Yeah, those borders are why I never bothered with integer scaling, but I have been meaning to sit down with my system and try some of your configs. As a standalone arcade build, I can't imagine having a spare 4K display to mount inside my expensive "toy", but it will be better for what is probably the majority of folks running RetroPie on their TVs. However, at that resolution, perhaps the artifacts become less noticeable?
                                • RumblinBuffaloR
                                  RumblinBuffalo @dankcushions
                                  @dankcushions
                                  Thanks for the info/screenshot. That matches up with what I am seeing so it appears I've set this up properly (and would explain the 9% wider image). Really appreciate the example!
                                  So if I understand correctly, applying the crt-pi vertical shader to a screen set at the proper aspect ratio (in this case, pacman @ 3:4), the difference would be a reduction in quality of the shader (I should see scaling artifacts)?
                                  One more oddity - i've also tested/ setup a couple of .37b5 roms using mame-libretro (2000) using the regular crt-pi shader (horizontal). I've noticed the regular crt-pi shader on these appear to look quite good on a vertical game (mspacman). Strangely, if I switch the to the vertical shader, the quality suffers/banding effect returns. This seems to be "opposite" of how it should work. Is there any reason why the standard crt-pi shader would look "correct" using the older MAME core?
                                    garion
                                    all working fine with cfg in MAME 2003 and FB Alpha but I notice some strange aspect ratio in well known games. By example Do donachi and others vertical games.
                                    @dankcushions I use the your zip file in first post.
                                    if 720 width then vertical games looks stretched. 896 seems perfect.
                                    EDIT2: I look into the crt-pi-configs DB and:
                                    ddpdoj, 448, 224,V,R, 810, 1080, 672, 896, 3, 4
                                    ddonpach, 320, 240,V,R, 810, 1080, 720, 960, 3, 4
                                    ddonpachj, 320, 240,V,R, 810, 1080, 720, 960, 3, 4
                                    Maybe I´m in a visual mistake.
                                    DDONPACHJ
                                    custom_viewport_width = "720"
                                    custom_viewport_x = "600"
                                    DDPDOJ
                                    custom_viewport_width = "896"
                                    custom_viewport_x = "512"
                                    EDIT3: I use the script with FBA with 1920x1080 and get that with same game and results are not the same than in the zip-cfg- file:
                                    DDPDOJ
                                    custom_viewport_width = "448"
                                    custom_viewport_x = "736"
                                    EDIT4: with above config DDPDOJ looks spaguettized.
                                      @dankcushions
                                      yes :) you might not necessarily see the scaling artifacts (especially on a game with a static dark background like pacman), but they are there.
                                      the core must tell the api that this is a rotated game. i'm not so sure that mame2000 does this. i only work with mame2003 really.
                                        dankcushions Global Moderator @garion
                                        @garion said in crt-pi shader users - reduce scaling artifacts in lr-mame2003/lr-fbalpha (horizontal AND vertical games):
                                        DDONPACHJ
                                        with this game, the native aspect ratio is 3/4 (0.75)
                                        the ratio my algorithm generates is 720/1080 (0.66)
                                        the next scale up would by 720+240 = 960
                                        the ratio of THAT would be 960/1080 (0.88)
                                        0.66 is closer to 0.75 than 0.88 so that's what it uses. i do agree that i might normally prefer it to be too wide than narrower for vertical games. i've been thinking about maybe always using the next widest scale for vertical games - do others agree?
                                        DDPDOJ
                                        DDPDOJ
                                        i'm not sure why you're getting those results. are you using the latest script? what command are you using to launch it? do you have the latest resolution_db files from my repo?
                                          garion @dankcushions
                                          @dankcushions
                                          thanks for your quick answer.
                                          Use next widest scale is a good solution with 1080p displays. Today we have very big screens so black bars are really big with 0,66 A/R.
                                          I forgot ask about, how to use curvature with the script? (or downloaded cfgs zipped)
                                          about script. I use last one, downloaded today from GitHub HERE. I unzip it then go to that folder and use:
                                          and
                                          python crt-pi-configs.py fbalpha 1920 1080
                                          Run script perfect. Each script create new dir with lot of cfg then a zip file.
                                          I repeat the script with fbalpha right now and same results.
                                          dankcushionsD 1 Reply Last reply Reply Quote 1
                                          • RumblinBuffaloR
                                            Thanks again for all the help! I do want to mention that the shader looks great on the old school classics (pacman, dkong, etc. that I've tried so far.
                                            You're right. I was able to test my setup on a larger TV last night and with pacman, I was able to see very slight banding at 3:4 ratio (in the ghosts). It was pretty flawless using your CFG/ratio. I'll probably get a better idea once I look at some different roms.
                                            Could be - I'll keep playing with it and see. I've only had an RPi for about 6 months but it sure is a fun little hobby (endless tinkering). I'm also amazed at the amount of creative cabinets/projects/ideas of I've seen already.
