    crt-pi shader users - reduce scaling artifacts with these configs in lr-mame2003, lr-fbalpha, lr-nestopia (and more to come)
    crt-pi shadercrt-picrt-pi-verticalshaderslr-mame2003
    385 Posts 42 Posters 303.3k Views
      Pyjamarama
      How do I install this shader to RetroPie? How do I update the existing crt-pi shader?
      Thank you!
        dankcushions Global Moderator @Pyjamarama
        @Pyjamarama said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
        Thank you!
        it is already included in the latest retropie image. if you don't have that, you should update retroarch via binary: https://github.com/retropie/retropie-setup/wiki/Updating-RetroPie#updatinginstalling-individual-packages
          Pyjamarama
          @dankcushions Can you confirm the paths plz? I have no MAME 2003 folder inside /opt/retropie/configs/mame-libretro/
          I put the configs in /opt/retropie/configs/mame-libretro/ but no change...still user crt-pi
          thank you
            @Pyjamarama you create the directory.
              Pyjamarama
              Hmmm...I did but did not make the trick.
              What did it is...I put them in the folder where I have the roms and renamed them from filename.cfg files to filename.zip.cfg (just a batch rename using TotalCommander)
              It worked smooth like Kylie's @@@ :)
              Thank you for your help (and your configs!!)
              • GreenHawk84G
                GreenHawk84
                I could not get this to work, even by creating the MAME 2003 folder in either configs directory. So I just renamed the files I needed with .zip as Floob suggested and all is well. Hopefully this can be implemented automatically at some point.
                  dankcushions Global Moderator @GreenHawk84
                  @GreenHawk84 @Pyjamarama
                  in my first post:
                  please check if it works and confirm, as i'm not sure what version the overrides functionality arrived in retroarch. it should be in retropie 4.x but i'm not sure.
                  without knowing what version of retropie you're using i won't know anything about your problem. if it's the latest, i guess it's only in very new retroarch builds. you could update retroarch from source to test that theory.
                  also, please post the full path of an example game and appropriate override config so i can be sure you have it set up right.
                  using zip.cfg files in the rom directory is the retropie way of doing it. my way uses retroarch functionality, which IMO we should move toward. read this for more details: https://retropie.org.uk/forum/topic/4055/idea-use-retroarch-s-built-in-per-rom-config-functionality-rather-than-runcommand-and-appendconfig/5
                    Mamemeister
                    Guys, I did this and found it didn't look great so tried to disable it but despite turning off all the shaders options in Retropie options AND deleting the Mame2003 folder with the config files the scan lines are still enabled, any ideas how to turn them off would be wicked thanks.
                    Update / discovered if I went into the individual emulator options ie Arcade and FBA and turned off the video shader that works.
                    • RionR
                      Rion
                      @dankcushions
                      Thank you for all your hard work.
                      I edited the mame2003-crt-pi-vertical-overrides and created one with the names changed to .zip.cfg so these can go right in to the roms folder.
                      Here mame2003-crt-pi-vertical-overrides-cfg (Put in roms\mame-libretro)
                      Here is also one with mame2003-crt-pi-curvature-vertical-overrides
                      And last one mame2003-crt-pi-curvature-vertical-overrides-cfg (Put in roms\mame-libretro)
                      FBNeo rom filtering
                      Mame2003 Arcade Bezels
                      Fba Arcade Bezels
                      Fba NeoGeo Bezels
                      RiverstormR 1 Reply Last reply Reply Quote 2
                      • RiverstormR
                        Riverstorm @Rion
                        @Rion said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
                        @dankcushions
                        These are nice additions to Dank's work, thank you!
                        • RionR
                          Rion @dankcushions
                          @dankcushions said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
                          for the curious, i created a little script that went through the lr-mame2003 source-code and pulled out the list of roms that are rotated, and from that it created the relevant .cfg files. we could potentially do the same for other arcade emulators but i'll leave that for someone else.
                          I'm interested in how you did this. I have several plans for creating cfg's for games that are not vertical and add a standard arcade overlay beazel for them.
                          Same for fba neogeo only roms and so on.
                          FBNeo rom filtering
                          Fba Arcade Bezels
                          Fba NeoGeo Bezels
                            dankcushions Global Moderator @Rion
                            with mame(2003) it was easy as the source code has easy to find strings for all the vertical games. eg:
                            https://github.com/libretro/mame2003-libretro/blob/7b55725e744ac9702db092f996e2fca2276146b2/src/drivers/pacman.c#L4356
                            GAME( 1981, maketrax, crush,    pacman,   maketrax, maketrax, ROT270, "[Kural] (Williams license)", "Make Trax (set 1)" )
                            GAME( 1981, maketrxb, crush,    pacman,   maketrax, maketrax, ROT270, "[Kural] (Williams license)", "Make Trax (set 2)" )
                            GAME( 1981, korosuke, crush,    pacman,   korosuke, korosuke, ROT90,  "Kural Electric", "Korosuke Roller" )
                            GAME( 1981, mbrush,   crush,    pacman,   mbrush,   0,        ROT90,  "bootleg", "Magic Brush" )
                            GAME( 1981, paintrlr, crush,    pacman,   paintrlr, 0,        ROT90,  "bootleg", "Paint Roller" )
                            GAME( 1982, ponpoko,  0,        pacman,   ponpoko,  ponpoko,  ROT0,   "Sigma Enterprises Inc.", "Ponpoko" )
                            GAME( 1982, ponpokov, ponpoko,  pacman,   ponpoko,  ponpoko,  ROT0,   "Sigma Enterprises Inc. (Venture Line license)", "Ponpoko (Venture Line)" )
                            anything with ROT90 or ROT270, i know is a rotated CRT screen so is a vertical game. you can get the zip name from the same string. i used some REGEX in a little python script to get the info (i think... i can't find it now). i then wrote this python script to go through that list and build the .cfgs:
                            fileName = "rotatedgames.txt"
                            myFile = open(fileName, "r" )
                            print('opened file', fileName)
                            for gamename in myFile:
                            	# strip line breaks
                                gamename = gamename.rstrip()
                                print('creating .cfg for', gamename)
                                # create cfg file
                                cfgFileName = gamename + '.cfg'
                                newCfgFile = open(cfgFileName, 'w')
                                newCfgFile.write("# Auto-generated crt-pi-vertical.glslp .cfg\n")
                                newCfgFile.write("# Place in /opt/retropie/configs/mame-libretro/MAME 2003/\n")
                                newCfgFile.write("video_shader_enable = \"true\"\n")
                                newCfgFile.write("video_shader = \"/opt/retropie/emulators/retroarch/shader/crt-pi-vertical.glslp\"\n")
                            myFile.close()
                            i had a quick look at FBA and the code didn't lend itself to the same approach i think.
                            dankcushionsD 1 Reply Last reply Reply Quote 1
                            • RionR
                              Rion
                              @dankcushions
                              Thank you for posting you script but for me this is useless because i don't know how to use python.. Yet.
                              But maybe you can help me nonetheless .
                              I have here a complete list of all the neogeo roms present in FBA 0.2.97.39 (New version right around the corner)
                              Can you help me create or guide me to how i can make cfg files with these templates?
                              Content of 2020bb.cfg In /home/pi/RetroPie/roms/mame-libretro/ "for example"
                              video_shader = "/opt/retropie/emulators/retroarch/shader/crt-pi-curvature.glslp"
                              video_shader_enable = "true"
                              input_overlay = /home/pi/RetroPie/roms/mame-libretro/overlays/2020bb.cfg
                              input_overlay_enable = true
                              input_overlay_opacity = 0.800000
                              input_overlay_scale = 1.000000
                              aspect_ratio_index = "0"
                              video_scale_integer = true
                              Content of 2020bb.cfg In /home/pi/RetroPie/roms/mame-libretro/overlays/
                              overlays = 1
                              overlay0_full_screen = true
                              overlay0_descs = 0
                              I was thinking about using this as an overlay Final_Arcade_NeoGeo_Horizontal
                              FBNeo rom filtering
                              Fba Arcade Bezels
                              Fba NeoGeo Bezels
                              FloobF 1 Reply Last reply Reply Quote 0
                              • FloobF
                                Floob @Rion
                                @Rion I may be mis-understanding, but all you have to do to get the config to work (if you dont want to use the original method posted at the top) is to rename 2020bb.cfg to 2020bb.zip.cfg and put it in the rom directory.
                                You could batch rename a whole set if you dont want to do it manually.
                                  dankcushions Global Moderator @dankcushions
                                  @dankcushions
                                  that's basically what my script above does. do you want me to keep re-writing it in different languages until you find one you like? ;)
                                  RionR T 2 Replies Last reply Reply Quote 0
                                  • RionR
                                    Rion @dankcushions
                                    @Floob said in crt-pi shader users - automatic usage of crt-pi-vertical in vertical games in lr-mame2003:
                                    @Floob Yes i know i posted some edited cfg files a few post up for this. I looked at you files on how to do this from you're rp-video-manager.
                                    What i wanted to do was to create cfg files for every NeoGeo games on that list and that is something i don't know how to do using python.
                                    @dankcushions
                                    Sorry i will try to figure it out on my own..
                                    FBNeo rom filtering
                                    Fba Arcade Bezels
                                    Fba NeoGeo Bezels
                                    • RiverstormR
                                      Riverstorm
                                      @Rion You should have all the pieces you need it looks like.
                                      1. Your game list is already done and just needs to be added to a text file.
                                      Create something like rionsgames.txt and paste the list into the file.
                                      2020bb
                                      2020bba
                                      2020bbh
                                      3countba
                                      3countb
                                      1. Dank gave you the Python script with some documentation and informational messages printed to screen while it's running which is really handy. It looks straight forward enough you could modify the lines to match your templates to write both files out at once that you want created for each game.
                                      Any programming experience should apply. In the code example the file rotatedgames.txt is being opened, then the first line (game name) is being read which would be 2020b (as the first entry from your list), it's then stripped of line breaks and used as the config file name of the new template you're creating, the last section is writing the new config information of each line. You can modify or add lines as needed.
                                      If you take a look at the script it's well formatted and broken down into 3 main sections. You just need to change the line fileName = "rionsgames.txt" to your game list file. Your first lines would be something similar to this in the last section of the code taken from your template:
                                      newCfgFile.write("video_shader = \ "/opt/retropie/emulators/retroarch/shader/crt-pi-curvature.glslp\"\n").
                                      The second line:
                                      The third line would be a bit more tricky as you have the game name in the line for the overlay.
                                      newCfgFile.write("input_overlay = \"/home/pi/RetroPie/roms/mame-libretro/overlays/$cfgFileName\"\n")
                                      I don't know much about Python but there's several ways to add variables depending on the version. I am not quite sure though. Maybe old fashioned is using $cfgFileName. If you have most of the script I am sure someone would be able to look it over.
                                      RionR 1 Reply Last reply Reply Quote 1
                                      • RionR
                                        Rion @Riverstorm
                                        @Riverstorm Thank you!
                                        It's alot more clear to me now. Will report back with the results and hopefully upload the cfgs to dropbox for everyone else to enjoy.
                                        FBNeo rom filtering
                                        Fba Arcade Bezels
                                        Fba NeoGeo Bezels
                                        • RiverstormR
                                          Riverstorm
                                          You might need to change the filename variable to cfgFileName = gamename + '.zip.cfg'. Which is adding the .zip to the filename. Then create a new variable like cfgOverlay = gamename + '.cfg' for use in the 3rd line naming the overlay file.
                                          It's a bit confusing but \"true\" translates to "true" the backslash before it is telling to interpret it as literal and not a special meaning to Python. \n is a linefeed (go to the next line). The last double quote is working with the first double quote just enclosing the whole string.
                                          Python line:
                                          Output (the string part): video_shader_enable = "true" (with a line feed \n to go the next line).
                                          Python line:
                                          print('opened file', fileName) (or whatever name is held in the variable fileName)
                                          Output:
                                          opened file rionsgames.txt
                                          Python line:
                                          Output:
                                          creating .cfg for 2020bb
                                          You might to define a new variable and add another section at the bottom for the overlay file creation or copy the file and tweak it if you want to use the same variables for creating the overlay file.
                                          cfgOverlay = gamename + '.cfg' (Overlay file name to be created with a .cfg extension basically 2020bb + .cfg = 2020bb.cfg
                                          newOVFile = open(cfgOverlay, 'w') (Open overlay file for writing)
                                          Add overlay file lines here.
                                          Dank did a nice job and did all the ground work but it's so close to what you want I think a few tweaks and it should work nicely.
                                          • RionR
                                            Rion
                                            Thank you again @Riverstorm for explaning this to me.
                                            I got it working
                                            Here is the code
                                            fileName = "fba_neogeo_029739.txt"
                                            	# strip line breaks
                                                # create cfg file
                                                newCfgFile.write("# Auto-generated crt-pi-curvature .cfg for NeoGeo\n")
                                                newCfgFile.write("# /home/pi/RetroPie/roms/mame-libretro//\n")
                                                newCfgFile.write("video_shader = \"/opt/retropie/emulators/retroarch/shader/crt-pi-curvature.glslp\"\n")
                                                newCfgFile.write("input_overlay = /home/pi/RetroPie/roms/neogeo/overlay/Final_Arcade_NeoGeo_Horizontal.cfg\n")
                                                newCfgFile.write("input_overlay_enable = true\n")
                                                newCfgFile.write("input_overlay_opacity = 0.800000\n")
                                                newCfgFile.write("input_overlay_scale = 1.000000\n")
                                                newCfgFile.write("aspect_ratio_index = \"0\"\n")
                                                newCfgFile.write("video_scale_integer = true\n")
                                            myFile.close()
                                            But i could not get
                                            newCfgFile.write("input_overlay = "/home/pi/RetroPie/roms/mame-libretro/overlays/$cfgFileName"\n")
                                            to work.
                                            Luckily because this was only NeoGeo games i could point them all to one cfg file in the overlay folder.
                                            But i would like to solve it when i start to look at adding a generic arcade-bezels to vertical games in lr-mame2003.
                                            Anyway here are the results for everyone to download.
                                            Just put them into you neogeo roms folder in "/home/pi/RetroPie/roms/neogeo"
                                            neogeo-crt-pi-curvature-Final_Arcade_NeoGeo_Horizontal-bezel-.zip.cfg
                                            Here is how its going to look when finished.
                                            SNK NeoGeo
                                            Thanks to:
                                            John.Merrit over at libretro forums for creating this in the first place.
                                            @dankcushions for the python script!
                                            @Floob for his work with rp-video-manager and making these work for the pi.
                                            @Riverstorm For explaining this to me in an easy way ;)
                                            FBNeo rom filtering
                                            Fba Arcade Bezels
                                            Fba NeoGeo Bezels
