    NO sound in snes
    problemsound
    11 Posts 2 Posters 8.3k Views
    • W
      wolverine
      hey guys, i have a very strange problem.
      i setup retropie everything worked perfectly but this morning i started retropie and there is no more sound in the snes games in n64 there is sound.
      i allready tried all the changes in the config.txt and in the menues/retroarch but no succsess.
      thanks for your help.
        BuZz administrators @wolverine
        @wolverine please provide more info. see link in my signature.
        • W
          wolverine
          i have a raspberry 3B, with retropie 4.0.2, i connected 2 snes controllers with the controlblock and one wireless xbox360 controller via the microsoft receiver as well as a keyboard.
          http://pastebin.com/GebBvn2p
            BuZz administrators
            Please read the link again and provide more information - Which snes emulator ? Are you using audio via HDMI or jack ? Which changes did you make in config.txt ? Please post any configs you have "altered" (please use a pastebin site or format the configs in code blocks on the forum - using three backticks above and below - link in the sticky to styling info)
            • W
              wolverine
              no sound in all snes emulators, sound over hdmi (had no problems with that the last weeks until today, i changed the hdmi cable still not working),
              http://pastebin.com/ExCczrKY (snes retroarch)
              http://pastebin.com/mpDPUsNT (all retroarch)
                BuZz administrators
                From a terminal what do you get if you do
                speaker-test -c2 (ctrl+c to stop - do you get audio ?)
                what is the output of tvservice -s
                Please post your /boot/config.txt
                • W
                  wolverine
                  speakertest: i just hear a quite sough all the time
                  tv service: state 0x12000a (HDMI CEA) (16) RGB lim 19:9) 1920x1080 60hz progressive
                  and i already posted boot.config.txt two posts below :)
                    BuZz administrators
                    I didn't spot it.
                      BuZz administrators
                      Looks like you have audio_volume set to 0 in both retroarch configs.
                      You have saved the config from retroarch which makes it harder to manage imho - you might want to consider backing up these configs, removing them, then reinstalling retroarch and the snes emulator from binary to get a default config. You can use the configuration editor to edit them then (and you end up with smaller simple files with just a few overrides in the per system config)
                      you shouldn't need hdmi_drive=2 in /boot/config.txt as you are using a CEA mode.
                      • W
                        wolverine
                        thx for your time and help i will try this tomorrow i will let you know if it works
                        • W
                          wolverine
                          i reinstalled retropie this morning and now the controlblock doesnt work no more but it fixed the sound issue :D thx for your help
