    Problem with controller mapping
    acmeretropie4.0.2controllermapping
    3 Posts 2 Posters 5.1k Views
      redlv
      Hello,
      Im having a problem with ACME GA08 controller mapping.
      I already had problems at the input configuration screen. When i tried to configure LEFT/RIGHT ANALOG UP/DOWN/RIGHT/LEFT, it returned "Already taken", so i skipped those. Afterwards, when i tried playing Legend Of Zelda: Ocarina of Time, the DPAD wasn't working the way it should work. The DPAD-Down key was mapped to A, so i couldn't really play it. And Super Mario Bros 3. on NES didn't even work with my controller. The strange thing is, that it worked fine (AFAIK) at the EmulationStation screen. What can be done about this?
      Pi Model: 2 B
      RetroPie Version Used: 4.0.2.
      USB Devices connected: USB Controller, Edimax 7811Un Wifi Adapter
      Controller used: ACME GA08 (Shows up as "DragonRise Inc. Generic USB Joystick")
      Joystick configuration file: http://pastebin.com/RUAchQQ2
      retroarch.cfg: http://pastebin.com/jJpNKR2L
        redlv @redlv
        @redlv I apparently solved the issue by pressing the "Analog" button on the controller, then reconfiguring the input.
          meleu @redlv
          @redlv mark your topic as solved then.
