    Runcommand System Splashscreens!
    run commandruncommandsplashscreenpixelpixel theme
    342 Posts 81 Posters 526.8k Views
    • RookervikR
      Rookervik Global Moderator
      Edited with correct info and "fix" from Meleu.
      It's that time again! More customization for you great people! This time, I made launch screens for every system that will display instead of the run command screen right before you launch a game!
      More examples!
      To achieve this, you must unzip the launching.zip archive into the /opt/retropie/configs folder. How you manage this is up to you. You can FTP in, you can use Samba shares and access the folder by the folder "configs" or you can come up with some other magical way to get these folders of images into /opt/retropie/configs.
      You know you've done it right when you get a directory listing like this:
      launching.png is the image that gets copied to the folder. This is what is displayed ont he Runcommand screen.
      Runcommand art needs to be disabled - thanks to @meleu
      Because of how RetroPie currently links Genesis and Megadrive together, you will need to choose which of the two images you'd like to use. The default is Genesis, the other is named "launching-megadrive.png" and you'd have to rename it "launching.png"
      Download: Pixel Runcommand Splashscreens
      meleuM UDb23U PokeEngineerP W sergioadS 15 Replies Last reply Reply Quote 26
        meleu @Rookervik
        @Rookervik
        I thought I've put it clear in the runcommando wiki:
        The conditions to show the custom launching image are:
        • Launch menu: enabled
        • existence of the launching.jpg or launching.png file in the proper config directory.
        • Launch menu art: disabled OR...
        • "Launch menu art" enabled, AND there's no emulationstation art for the chosen game.
        BTW:
        I really love your art dude!!
        RookervikR 1 Reply Last reply Reply Quote 3
        • RookervikR
          Rookervik Global Moderator @meleu
          @meleu Ah, very sorry. You did make it clear. I didn't read the entire wiki on that section. Thank you for clearing it up. So we're all good to go.
            meleu @Rookervik
            @Rookervik said in Runcommand System Splashscreens!:
            The "launch menu art" is not required to be disabled, BUT if it is enabled the launching.jpg will only be displayed when the game has no scraped art.
            English is not my native language, so this may not be very well written. I've just changed it a bit and hope that it's more clear now:
            • Launch menu art:
              • disabled OR...
              • enabled, AND there's no emulationstation art for the chosen game.
              meleu @Rookervik
              @Rookervik i arrived home and went to try these launching images with pixel theme... it's so beautiful that tears flowed from my eyes. :~)
              RookervikR 1 Reply Last reply Reply Quote 2
              • RookervikR
                @meleu Hahaha, glad you like them.
                lilbudL 1 Reply Last reply Reply Quote 1
                • RionR
                  Rion
                  Omg this is so sweet! Thank you!
                  FBNeo rom filtering
                  Mame2003 Arcade Bezels
                  Fba Arcade Bezels
                  Fba NeoGeo Bezels
                    lilbud @Rookervik
                    @Rookervik Did you finish those flat icons for the retropie menu?
                    RookervikR 2 Replies Last reply Reply Quote 0
                    • RookervikR
                      Rookervik Global Moderator @lilbud
                      @lilbud They're done but they look like ass.
                      I'd personally suggest using the icons already included in the pixel theme. They are in pixel/retropie/icons
                      • RookervikR
                        @lilbud I submitted them to the devs but I don't think they wanted to use them.
                          dankcushions Global Moderator
                          these are great! thanks :)
                          for anyone curious about the pixel theme, it's available in the theme manager: https://github.com/retropie/retropie-setup/wiki/themes
                            robertybob
                            Perhaps this is taking the piss a bit, but it there a way for automate this? i.e. a script that'll install the images to their respective folders (assuming they've not been renamed) and also enable the launch menu + disable menu art ?
                            Would be pretty sweet to have this as a menu item item much like installing additional Emulationstation themes!!
                            dankcushionsD RookervikR 2 Replies Last reply Reply Quote 1
                              dankcushions Global Moderator @robertybob
                              @robertybob said in Runcommand System Splashscreens!:
                              IMO the theme manager could do it at the same time as installing the theme.
                              • RookervikR
                                Rookervik Global Moderator @robertybob
                                @robertybob
                                My customization stuff is really just that; my little tweaks. For this stuff to make it into the RetroPie installer, Herb or Jools would have to create the installer and add it to the system. That's fine if they want to, but I don't want to bother them about it.
                                herb_fargusH R 2 Replies Last reply Reply Quote 0
                                • herb_fargusH
                                  herb_fargus administrators @Rookervik
                                  @Rookervik at the very least I could probably include them in the pixel theme repo (like I did with the alternate icons)
                                    robertybob @Rookervik
                                    @robertybob
                                    I was just thinking that it's such a neat idea, and well executed, that it would be such a shame if, over time, this was lost deep within the forums.
                                      meleu @robertybob
                                      @robertybob OK. I'll put a link to the @Rookervik dropbox file in the runcommand wiki page.
                                      Thanks for the idea! :-)
                                        detron
                                        I think these look Great! I installed them on my Retropie with no issues. thank you!
                                          backstander
                                          I can't wait to get home and try this out! Great work @Rookervik !
                                            meleu @herb_fargus
                                            @herb_fargus I had another idea, see if you agree:
                                            create a subdirectory in your retropie-splashscreens-extra named runcommand and then subdirectories with the runcommands launching image packages.
                                            Not sure if I described well... Here is an example using the pixel-friendly images that @Rookervik made:
                                            https://github.com/HerbFargus/retropie-splashscreens-extra/
                                                - runcommand/
                                                    - pixel/
                                                        - atari2600/
                                                        - mame/
                                                        - megadrive/
                                                        - nes/
                                                        - snes/
                                                        - ... etc...
                                            And maybe in the future the the retropie_setup Splashscreen menu can manage the runcommad's splashscreens too.
