    Runcommand System Splashscreens!
    run commandruncommandsplashscreenpixelpixel theme
    342 Posts 81 Posters 555.7k Views
      meleu @UDb23
      @UDb23 I think it would be pretty simple. Maybe only one line of code on runcommand.sh. But a naming convention is needed.
      My suggestion is RetroPie/roms/SYSTEM/images/RomName-lanching.png (or .jpg).
        UDb23 @meleu
        @meleu Sure. I totally agree.
          meleu @UDb23
          @UDb23 It's done. The logic is the same of the system launching images (scraped image takes precedence if "Launch menu art" is on). Just update your RetroPie-Setup script / runcommand and then place the images with the naming convention we talked above. ;-)
          I ended up making symbolic links to the cool game related splashscreens. Example, I made symbolic links for all my megaman games pointing to this image:
          launching_megaman
          Pretty cool, huh?! :-)
          UDb23U 1 Reply Last reply Reply Quote 2
            UDb23 @meleu
            @meleu Thanks !!!
            • DarksaviorD
              Darksavior
              How do you use the pce-cd loading screen? I have manually added pce-cd to the default carbon theme, which supports it. The problem is, pce-cd games use pcengine to load, so the pcengine loading screen is used. No big deal, just wondering if there was a way.
              ShizzmoneyS 1 Reply Last reply Reply Quote 0
              • PokeEngineerP
                PokeEngineer @Rookervik
                Hey @Rookervik ,
                Can you make runcommand splashscreens for the 3 GameMaker games (Maldita Castilla, Super Crate Box, and They Need to be Fed)?
                Don't sweat it.
                  lilbud @PokeEngineer
                  @RetroPieNerd Here you go.
                  RookervikR hiulitH 2 Replies Last reply Reply Quote 2
                  • RookervikR
                    Rookervik Global Moderator @lilbud
                    @lilbud Thanks rook. :P
                    Actually I think I have a repo for these. And buzz made a change so that ports work. I'll have to chat with him tomorrow and get the correct directory structure. Then I can add these. But I will do them like the other run command screens. And probably fix Kodi. It looks turrible.
                    • hiulitH
                      hiulit @lilbud
                      @lilbud Awesome! Thanks! I'll try them when I get home right away!
                      My little contributions to the RetroPie project:
                      • Shell-Script-Boilerplate
                      • Fun-Facts-Splashscreens
                      • Limit-Last-Played-Games
                      • RookervikR
                        Ok, got the titles pixelized and now just need the directory structure.
                        hiulitH PokeEngineerP 3 Replies Last reply Reply Quote 3
                        • hiulitH
                          hiulit @Rookervik
                          @Rookervik Ohhh!! Much better! ;) Thanks
                          • PokeEngineerP
                            @Rookervik
                            Directory Structure:
                            Maldita Castilla = /opt/retropie/configs/ports/MalditaCastilla
                            Super Crate Box = /opt/retropie/configs/ports/SuperCrateBox
                            They Need To Be Fed = /opt/retropie/configs/ports/TheyNeedToBeFed
                            Don't sweat it.
                            RookervikR 2 Replies Last reply Reply Quote 1
                            • RookervikR
                              @BuZz
                              Do you know what folder structure I'd use for the game-maker game splash screens? I have no idea where to add them in the repository. Everything else goes in ...configs/<system>/launching.png
                              • RookervikR
                                Rookervik Global Moderator @PokeEngineer
                                @RetroPieNerd Thank you very much. :D
                                • RookervikR
                                  @RetroPieNerd The capitals are correct? They aren't all lower-case?
                                  PokeEngineerP 1 Reply Last reply Reply Quote 0
                                  • RookervikR
                                    Looks like you can grab the screens from this link.
                                    I don't know if there's a downloader on the retropie menu. As far as I know you just download all of this as a zip. Which can be done, here. LOL. Green button, click "Clone or Download" and download it wherever it is you download stuff.
                                    Dropbox is changing the public folder so I won't upload anything there until that's all settled down.
                                    • PokeEngineerP
                                      @Rookervik
                                      Yes I am sure, I checked it in the script to install them.
                                      Don't sweat it.
                                      • PokeEngineerP
                                        @Rookervik
                                        You could just directly clone it to the Raspberry Pi in the file manager for now...
                                        Don't sweat it.
                                        • PokeEngineerP
                                          @Rookervik
                                          Thanks for the awesome splashscreens! Cheers!
                                          Don't sweat it.
                                            tekn0
                                            This post is deleted!
