    Runcommand System Splashscreens!
    run commandruncommandsplashscreenpixelpixel theme
    342 Posts 81 Posters 555.8k Views
    • daeksD
      daeks
      @Rookervik very nice picture pack! Is there also a version available for the carbon theme?
      RookervikR 1 Reply Last reply Reply Quote 0
      • RookervikR
        Rookervik Global Moderator @daeks
        @daeks No splash pack for the Carbon theme. A splash pack for Carbon would take considerably longer to create and be quite a large file size. I didn't plan on making one. Especially considering there are well over 80 splash screens to create for a "pack" *(-_-)
        daeksD meleuM 2 Replies Last reply Reply Quote 0
        • daeksD
          daeks @Rookervik
          @Rookervik too bad, but anyhow I have added it to my installation. I really like it.
          • RookervikR
            @daeks Let me know if you run into any systems that won't launch after installing the splash screens. For me, Final Burn stopped launching when I put a splash screen for it. Removing the splash screen allowed it to go back to running again.
            meleuM herb_fargusH 2 Replies Last reply Reply Quote 0
              meleu @Rookervik
              @Rookervik let's fix it! I'm using the fba launching screen with no issues!
              Is your RetroPie updated? What version?
              • herb_fargusH
                herb_fargus administrators @Rookervik
                @Rookervik idk it may be possible to batch script a launch image for each system based on the assets already available with carbon- perhaps like the ones we did for paradox when we were attempting that great failure...
                If anyone is feeling ambitious ;)
                • RookervikR
                  Rookervik Global Moderator @herb_fargus
                  @herb_fargus It would be hard to find a program that would be able to use SVG, though. I was planning to flatten all the Carbon SVGs down to PNG at some point to increase speed, maybe now is a good time.
                  • RookervikR
                    Oh gawd, I will have to re-do all the pixel run commands now. LOL. That can wait til I edit the consoles. :D
                      meleu @Rookervik
                      @Rookervik if you did "carbon-friendly" launching screen, what picture would you use? The system logo at the top, the controller at the center and the message at the bottom?
                      Maybe we can find some ImageMagick trick to automate this task...
                      • RookervikR
                        Rookervik Global Moderator @meleu
                        @meleu Right now just all the controllers and logos need to be converted to PNGs.
                        Then I'd have to spend some time thinking about how it should look. And go over it with buzz since that's his chosen theme.
                          meleu @Rookervik
                          @Rookervik said in Runcommand System Splashscreens!:
                          You can do it from command line on a Linux box (with ImageMagick installed). The command is simple as that:
                          Before using this command I had to install librsvg2-bin:
                          sudo apt-get install librsvg2-bin
                          As you said you don't plan to make Carbon splashscreens due to the number of systems, I remembered the ImageMagick tools and thought "If the splashscreens are simple enough, maybe we can automate their generation with some ImageMagick wizardry."
                          I'm not an ImageMagick wizard and I'm not really sure if this is possible, but I can do some research on this topic...
                          • RookervikR
                            Well once the images are all converted you can run a Photoshop script to create everything. I'll have to dig out my linux laptop and see about converting all the SVGs that way. Doing them all in Illustrator is a massive bummer.
                              meleu @Rookervik
                              @Rookervik if you're brave enough to believe me :) , the following commands convert all the SVG files below a directory level to PNG. Actually it won't convert but creates a new file with PNG format, and leave the original SVG file untouched.
                              EDIT: don't forget to install librsvg2-bin before!!
                              And yes! I tested these commands before posting here! ;-)
                              # create a temporary directory in your home dir
                              cd ~; mkdir tmp
                              # copy the theme files to another place
                              cp -R /etc/emulationstation/themes/carbon/ ~/tmp/
                              # create PNG files from the SVG files
                              # the -verbose option isn't really necessary, it's used just to let you
                              # see that something is happening
                              for svg_file in $(find ~/tmp/carbon/ -type f -name '*.svg'); do convert -verbose "$svg_file" "${svg_file/%svg/png}"; done
                              Hope it helps! :-)
                                By the way, here are some examples of what I could get with my initial research on ImageMagick commands and the respective command line (these commands were executed after the conversion from SVG to PNG):
                                convert -size 800x600 tile:$HOME/tmp/carbon/art/carbon_fiber.png -gravity center ~/tmp/carbon/nes/art/controller.png -composite nes.png
                                convert -size 800x600 tile:$HOME/tmp/carbon/art/carbon_fiber.png -gravity center ~/tmp/carbon/nes/art/system.png -composite nes2.png
                                convert -size 800x600 tile:$HOME/tmp/carbon/art/carbon_fiber.png -gravity center ~/tmp/carbon/nes/art/system2.png -composite nes3.png
                                herb_fargusH RookervikR daeksD 3 Replies Last reply Reply Quote 1
                                • herb_fargusH
                                  herb_fargus administrators @meleu
                                  @meleu I used imagemagick to generate grids of sprites I ripped from Bomberman
                                  I wrote up a bit of a guide here:
                                  https://github.com/HerbFargus/Atomic-Bomberman/wiki/Sprites#create-montage-with-imagemagick
                                  Personally I think the run command launch images should have the carbon background instead of just black ;)
                                  • RookervikR
                                    @meleu Those look slick already. And use the carbon fiber. Just need some nice text saying to press X or 'any key' to configure run command.
                                    PS, it does seem "X" is the most-correct button to press if you need to get into the run command editor. Any other button seems to be ignored (on a joystick)
                                    Might want to test 1080p versions of these and see how long it takes to load them. I fear it might take long enough to load them that they might just flash on the screen for a split second before the game launches.
                                    • daeksD
                                      daeks @meleu
                                      @meleu wow, I already love your third image :) I am happy to see that there will be something for carbon as well in the near future.
                                      edit: I played a bit with imagemagick on windows: https://github.com/daeks/retropie-system-splashscreens-carbon
                                      Each folder contains an autogenerated launching.png. The parameters used are stored in convert.bat
                                        meleu @herb_fargus
                                        @herb_fargus
                                        But it's already carbon. Maybe are not seeing because you're on mobile?
                                        @Rookervik
                                        Could you make an image with the text with a transparent background (just like the controller lines)? You can choose a font that pleases you...
                                        With this I can make the launching images for carbon...
                                        Actually runcommand gets input from the 0 and 1, and unfortunately the manufacturers don't have a standardization about these numbers. I have several joysticks here and the <ENTER> button (button 0) differs in all of them.
                                        The "a" on the text should be an indefinite article, not the A button of the joystick. :-)
                                          meleu @daeks
                                          @daeks said in Runcommand System Splashscreens!:
                                          edit: I played a bit with imagemagick on windows: https://github.com/daeks/es_launching_carbon
                                          Wow! It's exactly what I would do!! I think I don't need to spend more time with it! LOL :-)
                                          Thanks for sharing!
                                          EDIT: And you used the command line to add the text. Good catch!! :-)
                                          daeksD 1 Reply Last reply Reply Quote 0
                                          • daeksD
                                            daeks @meleu
                                            @meleu glad to hear that you like it :) anyhow it is not final as it still struggles about some issues:
                                            • logos which are too big (edit: fixed)
                                            • logos which are black or transparent (like game&watch or gamecube) are just shown as black image
