Final Burn Alpha 0.2.97.39 is out!
can anyone please help i just updated floobs image by using the onscreen guide in retro pie everything looks good but now i have loads of text on right hand side of screen scrolling up when i boot up or swith to attract mode. i think this was hidden before.
thanks
@meleu thanks bro i check it out
It seams the where some problem with the input mapping in the latest release
Issues
Rework mappings in fbalpha ?Commits on Oct 24, 2016 New input handling (final version ?)
But there seams to be some discussion about it. So no final version yet.
I think the new input mapping is now final from what i can see on libretro.
new input handling in fbalpha-libretro
"the new code is easier to maintain and should solve present and future issues with bad/missing inputs"
There is also a fix for segfault while running actfancr (and clones).
Maybe new binaries should be in order?
They were rebuilt yesterday.
@BuZz said in Final Burn Alpha 0.2.97.39 is out!:
actfancer still segfaults, the commit was a day ago, so probably just missed that fix.
Well, i'm working a lot on fbalpha-libretro these days, expect lots of bugs and bugfixes (i finally got working analog controls this morning, i still need to rewrite some code before pushing it, probably within a day)
@Twitch0815 Rtype & Rtype 2 crash back to ES with 0.2.97.39 :( (
Rtype works in level 1, from level 2 on crashes. Rtype 2 crashes from level 1 on after some playing..
Tested with CLRMAMEPRO confirmed Roms. LR-FBalpha 2012 runs fluidly, but core does not support savegames :(
Any ideas? I´m on RP4.1
