    A problem About the forum.
    forum
    18 Posts 4 Posters 3.9k Views
    • spannernick1S
      spannernick1
      Why are you not using phpBB or vBulletin,I am asking cos I have to always change the zoom level in chrome to fit the edit box in to post (its at the bottom) and it makes the text smaller that I can't see it that well,and I were glasses.
      Its just annoying.I have to have it at 75% .is there a way of not using the box at the bottom to post..?
      If I have it higher things don't fit like where the home/help and support is,its under the header.When I say its under the heder it is its under it so you can just see it..;)
      It maybe my resolution,The forum is for higher res than 1024x768.I don't use a widescreen monitor,I don't like them,I like the Retro feel..)..I think I am still in the 80s..;)
        BuZz administrators
        Please post a screenshot so I can see / pass upstream to the forum devs.
          GtBFilms
          I think he means like this:
          1024 x 768 screen resolution - the compose box is partially off the bottom of the screen and the 'Home /Help Support/ A problem about the forum' navigation hierarchy is partially obscured by the menu bar.
          spannernick1S 1 Reply Last reply Reply Quote 0
            BuZz administrators
            I will see if this is something I can fix in css, or if it's an upstream issue.
              BuZz administrators
              hmm seems to fit ok on mine at a smaller res. if the res is too small it also goes fullscreen.
              Which browser? Did you try any other browsers to see if it's different ?
                BuZz administrators
                the top bar is is a minor one, I already removed one icon to make it work on a smaller screen, but I will see what I can do.
                I much prefer nodebb over old style forums though.
                  Pyjamarama
                  I have been using Vbulletin as an admin for 11 years.
                  Vbulletin 5 is the worst piece of @@@@ I have ever used. It has caused us terrible issues and loss of users due to them.
                  I really like the software platform Buzz has selected to use for this community
                    GtBFilms
                    Yeah, I've got no gripes with it personally, and like it.
                    I was just illustrating the problem @spannernick1 had.
                    Using ctrl - to shrink the page fixes it (or getting hold of a higher resolution monitor!)
                      BuZz administrators
                      Note - you can also press the icon second to the right when composing to enter "Zen mode" (fullscreen editor). You should be able to increase the height of the composing area too - with the icon at the left above the topic title.
                      • spannernick1S
                        spannernick1 @GtBFilms
                        @GtBFilms Thanks you beat me too it..;) I only use Chrome not any other cos i'm use to it and being using it for years,and It signs me in to everything.I have firefox I try that.
                        • spannernick1S
                          spannernick1
                          Yep it does it with Firefox too.I would get a new monitor but they have just stopped my benefit..;( so no money,thanks DWP.
                          • spannernick1S
                            spannernick1
                            I don't have a problem with the forum as it looks I am happy with it just the fit is the problem,if I made it sound like I didn't like the forum I am sorry I didn't mean that,I sometime have a problem with communication so no worries..;)
                              BuZz administrators
                              Doesn't happen on my Firefox when I set it to 1024x768.
                              I will try on windows though.
                              Can probably pick up a monitor with a better resolution from a local freecycle type organisation/mailing list. People get rid off old monitors all the time - and often no-one wants them.
                                BuZz administrators
                                I have removed the "RetroPie Forum" text from the header and have used an image instead - this will fix the header issue. May or may not help the other issue.
                                • spannernick1S
                                  spannernick1
                                  You are right...werid,dam just noticed the you can drag the box up and down,was it there before...silly me..My brain don't allways see everything,well thats what autism does to you..;(
                                  • spannernick1S
                                    spannernick1
                                    Yep that sorted it,can see the home/Help and Support now,thanks..;) Nice to be able to see it properly too,I have it at 99% now..:)
                                    • spannernick1S
                                      spannernick1
                                      I was wondering about Attachments,can you add it so you can add pictures or add a link like on Lemon64 forum it has a link .. • Add image to post and it opens a box so you can add a picture file to the post but uploads it to postimage.org then adds it to the post..?
                                        BuZz administrators
                                        You can upload directly with the icon at the top right - or upload manually to an external site and reference it (the image icon helps)
                                        This forum uses markdown syntax
                                        http://commonmark.org/help/
