    LR-PSCX Rearmed analog issue
    psxlr-pcsx-rearmedanalog
    13 Posts 3 Posters 3.1k Views
      meleu @YoshiFan501
      @YoshiFan501 paste your /opt/retropie/configs/psx/retroarch.cfg and /opt/retropie/configs/all/retroarch.cfg in pastebin.com (or something similar) and put the link here. So we can check if it's something with your configs.
      Y 1 Reply Last reply Reply Quote 0
      • Y
        YoshiFan501 @meleu
        @meleu said in LR-PSCX Rearmed analog issue:
        http://pastebin.com/7B4TCc3R here you go!
          meleu @YoshiFan501
          @YoshiFan501
          Did you followed these instructions?:
          https://github.com/retropie/retropie-setup/wiki/Playstation-1#analog-controller-type
          I didn't find any problem with your configs. Just one thing to note: there's no need for that system_directory config in your ...psx/retroarch.cfg, this option is already present in ...all/retroarch.cfg. Anyway it has nothing to do with your analag pad issue.
          • Y
            YoshiFan501 @meleu
            @YoshiFan501
            I have! Still no response from analog. Also tried messing with the controller settings to retropad with analog and that doesn't work either.
            rgui settings
              meleu @YoshiFan501
              @YoshiFan501 it's a little embarrassing... only now I noticed that you updated retropie to the latest commit, and not the lr-pscx-rearmed...
              Sorry, I can't see what's going wrong... :/
              • Y
                YoshiFan501 @meleu
                Its alright! I'll either just wait for a fix or roll back RetroPie
                • Y
                  YoshiFan501
                  Any other idea on what may be going on?
                    edmaul69 @YoshiFan501
                    @YoshiFan501 one of the versions i had to set all the controllers to analog to work so i would try that on some crazy off chance that might help.
                    • Y
                      YoshiFan501 @edmaul69
                      @edmaul69 said in LR-PSCX Rearmed analog issue:
                      SOMEHOW THAT WORKED!
                      Thank you so much!
                        @YoshiFan501 no prob. Glad i could help!!
