DragonRise usb arcade stick keep on D1
  • Hello,
    I use a DragonRise usb arcade stick with Retropie on a Raspberry Pi 3.
    I would like to know how to keep the card on D1, which means "device 1". I can switch from D1 to D2 by switching the mode button on the controller card.
    The problem is when I restart Retropie, the controller car always start on D2 (red light).
    How can i foce the controller card to stay on D1 ?
    Thank you.
  • EDIT : I continue to search and I found that the "mode" button switches between two modes, signaled by green and red LEDs next to the button. Green appears to be designed for games expecting only digital controls, while red makes all analog controls available.
    So it is not what I need.
    I need to use two identique arcade stick on the same Rasperberry Pi.
    Do you know how to make this possible ?
    When I configure the inputs for the second stick, it says that buttons are already taken...
  • i think i also have this issue! any help?
