    Using Retropie Setup inside SteamOS
    retropiex86steamos
    18 Posts 4 Posters 8.3k Views
      Twitch0815
      Alienware Steam Box
      RetroPie Version Used: (3.6, 3.8.1, 4.01 etc..) 4.0.6
      Built From: Attempting Retropie X86 Install
      USB Devices connected: Steam Controller via dongle
      Controller used:Steam Controller
      Error messages received:
      Unsupported OS
      Distributor ID: SteamOS
      Description: SteamOS 2.0
      Release: 2.0
      Codename: brewmaster
      How to replicate the problem:
      Starting with a fresh SteamOS install
      launching Retropie Setup
      desktop@steamos:~/RetroPie-Setup$ uname -a
      Linux steamos 3.18.0-trunk+steamos1-amd64 #1 SMP Debian 3.18.17-1+steamos2 (2015-07-11) x86_64 GNU/Linux
      desktop@steamos:~/RetroPie-Setup$ cat /etc/issue
      SteamOS GNU/Linux 8 \n \l
      Is there edits or something that can be updated to allow for the Retropie SEtup to proceed on SteamOS?
        Twitch0815
        Best I can tell version 2.0 of Steam OS is Debian Jessie
          meleu @Twitch0815
          @Twitch0815 is steamos ubuntu based?
          Edit: oh. I see your next post right now. It's Debian based...
            meleu @Twitch0815
            @Twitch0815 can you paste here the output of lsb_release -sidrc?
              BuZz administrators
              for testing
              cd ~/RetroPie-Setup
              wget http://malus.exotica.org.uk/~buzz/steam.diff
              patch -p1 <steam.diff
              sudo ./retropie_setup.sh
                Twitch0815
                @meleu
                desktop@steamos:~/RetroPie-Setup$ lsb_release -sidrc
                SteamOS
                SteamOS 2.0
                2.0
                brewmaster
                  Twitch0815
                  @BuZz
                  On first try
                  Reading package lists... Done
                  Building dependency tree
                  Reading state information... Done
                  Package dialog is not available, but is referred to by another package.
                  This may mean that the package is missing, has been obsoleted, or
                  is only available from another source
                  E: Package 'dialog' has no installation candidate
                  E: Unable to locate package xmlstarlet
                  Unable to install packages required by /home/desktop/RetroPie-Setup/retropie_packages.sh - Could not install package(s): dialog g++ build-essential unzip xmlstarlet.
                    meleu @Twitch0815
                    @Twitch0815 does SteamOS have apt-get?
                      Twitch0815
                      Yea absolutely. Its got a full desktop mode, terminal and apt-get
                        meleu @Twitch0815
                        @Twitch0815 for some reason retropie_setup failed to install the following packages: dialog g++ build-essential unzip xmlstarlet.
                        Try to install it yourself via apt-get and then try again.
                          Twitch0815
                          Going to try adding
                          add "deb http://ftp.us.debian.org/debian/ main contrib" to the end,
                          but will need to rekick as I had switched to Ubuntu
                            Twitch0815
                            Solution thus far is to edit the /etc/apt/sources.list file
                            adding the following to the bottom
                            deb http://security.debian.org/ jessie/updates main contrib non-free
                            deb-src http://security.debian.org/ jessie/updates main contrib non-free
                            deb http://http.us.debian.org/debian jessie main contrib non-free
                            then sudo apt-get update && sudo apt-get upgrade
                            Follow normal x86 install instructions and applying exos patch above will then allow retropie setup to launch correctly.
                            Currently running basic install will report back on progress
                              Twitch0815
                              @BuZz
                              Alright progress
                              Basic Install builds successfully
                              NDS builds successfully
                              Reicast Builds Successfully
                              PSP Builds Successfully
                              Kodi will install if you add
                              deb http://http.debian.net/debian jessie-backports main
                              to the /etc/apt/sources.list
                              Dolphin does not install from Retropie Setup but Debian Jessie 8 allows for simple sudo apt-get install Dolphin but none of the special sauce is done like the rom directory or ES integration and the dolphin exeuctable i cant seem to find, even via the program search where something like retropie or emulation station could be found and launched manually
                              http://pastebin.com/2bptLVed
                              Is the installation log.
                                backstander
                                Thanks for keeping us updated on this @Twitch0815
                                Another way you can search for files from the command prompt by using sudo find / -name "<filename>” You could do something like sudo find / -name "dolphin". I don't use this find function that much.
                                I personally like to use Locate instead!
                                To install Locate type:
                                sudo apt-get install locate
                                To update the database that Locate uses to find files and directories:
                                sudo updatedb
                                Now all you have to do is type this to find something:
                                locate <filename>
                                Example:
                                locate dolphin
                                The only downside to Locate is that you sometimes have to update the database (sudo updatedb) to make sure you get all the newest files in your search. Updating will also remove newly deleted files.
                                  Twitch0815
                                  Looking into this further,
                                  probably the simplest and cleanest option is installing SteamOS Tools
                                  https://github.com/ProfessorKaos64/SteamOS-Tools
                                  After a clean install, and only adding SteamOS Tools
                                  Basic Install compiles cleanly
                                  Dolphin compiles cleanly
                                  lr-desumme compiles cleanly
                                  kodi installs cleanly
                                    Twitch0815
                                    Next major step was to get Steam OS to load, emulationstation from its native menu.
                                    to do this you need to create a file called
                                    emulationstation.desktop
                                    in the
                                    /usr/share/applications
                                    directory and paste in the following
                                    [Desktop Entry]
                                    Version=1.0
                                    Name=EmulationStation
                                    GenericName=EmulationStation
                                    Comment=Manage and play your games
                                    Exec=emulationstation
                                    Icon=emulationstation
                                    Terminal=false
                                    Type=Application
                                    Categories=AudioVideo;Video;Player;TV;
                                    Actions=Fullscreen;Standalone;
                                    [Desktop Action Fullscreen]
                                    Name=Open in fullscreen
                                    Exec=emulationstation -fs
                                    OnlyShowIn=Unity;
                                    [Desktop Action Standalone]
                                    Name=Open in standalone mode
                                    Exec=emulationstation --standalone
                                    OnlyShowIn=Unity;
                                    Just documenting here for now, will update in wiki going forward.
                                      Twitch0815
                                      Only problem now is
                                      that when you launch EmulationStation from within SteamOS it seems to manage the application.
                                      I mapped controls which is awesome because when Steam is managing it overlays the controller profile allowing the steam controller to be configured semi-correctly. Button triggers I need to manually mess with inside the controller config.
                                      It also gets the advantage of having the Steam Button be able to bring up the xmb of steam allowing for hot swapping controller settings and exiting the shortcut.
                                      Problem is that when launching say a genesis game, it shows the steam thinking icon really fast then reverts back to emulation station
                                      /dev/shm/runcommand says
                                      parameters: 0 SYS megadrive /home/desktop/RetroPie/roms/megadrive/3 Ninjas Kick Back (USA).md
                                      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-picodrive/picodrive_libretro.so --config /opt/retropie/configs/megadrive/retroarch.cfg "/home/desktop/RetroPie/roms/megadrive/3 Ninjas Kick Back (USA).md" --appendconfig /dev/shm/retroarch.cfg
                                      So I know it does try to launch it just Steam seems to stop if.
                                      Tried as well with Kodi and it did the same thing.
                                      I know were out of the normal support matrix i posted on /r/steamos to see if any users have found a way to allow a steam managed application to launch another application in the same profile which I guess is what I am hoping for, just documenting where I am at and if anyone has any ideas on something to try let me know.
                                        Twitch0815
                                        http://pastebin.com/jfKLrumc
                                        Pastebin of the STD out file
                                        This is the output of tail -f /tmp/dumps/steam_stdout.txt
                                        When attempting to launch lr-picodrive from inside emulation station that is launched from SteamOS.
