    Aimtrak Light gun and Mame2003
    aimtraklight gunmame2003mame 2003lightgun
    44 Posts 9 Posters 20.0k Views
      mediamogul Global Moderator @BGallagherLA
      @BGallagherLA
      I haven't tried it myself, although I'm pretty sure it won't work in conjunction with the DolphinBar unless that advertised sensor mode is somehow alluding us. However, if any of the linux Wiimote drivers pass the g-sensor information along as an analog controller axis, then it should work just fine.
      • HurricaneFanH
        HurricaneFan
        @gunpadawan I'm getting this error when I try to install the setup.py script step:
        pi@retropie:~/gunconf $ python setup.py install
        Traceback (most recent call last):
          File "setup.py", line 1, in <module>
            from setuptools import setup, find_packages
          gunpadawan @HurricaneFan
          @HurricaneFan sounds like you are missing setuptools
          try this:
          sudo apt install python-setuptools
          HurricaneFanH 1 Reply Last reply Reply Quote 0
          • HurricaneFanH
            HurricaneFan @gunpadawan
            @gunpadawan Now it's throwing this error:
            running install
            error: can't create or remove files in install directory
            The following error occurred while trying to add or remove files in the
            installation directory:
            [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/test-easy-install-1018.write-test'
            The installation directory you specified (via --install-dir, --prefix, or
            the distutils default setting) was:
            Perhaps your account does not have write access to this directory? If the
            installation directory is a system-owned directory, you may need to sign in
            as the administrator or "root" account. If you do not have administrative
            access to this machine, you may wish to choose a different installation
            directory, preferably one that is listed in your PYTHONPATH environment
            variable.
            For information on other options, you may wish to consult the
            documentation at:
            https://pythonhosted.org/setuptools/easy_install.html
            Please make the appropriate changes for your system and try again.
