    Retroarch Not Seeing Controllers
    retroarchcontrollerx86
    27 Posts 7 Posters 11.1k Views
      popkid @popkid
      @popkid said in Retroarch Not Seeing Controllers:
      @obsidianspider no worries :) weird you didn't have anything at all at that level though, my udev folder was there and full of entries (dozens of them for all sorts of controllers) just not my controller, it was your debug stuff that led me there, so thanks to you too, happy gaming :)
      actually, I recall I did an online update in retroarch of the autoconfig databases in my attempts to fix my issue, I guess it created the udev folder and entries in the course of doing that
        pawpie
        i have this exact problem right now as well
        i was also missing udev folder from retroarch which i created and then copied the gamepad.cfg files. Unfortunately for it made no difference my control still does not work when launching games it seems to be disabled and only allows the keyboard to be used
          obsidianspider @pawpie
          @pawpie this is a dumb question, but did your reboot? I don't think it matters with retroarch, but it's worth a try. I rebooted and re-upgraded so many times I don't know when I did what.
            pawpie @obsidianspider
            @obsidianspider
            I did restart the system , at first i only copied the gamepad.cfg control but since that did bit work i also copied the other .cfg file ( says play station wireless gamepad.cfg) as well as a .bak file but that also did not make a difference.
            Restarted the system about 4 times already still same issue
            I am using retropie on a raspberry pi 3 though not a pc
              @pawpie rebuild retroarch from binary via the retroarch_setup.sh menus. That seemed to help the other person who was having trouble.
              • L
                lawrencejd @obsidianspider
                @obsidianspider Hello everyone, I'm using retroarch, everything smooth but when i connect xbox 360 controller its keep blinking even i installed the driver using this command sudo apt-get install xboxdrv
                can anyone help me out?
                  mitu Global Moderator @lawrencejd
                  @lawrencejd Please open a new topic explaining your issue and add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first.
                  It's bad forum etiquette to bump years old topics, even if related to your issue.
