    Top requested arcade games for overlays
    overlayarcadepoll
    594 Posts 34 Posters 854.4k Views
    • RiverstormR
      Riverstorm @UDb23
      @udb23 said in Top requested arcade games for overlays:
      @riverstorm said in Top requested arcade games for overlays:
      On a side note do you think there's any value to making an option to adjust input_overlay_opacity globally
      I think that's an interesting suggestion; I did get a couple of requests on how to set different level of opacity. Don't know if this a customization that's requested by many.
      Ok, right now I do them manually and make a backup on a USB so I don' t need to do it again. Maybe if enough interest is shown a feature request down the road for those that don't like command line file tweaking.
        UDb23 @Riverstorm
        @riverstorm The idea behind @meleu's script is to allow (typically less expert) people to install overlays and other art without needing to edit or move files around manually.
        So you're right it would be nice to be able to set custom opacity thru the same script.
        @meleu is quite busy already but maybe he'll be able to look into this in the near future.
          meleu @UDb23
          @udb23
          Yep, you're right. I'm kinda busy with another project now (RetroAchievements related). But you guys are encouraged to make feature requests, and using the repo's issue tracker is the best way to do it. ;-)
            UDb23 @meleu
            @meleu said in Top requested arcade games for overlays:
            Done.
            RiverstormR 1 Reply Last reply Reply Quote 2
            • RiverstormR
              Riverstorm @UDb23
              Done.
              Thanks Udb, I was going to add a feature request this morning but you beat me to it. It seems like a good fit for the script. I think the range you choose is perfect as much below .5 it gets pretty opaque.
              • BriganeB
                Brigane
                @UDb23 I'm sorry if this ain't the right place to be asking but I'm having a bit of a problem getting overlays to match my screen (Makibes 7 inch screen) as well as the game. Is it possible to adjust this in the config files for each overlay or is this to be adjusted in Retroarch?
                Edit: Also the first overlay I use keeps showing up in all the other games except when I change input_overlay_enable = "false" in Retroarch.cfg
                Thank you again for your amazing work!
                Systems: Raspberry Pi 0/2/3 Model B+
                Os: RetroPie 4.5
                Frontend: Emulationstation & Attract Mode
                UDb23U 2 Replies Last reply Reply Quote 0
                  UDb23 @Brigane
                  @brigane said in Top requested arcade games for overlays:
                  This happened previously to other users; if I remember well it's related to the "save on exit" retroarch setting.
                    UDb23
                    @Brigane For that issue check this.
                      UDb23 @Brigane
                      My overlays are for 1080p; what is your display resolution ? Probably it is not 16:9.
                      If this is the case actual artwork has to be re-created for your specific resolution; you can't fix this thru settings in cfgs.
                      BriganeB 1 Reply Last reply Reply Quote 0
                      • BriganeB
                        Brigane @UDb23
                        @udb23 the resolution is 800x480
                        Os: RetroPie 4.5
                          UDb23 @Brigane
                          @brigane unfortunately not exactly 16:9....
                          • BriganeB
                            Brigane @UDb23
                            @udb23 Too bad.. I really like those overlays. Oh well, thanks for the quick replies.
                            Os: RetroPie 4.5
                              UDb23 @Brigane
                              @brigane If you have one your really like I could adapt it. For this I need to know the actual game area size (check video settings in RGUI).
                              • AndersHPA
                                AndersHP
                                Hey @UDb23 - what's the ETA on some more 5:4 overlays? :) Gyruss, BurgerTime, Pacman, everything's of interest.
                                My Gameboy
                                UDb23U A 3 Replies Last reply Reply Quote 0
                                  UDb23 @AndersHP
                                  @andershp hope to have some time this weekend
                                    UDb23 @AndersHP
                                    @andershp said in Top requested arcade games for overlays:
                                    Gyruss 1280x1024 ready now:
                                    AndersHPA 1 Reply Last reply Reply Quote 4
                                    • AndersHPA
                                      AndersHP @UDb23
                                      Sublime! Looks sooo good!
                                      It's already installed, looks sweet! Thanks!
                                      My Gameboy
                                        UDb23 @AndersHP
                                        @andershp
                                        BurgerTime 1280.
                                        Fixed logo colors and updated also 1080p overlay. Launching image (game marquee @1080p) now available.
                                        AndersHPA UDb23U 2 Replies Last reply Reply Quote 2
                                        • AndersHPA
                                          AndersHP @UDb23
                                          @udb23 Nice, it's installed and it looks excellent! Thanks again!
                                          My Gameboy
                                            UDb23
                                            Congo Bongo overlay done (1080p and 1280x1024).
