    Emulators not showing (rom path and extension validated)
    retropie 4.1emulationstatiodaphneroms not workinemulators gone
    28 Posts 7 Posters 10.8k Views
      megananthony
      Hello, installed Daphne, C64 and coleco emus.Added roms (correct location and supported extensions) . Rebooted Pi and they do not show.
      Im using a Pi3 with version 4.1 retro.
      I have other emus that were previously installed that run fine.
      Parse gameslist is not on,
      i am really happy eith my build so far and do not want to have to restart (and won't to determine root cause)
      Any clues on where to start would be welcome
        mediamogul Global Moderator @megananthony
        @megananthony
        Did the log provide any useful information?
          megananthony
          Hi Medi,
          Could you please let me know where the log file is and i would happy to post it.
          Thanks for the peek
          Model or other hardware: n/a
          Power Supply used: (If using a Pi) 2.5
          RetroPie Version Used 4.1
          Built From: RetroPie website
          USB Devices connected: logitech usb keyboard/mouse
          Controller used: ps4 usb (blue tooth not set yet)
          Error messages received: n/a
          mediamogulM 2 Replies Last reply Reply Quote 0
            @megananthony
            The log can be viewed at /opt/retropie/emulators/daphne/daphne_log.txt
            @megananthony's Response from other thread:
            There is no log.txt file only the files below:
              So far we've verified that the emulators are installed, the "parse gameslist" option is off in Emulation Station and that the file extensions are correct inside the each system's ROM folder. I have to say, I'm at a bit of a loss as to what else would prevent a system from showing up in Emulation Station.
                @megananthony
                As a shot in the dark, you might try updating the RetroPie Setup, removing Daphne, reinstalling and then rebooting to see if it has any effect.
                • herb_fargusH
                  herb_fargus administrators @mediamogul
                  @mediamogul possible he has two es_systems.cfg and it keeps looking at the one in /.emulationstation instead of /etc
                    SpudsMcToole Banned @herb_fargus
                    I'm having the same problem as this. I've installed two emulators from the "Optional" list - CoolCV and GameAndWatch - and neither shows up. I've updated the Retropie setup script, I've updated both of the emulators after installing them just in case, and I have "Parse Gamelist Only" set to Off.
                    Both emulators have valid ROM files in the correct folders. I've even tried switching the file extensions on the Coleco ones between ROM, COL and BIN.
                    Whenever I've activated other emulators by adding ROMs, that's worked absolutely fine, but these two that I've had to install manually through the Retropie setup menu just will not appear no matter how many times I reboot or restart.
                    I also only have one ES_SYSTEMS.CFG as far as I can tell, which is located in the EMULATIONSTATION folder.
                    Any ideas would be much appreciated.
                    S herb_fargusH mediamogulM 3 Replies Last reply Reply Quote 0
                      SpudsMcToole Banned @SpudsMcToole
                      This post is deleted!
                      • herb_fargusH
                        herb_fargus administrators @SpudsMcToole
                        @SpudsMcToole there was an issue with colecovision but it should have been solved...
                          @herb_fargus I updated the Retropie setup script BEFORE I installed CoolCV.
                            Nobody got anything at all on this one? :(
                              mediamogul Global Moderator @SpudsMcToole
                              @SpudsMcToole said in Emulators not showing (rom path and extension validated):
                              What exactly is the path to the EMULATIONSTATION folder you're referencing?
                                SpudsMcToole Banned @mediamogul
                                @mediamogul /home/pi/.emulationstation
                                  Melvin.FoX @SpudsMcToole
                                  @SpudsMcToole do you have es_systems.cfg in /etc/emulationstation?
                                    SpudsMcToole Banned @Melvin.FoX
                                    @Melvin.FoX Aha! It seems that I do! (I think I'd just looked in "etc" before, not the "emulationstation" directory - I'm very new to this.)
                                    One of them had the Coleco and G&W emulators in the script and one of them didn't - I cut and pasted it across and bingo! Both emulators appeared in the menu! (The Coleco one freezes whenever I start a game, but that's a separate problem...) Thanks very much for the tip!
                                    Should I delete one of them, then?
                                    BuZzB herb_fargusH 2 Replies Last reply Reply Quote 1
                                      BuZz administrators @SpudsMcToole
                                      @SpudsMcToole the one in /opt/retropie/configs/all/emulationstation (which /home/pi/.emulationstationlinks to) will override the default retropie one which is stored in /etc/emulationstation. RetroPie only updates the es_systems.cfg in /etc/emulationstation
                                      You must have copied it before - if maintaining your own copy you need to manually keep it up to date etc.
                                        SpudsMcToole Banned @BuZz
                                        @BuZz
                                        Cheers. So I should delete the one in /home/pi/.emulationstation?
                                        (As a noob I'm obviously wary of deleting stuff that seems like it might be important.)
                                          @SpudsMcToole I was also noob few days ago but had the same problem ;) delere the one in .emulationstation folder. Or just rename the file to es_system.cfg.bak until You fully configure whole system. Just do yourself a to do list not to forget about it.
                                          • herb_fargusH
                                            @SpudsMcToole I was right! Sorry I wasnt more explicit in my paths. Helps to know what files you mess with, easier to fix that way
