Joystick general settings info
All to everyone...
anyone, could help me to change the joystick settings?
normally i connect joystick in USB "0" port
but if i try to run jstest dev/input/js0 - the test results for the keyboard in usb port 1
joystick results only in jstest dev/input/js1how I can change joystick setting from Js1 to Js0 ?
thanks in advance.
may be switch around the usb ports? try to plug your keyboard at 3 and your first joystick at 0.
@jretropie said in Joystick general settings info:
actually:
- joystick port 0
- keyboard port 2
i will try to plug keyboard in usb port 3, than i will give you results..
Unfortunately, i just tried to plug keyboard in usb port number "3"....
boot raspberry pi3
(retropie 4.1)linux command line:
jstest /dev/input/js0 = keyboard
jstest /dev/input/js1 = joysticki would think that there is a config file in linux... where it is stored.
i would set Joystick js0
and keyboard js1;)
someone would know tell me where it saved this parameter? -
@andrea_ita I think you may want to remove both device first and then detect it one by one.
Quit ES by pressing F4, ran sudo ~/RetroPie-Setup/retropie_setup.sh
went to Manage Packages -> Core Packages -> emulationstation -> Configuration and chose the option Clear/Reset Emulation Station input configuration.
Restarted ES by plug in Joystick (to the 0 Port) only with no keyboard and config your Joystick.
Restarted again and plug in your keyboard to 3 port.
ok i try now... i will delete es_input.cfg and follow your idea... ;)
@andrea_ita said in Joystick general settings info:
delete es_input.cfg won't work. I tried so many times. The instruction above remove all the controllers.
Another idea is to fix the keyboard so it won't detect as joystick:
https://manerosss.wordpress.com/2016/05/31/fix-mouse-detected-as-joystick/ -
i just follow your suggest.... in both ways, with 4 reboot...
reconfig first joystick... reboot... plug keyboard.. reboot...in the linux prompt.. /dev/input/js0 is always the keyboard.... :(
