    Colecovision sound stutters
    colecovisionsound issue
    50 Posts 10 Posters 13.7k Views
      mediamogul Global Moderator @dman2552
      @dman2552
      my screen goes blank and becomes unresponsive to any connected keyboard/controllers when I try to play any CV game
      I can't speak to the keyboard controls, but you might try adding the following to /opt/retropie/configs/all/runcommand-onstart.sh and see if it solves the screen issue. It was used to solve a similar issue in Kodi a while back and may work here.
      if [ "$2" = "coolcv" ]
      then
      fbset -depth 8
      fbset -depth 32
      fi
        raymate
        OK did from script and it works, sound normal. Perfect thank to all your hard work
        RPi 1b / 2b / 3b / 3b+ / Zero W
        iBuffalo gamepad / Logitech F310 gamepad / NeoGeoX ArcadeStick / Retroflag case and Controller
          dman2552 @mediamogul
          @mediamogul said in Colecovision sound stutters:
          @dman2552
          then
          fbset -depth 8
          fbset -depth 32
          fi
          I tried as you suggested but it didn't work. I did find out what the problem was. I used the /etc/modprobe.d/alsa-base.conf method of setting the sound device but had to use the /etc/asound.conf method. All seems to be working great now.
          Thanks.
          RetroPie 4.1.18, RPi3B, 32GB microSD, Logitech F310, mini wireless keyboard
            edmaul69 @BuZz
            @BuZz i have an ip address showing but when i try to update setup script so i can update coolcv i am getting this error:
            I even rebooted my pi and same thing. Tested in basilisk and i have internet connection.
            • RionR
              Rion @barbudreadmon
              @barbudreadmon said in Colecovision sound stutters:
              I'll try to fix fbalpha-libretro's colecovision inputs soon, that way you'll have an alternative to CoolCV.
              Yes please! 😀
              FBNeo rom filtering
              Mame2003 Arcade Bezels
              Fba Arcade Bezels
              Fba NeoGeo Bezels
              • herb_fargusH
                herb_fargus administrators @barbudreadmon
                @barbudreadmon I also hear the bluemsx is capable of emulating colecovision ;) just needs some controller hooks.
                RionR 1 Reply Last reply Reply Quote 1
                  BuZz administrators @edmaul69
                  @edmaul69 unrelated to this btw - you have out of date certificates, incorrect system time, or they have been removed. sd card corruption could also cause issues like this.
                  if related to missing certs you can try
                  sudo apt-get install --reinstall ca-certificates
                  if still no luck start a new topic.
                    edmaul69 @BuZz
                    @BuZz i had tried a couple hours later and it worked. Thank you
                    • E
                      EVEGames @mediamogul
                      @mediamogul Got it. Thanks!
                      • RionR
                        Rion @herb_fargus
                        @herb_fargus said in Colecovision sound stutters:
                        This would be a more viable option. Fba needs it's on romset for Colecovision.
                        With bluemsx you could just use the No-Intro set.
                        FBNeo rom filtering
                        Fba Arcade Bezels
                        Fba NeoGeo Bezels
