    Doom and other ports, Controller not working, and XBOX 360 controller problem.
    xbox 360doom portretropie
    15 Posts 5 Posters 7.0k Views
    • W
      wilburburns
      I've tried to install the Doom and a few of the other gaming ports, but I am unable to get my controller to work at all. My Controller does work in the normal NES, NES, and other gaming system Roms, just not on the other "Ported" games.
      Second Problem:
      I'm using a wireless XBOX 360 controller as my gaming controller. All works well, except at times, the connection between the controller and the system just dies. The green ring lights up on the conntroller, much like it was just reset and then it reconnects and works fine for a while longer. Obviously, this is a problem when it happens in the middle of a game, as often times, it's exactly when you need control the most and are killed, due to not being able to move.
      Any idea or links on how to fix these issues would be greatly appreciated.
      Thanks,
      Cliff
      edmaul69E B 2 Replies Last reply Reply Quote 0
        edmaul69 @wilburburns
        @wilburburns which emulator are you using to play doom?
        • ExarKunIvE
          ExarKunIv
          sounds like what they talked about here
          Xbox360 wireless controllers - receiver connectivity issues.
          i did what trixter1981 said for downgrading the firmware. and the few problems i had went away.
          hard to say if that will work for you, but its not hard to go back up if it does not help
          • W
            wilburburns @edmaul69
            @edmaul69 Should not be an emulator at all, it's the direct Doom port that is loaded like Kodi Port. I'm not in front of the Pi at the moment, but it may not have been Doom, it might be Quake or Duke Nukem, but it is one of those 1st person shooter games.
            There are a couple of other games or games that I have loaded the same way and none of those work with the controller either.
            Cliff
            • W
              wilburburns @ExarKunIv
              @ExarKunIv I'll give this a shot..
              Cliff
                @wilburburns it is an emulator. Either lr-prboom or zdoom. It tells you on the runcommand screen right before doom loads.
                mediamogulM W 2 Replies Last reply Reply Quote 0
                  @edmaul69 said in Doom and other ports, Controller not working, and XBOX 360 controller problem.:
                  lr-prboom or zdoom
                  I believe those are actually both source ports. If he were running Doom through DOSBox or Basilisk II, then it would be emulation.
                  • W
                    @edmaul69 In that case, I will check tonight. I was under the impression these were direct ports of the original games, but I guess I should have dug deeper.
                    Thanks, working with a RPi and and RetroPie is new and even renewed my hobby interest in tinkering with other OS's and devices.. The last few years have basically been Windows only.. :)
                    Cliff
                      edmaul69 @mediamogul
                      @mediamogul you are right. they are so heavily modified that i think it goes far beyond just a port. So i guess we need to know which port he is using.
                        backstander @wilburburns
                        @wilburburns
                        I would recommend using the Xpad driver instead of the Xboxdrv driver. I don't think the Xboxdrv driver has been updated in a while and doesn't support the current Kernel that RetroPie/Raspbian uses right now. If you want to use the Xboxdrv, then you might need to downgrade your kernel.
                          Yeah, until xboxdrv is updated, it should really only be used in conjunction with non-Xbox controllers for key-mapping purposes.
                          W 1 Reply Last reply Reply Quote 1
                          • W
                            I just checked, and the emulator is zdoom.
                            Cliff
                            • W
                              wilburburns @mediamogul
                              @mediamogul said in Doom and other ports, Controller not working, and XBOX 360 controller problem.:
                              Looks like I've already switched to xpad instead of xboxdrv. But I'm still having the problem.
                              Cliff
                                @wilburburns so for zdoom you need to start with a keyboard or a mouse. inside of zdoom you need to go into option and the controller settings to turn on controllers, but in that same menu before you turn on the controller you need to disable the third and fourth analogs for your controller. Otherwise the controller goes crazy scrolling through the menus. Then there is another controls menu that you set up the buttons in. But you need to still use a keyboard and mouse for that. Once you are set up, moving through the menus with a controller are left and right instead of up and down if i recall.
                                • W
                                  Thanks, I'll try this tonight. Is it safe to assume the other Ported games such as Duke Nukem 3D should have a similar process to configure.
                                  Cliff
