    Correct location for PSX Rearmed Bios? Always selects HLE
    psx biospsx-rearmed
    93 Posts 6 Posters 42.3k Views
      a7mag3ddon
      oh crap, just rebooted and now the joypad is all messed up, only up and down works but its sends the menus left and right.
        a7mag3ddon
        i deleted the input config and every time i set up the pad it skips the right trigger and says NOT DEFINED. no matter how slow or quick it skips.
        anyways i didnt bother with the right trigger went to test the psx again. still same, yellow screen on boot.
          BuZz administrators @a7mag3ddon
          @a7mag3ddon use the xpad driver.
          Something is broken on your setup I guess. I'm out of ideas.
            a7mag3ddon
            I am using the xpad driver, the old one stopped working in V 3.7? or rather kernel 4.1.21 ?
            ill try a remove and reinstall of it.
              @a7mag3ddon xpad driver works fine on new kernels. Check drivers section.
                a7mag3ddon
                I don't know what to say, it was working until we updated the system about an hour ago (the gamepad)
                I think we have both spent too much time on this? I started trying to sort this 8pm yesterday, stopped at 2am, then spent most of the day trying to get it going as well and its now close to 2am again haha.
                for me personally i will just go back to my build from yesterday, copy the bios files to /home/pi/bios and just use the emulator from there instead.
                If i ever rebuilt from scratch again ill be safe knowing that it will work.
                Thanks for all your time, it really is appreciated i know its not easy diagnosing other peoples problems.
                  @a7mag3ddon no probs.
                    ango
                    I know ist old but I had the same problem.
                    It´s working if you rename the bios file to uppecase (SCPH1001.BIN).
                    MajorDangerNineM 1 Reply Last reply Reply Quote 0
                    • MajorDangerNineM
                      MajorDangerNine @ango
                      @ango The RetroPie Documentation on PSX is correct and up-to-date. Your installation of lr-pcsx-rearmed is outdated and should be updated through RetroPie-Setup.
                      https://retropie.org.uk/docs/Updating-RetroPie/
                      SBCGaming | Unofficial RetroPie Discord
                        ango @MajorDangerNine
                        @eckaji : I´ve made a clean 4.4 Install and had the same problem. Only renaming it to uppercase, solved my problem
                        • MajorDangerNineM
                          @ango Yes, because you are on a clean 4.4 install. lr-pcsx-rearmed has been updated since that official image was made.
                            @eckaji said in Correct location for PSX Rearmed Bios? Always selects HLE:
                            "lr.pcx-rearmed" is working and it doesnt matter if the bios filename is lowercase or uppercase.
                            The problem only exist with "pcsx-rearmed"
                            • MajorDangerNineM
                              @ango Oh! My bad. I forgot about the standalone.
                              I believe pcsx-rearmed does only recognize SCPH1001.BIN. Seems like an addition is needed to the documentation.
