    Correct location for PSX Rearmed Bios? Always selects HLE
    psx biospsx-rearmed
    93 Posts 6 Posters 40.1k Views
      a7mag3ddon
      This is the psx confing doesnt seem to be any extra content but i still have 1 blank entry on the list of available emulators.
      lr-pcsx-rearmed = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg %ROM%"
      pcsx-rearmed = "pushd /opt/retropie/emulators/pcsx-rearmed; /opt/retropie/emulators/pcsx-rearmed/pcsx -cdfile %ROM%; popd"
        a7mag3ddon
        Well something is completely knackered now, even though i have removed psxrearmed using retropie menu, my choose default emulator screen not only has the blank line on number 1, but still shows options 2 and 3 as well.
          BuZz administrators @a7mag3ddon
          @a7mag3ddon zip your configs up and I'll take a look.
            a7mag3ddon
            Its ok, i fixed the extra line thing by reinstalling the emulator from the menu, then copying over my backup config folder, still getting the yellow screen of death
            Im going to install a fresh retropie using the image i started with from the downloads section and see what happens, if thats ok then i will put my backup image on from yesterday see if the emulator works (looking for the wrong bios folder) then update from binary, reason being because i originally this afternoon accidentally updated from source before you said to do binary install and that may have broken something ?
            other than the time it takes to reflash my back up its an easy test.
              a7mag3ddon
              Ok were getting somewhere, fresh install of RP then updating update script, then installing psc-rearmed works AND its finding the bios file, albeit just the SCPH1001.BIN one.
              Now to re do my big backup and do the same now.
                a7mag3ddon
                So lets say i get to a point where the old emu was installed, its looking in the wrong place for the bios etc etc etc... whats THE best way to unistall it before updating the script and updating the emulator from binary?
                  @a7mag3ddon the removal lines I put above.
                  I have just tested a fresh install of pcsx-rearmed and all is fine. Must be something else on your system - note I never changed anything that would affect this - I only changed the folder when we launch it so it looks in the right place for a bios (and made the configs live in /opt/retropie/configs/psx/pcsx)
                  Make sure you are testing with a known working playstation game.
                  I can't really advise further as it all works here.
                    a7mag3ddon
                    Ok but they are known working games, they worked on psxrearmed until I updated but using the hle BIOS of course.
                    I don't honestly know either because I've only been messing with the 1 problem since 8 o'clock yesterday nothing else.
                    I'll let you know.
                      a7mag3ddon
                      updated back to my old one, updated by binary... yellow screen of death.
                      oh well.
                        a7mag3ddon
                        Where does the binary you updated get installed, the one inside /opt/retropie/emulators/pcsx-rearmed/ has a file date stamp of 27/11/2016, shouldnt it be todays date?
                          @a7mag3ddon no - the binary hasn't been changed since November. The reason for doing the update is to get the latest configuration parts triggered from retropie-setup.
                            a7mag3ddon
                            ohh..
                            ok, can you tell me what stuff gets downloaded when updating from binary then so i can try and reverse my issue 1 file at a time until i find out which is causing the yellow screen?
                            Im just in the process of unzipping the working image so i can get to the original files.
                            many thanks.
                              @a7mag3ddon the files in /opt/retropie/emulators/pcsx-rearmed/ are downloaded (the new stuff is the symlinks which are created to redirect the configuration)
                                a7mag3ddon
                                That cant possibly be correct, that 1 single change would / should not break the emulator, however.... even though its impossible and shouldn't couldn't it must be true. because that's the only thing i'm doing.
                                Whats the command to run to create that symlink manually, i will test it on my known working image, if it then does break it then at least we will know.
                                  a7mag3ddon
                                  Im sorry to say that (whilst waiting for another SD to write) i tried deleting the symlinked capital letters link and im still getting that yellow screen on boot so something else must be being installed at the same time ?
                                    @a7mag3ddon I have no idea - I would need more information to advise.
                                      a7mag3ddon
                                      ok how about the command to create the symlink to the file in the bios folder? i could try that without updating anything .
                                        a7mag3ddon
                                        I think this is the command
                                        ln -s /home/pi/RetroPie/BIOS/SCPH1001.BIN /opt/retropie/emulators/pcsx-rearmed/bios/SCPH1001.BIN
                                        just testing now
                                          a7mag3ddon
                                          Link created but doesnt work
                                          only way to get this going is to copy a bios file to home/pi/bios/
                                          personally i still think its a bug and the wiki should be updated to reflect it, installing a fresh build isnt really the answer to fixing it. Good for people just starting out but not for people who have already spent time making their retropie from scratch.
                                            @a7mag3ddon it wont work unless your launch line changes directory - which is now fixed - there is no bios bug anymore. It won't work if you just create a symlink on a non updated retropie 4.1 etc.
                                            I have removed/reinstall the latest pcsx-rearmed multiple times and it works fine each time. You have provided me with no information - no configs (as I asked for), no system specs, no idea of what you are launching and so on.
