    scrolling not quite right....mame
    scrollingtearingvertical syncrefresh rate
    5 Posts 2 Posters 2.5k Views
      tonytone
      hi there,
      tried a couple of sideways scrollers.....pac land and wonderboy.
      both have what looks like tearing.
      have tried changing various settings in retroarch....but it just wont go away.
      have tried it on 2 other tv's and its the same on those....
      only interested in mame at the mo so only tested on that.
      setup.
      standard install....just updated everything.
      raspberry pi2
      hdmi cable to dvi adaptor....on a 32" monitor.
      xin-mo controller.
      sanwa sticks and buttons.
      any help would be great :)
      • CapemanC
        Capeman
        2 questions:
        What resolution are you running at and what emulator are you using?
        You can see those settings in the launch command by pressing a button during game load when the square box pops up.
        I find using lr-mame2003 gives the best video performance and setting the resolution to OUTPUT (which makes it match the pi's output) is best.
          tonytone
          thanks for the reply....
          emulator is advmame-0.94.0
          video mode is 1280x768 @ 60hz 15:9 79mhz progressive
          when the pacland is playing....in the menu it says its playing at 288x224s ??
          CapemanC 1 Reply Last reply Reply Quote 0
          • CapemanC
            Capeman @tonytone
            @tonytone I'm not sure how that one works, I only use the libretto emulators, but it sounds like since your not using the native resolution of the tv or an integer scaling, that's probably what's causing your screen tearing. See if it's possible to set the output res from the 1280x768 to either 780p (which is close to what your at already) or 1080p. That might help. The other resolution is the native res of the game, best to leave that alone.
              tonytone
              no m8...you were dead right.
              I've switched to nachos ready made 128gb image and it uses different emulators for different games....
              my 2 faves wonderboy and pac land use ir-mame2003 and the video has no tearing at all.
              just need to swap the button setup and I'm all set....have tried every key on the keyboard and it doesnt seem to have a button to bring the menu up for swapping buttons around like advmame.
              thanks for the help...really appreciate it.
