    Retro arch cores issue
    helpretropie 4.1raspberry pi 3b
    11 Posts 2 Posters 7.4k Views
    • V
      valo
      Re: Core Updater not work.
      Same issue, but from what I can tell the options in retropie 4.1.14 are different, and I can't seem to find the option they mention as a solution. Can someone please point me in the right direction? I'm using a raspberry pi 3 with retro pie version 4.1.14. Thank you for your time
        dankcushions Global Moderator
        same solution: https://github.com/retropie/retropie-setup/wiki/Updating-RetroPie
        what can't you find ?
        • V
          valo
          "Choose "Install Individual Emulators from Binary or Source" and then, choose the core you want to update.
          Core updating via rgui doesn't work in RetroPie."
          I cant find that option anywhere. Ive tried going through each option 1 by 1 and I cant seem to come across it.
          can you tell me which path of options to take to get to it?
            dankcushions Global Moderator @valo
            @valo are you looking in the retroarch menu? it's not in there. the retropie-setup menu is accessed via emulation station > retropie > retropie setup.
            • V
              valo
              No, ive been looking in retropie setup
              Please forgive my ignorance but on bootup i am presented with a horizontal menu of a few consoles(not the full list that i tried installing via setup) and then when i click on retro pie via this menu im presented with a vertical list of options.
              Audio
              Bluetooth
              Configuration Editor
              ES Themes
              File Manager
              Raspi-Config
              Retroarch
              Retroarch Netplay
              Retropie Setup
              Run command editor
              Show IP
              Splashscreens
              WIFI
              I have looked in retropie setup from here, and i do not see any such option. am i missing a step?
                @valo said in Retro arch cores issue:
                Audio
                Bluetooth
                ES Themes
                File Manager
                Raspi-Config
                Retroarch
                Retroarch Netplay
                Retropie Setup
                Run command editor
                Show IP
                Splashscreens
                WIFI
                select the option i've bolded. the rest is as per the wiki.
                • V
                  valo
                  Im sorry, i still dont see any option for "Install Individual Emulators from Binary or Source"
                    follow the documentation page from the top.
                    • V
                      valo
                      I am, I'm sorry. Did the old answer actually mean install update from binarry instead of mentioning emulator? even trying to use the find command, no such option is meantioned in documentation. Im trying to update the retroarch cores, not cores as pie refers to them
                        i don't know how i can answer you anything that isn't in that documentation. manage packages > main (probably) > select core (retroarch ones are prefixed "lr-") > update by binary.
                        • V
                          valo
                          I see, well thank you for your time.
