    nescasediybuildtheme
    1.3k Posts 210 Posters 3.3m Views
    • HexH
      Hex
      @ruckage @TMNTturtlguy I dont know where you guys are from. I am in LA. Are you anywhere near?
      • ruckageR
        ruckage
        And I've just found a bug - typical, I thought I'd checked so carefully.
        Vectrex and Virtual boy display incorrectly in 4x3 mode. No other systems are affected. I'll fix those systems and issue an update shortly.
        @Hex said in Cardboard Mini NES + Nes mini and Famicom mini themes:
        I'm in the UK. I'd have a long way to come and get that drink from @TMNTturtlguy as I think he lives in the US as well :)
          lilbud @ruckage
          @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          http://www.dailymail.co.uk/sciencetech/article-4354872/Bizarre-lets-send-drinks-internet.html
          • HexH
            Hex
            @ruckage Also in the resolutions guide file
            Find the following line:
            	<include>./layouts/1920x1080.xml.xml</include>
            Change 1920x1080 to your desired resolution (valid options are 1920x1080, 1280x720, 1440x1080, 1280x960, 1024x768, 800x600, 640x480, 320x240)
            The twice xml is incorrect 1920x1080.xml.xml
            ruckageR 1 Reply Last reply Reply Quote 1
            • ruckageR
              ruckage @Hex
              Thanks, silly typo. I'll correct it.
              • ruckageR
                ruckage
                Fixed Vectrex and Virtual Boy.
                Corrected the typo in the ## RESOLUTION AND LAYOUTS GUIDE ##.txt
                • FlyingTomahawkF
                  FlyingTomahawk
                  That latest update is for the "NES" theme only?
                  Regarding that drink, add a donation link or your PayPal address so that people can support your work.
                  meleuM ruckageR 2 Replies Last reply Reply Quote 2
                    skj
                    @ruckage Thank you so much for the 4:3 update, my question is, is there any chance you can create a new layout option for 4:3 that does not add the ratings, publisher, etc.... So that the on the left only the box art is shown?
                    • HexH
                      Hex
                      @skj what purpose does that serve?
                      • TMNTturtlguyT
                        TMNTturtlguy
                        @skj if you want something that custom, I suggest you try to figure out how to modify the theme yourself and adjust it how you want it. The changes you have requested do not benefit the theme and add a lot of work and unnesecary maintence issue for @ruckage
                          dankcushions Global Moderator
                          excellent work @ruckage!
                          one tiny issue i noticed: when scrolling through a gamelist, i'm seeing the box art/screenshots shift ~1 pixel to the right. you can actually see them move. not sure if this a theme thing or an ES thing.
                          i'm at 1080p
                          fellegF 1 Reply Last reply Reply Quote 1
                            meleu @FlyingTomahawk
                            @FlyingTomahawk said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                            +1 here.
                            I would like to send him some rupees to encourage him to release that Neo Geo X theme. :-)
                            FlyingTomahawkF 1 Reply Last reply Reply Quote 2
                            • HexH
                              Hex
                              @meleu Indian Rupees?
                              • FlyingTomahawkF
                                FlyingTomahawk @meleu
                                @meleu said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                +1 here.
                                Yep, +1 here too.
                                That NeoGeo/Capcom theme is looking awesome.
                                  meleu @Hex
                                  @Hex Hyrulean rupees:
                                  r
                                  • ruckageR
                                    ruckage @FlyingTomahawk
                                    @skj said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                    Not going to happen, there is only so much I can do, I can't create custom layouts for everyone - I think I already offer plenty of options to fit most peoples needs as it is.
                                    @dankcushions said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                    It may be an ES issue but I'll check. I imagine it has to do with scaling (are the images different sizes?) but it's possible my overly precise values are adding to it. I'll look into it and see if it's anything I can remedy.
                                    Yes only Nes-mini, I will work on getting the famicom-mini theme updated next (it's a bit behind as it doesn't have the new carousel either.)
                                    @FlyingTomahawk @meleu
                                    I've created a paypal donation link for anyone who would like to support my work. I'll put a link below and it's also in my signature.
                                    Donate
                                    FlyingTomahawkF meleuM 2 Replies Last reply Reply Quote 1
                                    • fellegF
                                      felleg @dankcushions
                                      @dankcushions This happens with almost every theme for me, which leads me to believe it's an ES issue indeed.
                                      • FlyingTomahawkF
                                        FlyingTomahawk @ruckage
                                        @ruckage
                                        Have a cold one on me. Enjoy!
                                        • ruckageR
                                          @ruckage
                                          Cheers, that's very generous of you :)
                                          FlyingTomahawkF 1 Reply Last reply Reply Quote 0
                                          • FlyingTomahawkF
                                            @ruckage
                                            My pleasure.
                                            I know how much time and work is behind such a theme so every beer you get is well deserved. If everyone donates a little here and a little there it will be worth it for you and more motivating.
                                            And there is more, lot more where that came from as soon the NeoGeo/Capcom theme is released. ;-)
