    nescasediybuildtheme
    1.3k Posts 210 Posters 3.3m Views
      Jara
      Hi.
      First of all, I want to thank you for this amazing theme. I enjoy it a lot.
      I know you want to finish it on your own. You have your own style and if other people start contributing it will probably show in the final version. Also it's fun to do it.
      To the users: If you're like me and don't like having a black space for a system in the to-do list, you can use this hastly made Dreamcast system images I made until rukage releases the official one. I made ones for Sega32X and PC (dosbox) but they are so horrible that I won't share them. Thrown together in a few minutes with almost no experience in Photoshop (recently transferring from Paint Shop Pro).
      This is not official and it doesn't have ruckage's support. It's meant to be used temporarily until the official pack comes out. You can use it or modify it anyway you want to as long as you're clear on those points.
      http://www79.zippyshare.com/v/S8KnmnLE/file.html
      If ruckage for some reason wants me to remove it, I'll do it.
      Edit: I just read now that the official version will probably be released this week. At least I'll know how far I was from some quality theme. lol.
      I guess I'll leave the link just for the fun of it.
      • TMNTturtlguyT
        TMNTturtlguy
        @ruckage i tried.......sorry man
        ruckageR 1 Reply Last reply Reply Quote 5
        • ruckageR
          ruckage @TMNTturtlguy
          @tmntturtlguy
          groundhogday
          facepalm
          I'm going to bookmark your previous post and just paste it as a response in the future :D
          • F
            FabianVG @mattmanforever
            @mattmanforever , ha, I made it awhile ago i just finally got around to posting it,. Thanks!
            • F
              FabianVG
              Sorry about bringing this up again, I'll just sit right back down and wait till all the goodies are done.
              • E
                elahrairah
                @RUCKAGE
                Nice theme. For me the best so far. If you find the time it would be great to add "Favorites".
                For the people who don't know you can select games from any system and it to the favorites menu in ES.
                Thanks bro
                • ruckageR
                  ruckage @elahrairah
                  @elahrairah
                  Hi. Already being worked on - see this post from last week: https://retropie.org.uk/forum/topic/8391/cardboard-mini-nes-nes-mini-and-famicom-mini-themes/896
                  • zippizZ
                    zippiz
                    I tried to install this theme two times now, but all I get is white background and text, no pictures. Downloaded and installed twice, same thing... using it on a Pi Zero w, any advice?
                    • ruckageR
                      ruckage @FabianVG
                      @fabianvg said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                      Should have checked the update notes in the readme or looked in the SNES theme folder ;) - the alternate SNES icon has been included since the update 20 days ago. I'll let you off though, I guess most people don't see the readme as they install the theme through retropie.
                      I wonder if it would be possible to display the update notes when you install/update a theme.
                      • ruckageR
                        ruckage @zippiz
                        @zippiz said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                        You're not using the latest version of EmulationStation. This theme require the latest version to work so you will need to update it from source.
                        To do this in Retropie go to the retropie/config menu and select the following:
                        1. Retropie Setup
                        2. Manage Packages
                        3. Manage Core Package
                        4. EmulationStation
                        5. Update From Source
                        It will take a little while to compile, once it's finished you will have the latest version of ES. Restart the system and the theme should work.
                        zippizZ HankolaH 3 Replies Last reply Reply Quote 0
                        • zippizZ
                          zippiz @ruckage
                          @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                          1. Retropie Setup
                          2. Manage Packages
                          4. EmulationStation
                          Thanks, you are right I was not.... actually I did not dare to install it, I have been working on a project and needed the gamecon-driver to work and I belive there is a bug or something... anyhow, I was afraid to update, before I could get the gamecon-driver to work...
                          Did not get it to work, so had to do a (way to big) workaround, so I will give this a try now and cross my fingers =)
                          • ruckageR
                            ruckage @zippiz
                            @zippiz
                            Updating just emulationstation on it's own shouldn't affect anything else so you should be okay.
                            • zippizZ
                              zippiz @ruckage
                              Well, its been going for more than half an hour maybe even close to a hour and is 29% now, thats more than a "little while" ;) Haha, I was thinking maybe it would take 15min or so...still so new at this.
                              Why would the theme need this btw?
                              ruckageR J 2 Replies Last reply Reply Quote 0
                              • ruckageR
                                ruckage @zippiz
                                @zippiz
                                It' probably slow because you're compiling on a pizero which isn't that fast - it doesn't take too long on rpi3.
                                EmulationStation has had lots of changes and improvements the last few months and my theme takes advantage of many of them - the downside being that as these features aren't in the older versions of ES the theme won't work in them.
                                  jcook84 @zippiz
                                  @zippiz
                                  pi zero takes forever to compile anything
                                  (BTW, looking forward to your clone NES in a controller "how-to" video. If postal tracking is to be believed, I should have mine tomorrow!)
                                  • F
                                    FabianVG @ruckage
                                    @ruckage thanks man, I'm offering my sincerest apology, I haven't updated in months. Like I said I'll just wait for everything gif to come and I'll be sure to donate to support a great theme.
                                      mahcneto
                                      Thank you for making this awesome theme :)
                                      I can't update ES at all. Whenever I try it says "Could not install package(s): libvlc-dev libvlccore-dev vlc-nox"
                                      Is anyone else having the same issue?
                                      • HyruleslinkH
                                        Hyruleslink
                                        Hi there. Great theme! This is probably the best RetroPie theme I have seen yet! I really like the touches you made to the games menu for Gameboy and Virtualboy. I see that there is an option to change the carousel icon to the US SNES logo. I saw that all I have to do is change the name, but where and how do I do that?
                                        • ruckageR
                                          ruckage @mahcneto
                                          @mahcneto
                                          Sorry, I don't know what could be causing that. As It's not a theme specific issue you would be better off asking the question in the Help and Support section of the forum where more people will see it.
                                          • ruckageR
                                            ruckage @Hyruleslink
                                            @hyruleslink said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                            Hi.
                                            There are 2 ways to do it.
                                            Option 1:
                                            Go to the nes-mini theme folder.
                                            Find the SNES folder within it.
                                            Open theme.xml in a text editor
                                            Change this line:
                                            <path>./carousel_logo.png</path>
                                            to
                                            <path>./carousel_logo_US.png</path>
                                            Save the file.
                                            Restart EmulationStation
                                            Option 2:
                                            Rename: carousel_logo.png to carousel_logo_EUR.png
                                            Rename: carousel_logo_US.png to carousel_logo.png
                                            E HyruleslinkH 2 Replies Last reply Reply Quote 2
