    nescasediybuildtheme
    1.3k Posts 210 Posters 3.6m Views
      dustloop
      I have a version of this theme from ETA PRIMES channel.
      The full carousel version is unreal and I think will be my number 1 theme to use. I cannot wait for the release. It is phenomenal!
        chileno77
        great!!!! thankyou..
        but... do not have atari800 layout??
          KillerQ @ruckage
          @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          I've finally finished all the icons and made the carousel images - and it works :D (on windows at least - will try the rpi next).
          Here's a video of it in action.
          Outstanding! It's like the Pixel Theme's little brother. Haha.
          Even if video snap support isn't added, I can still see this becoming my daily-driver!!
          Great work!!
          • ruckageR
            ruckage
            Sorry for the lack of replies.
            I've tested the new version of the Nes mini theme on retropie and it seems to be working well, the github version has been updated and it should now be available to download through the 'Retropie Theme installer'.
            The famicom mini theme hasn't been updated with the new features yet but will be done next.
            Changes
            The carousel has been themed and pixel art icon has been drawn for every system. To see see the updated carousel you will need to update to the very latest version of Retropie via the Retropie setup script https://github.com/retropie/retropie-setup/wiki/updating-retropie
            On older versions of retropie the carousel will revert to the old style.
            6 new systems have been added Daphne,PSP, SG-1000, Atari Lynx, Ports, and Virtual Boy.
            'OUR BOX ART IS IN ANOTHER CASTLE' image has been reduced in size to hopefully prevent it showing behind some artwork and has been completely removed from the config screen.
            J 1 Reply Last reply Reply Quote 2
            • CodeDrawerC
              CodeDrawer
              Hey @ruckage what type of retropie are you using? Is it on the raspberry pi?
              N64 emulation is the next step :)
                kbronctjr
                hi, your theme is awesome!. Could you add sega32x and Steam?
                Also, the image displayed for a game is small you still can see the image that is displayed when there is no art for that game. Could you fix that too?
                Thank you very much!
                • ruckageR
                  ruckage @CodeDrawer
                  @CodeDrawer said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                  Yes, it's raspberry pi.
                  @kbronctjr said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                  Hi, those sytems are on the todo list but I can't say exactly when they will be done
                  Well I've already reduced that image in size in this update. What artwork are you using where this is still an issue - can you post an example so that I can see the problem? A screenshot of the problem and the actual boxart/preview image file would be very helpful. Thanks.
                    kbronctjr @ruckage
                    @ruckage Sorry I can't take a picture right now.
                    I'm using this scraper
                    https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/releases
                    and the images that i'm generating are like this:
                    https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/raw/master/Images/Presentation/MIX/Super Mario All-Stars (Europe)-image.png
                    with that type of image I can see the lower part of the character (for other games the boxart is smaller)
                    • CodeDrawerC
                      CodeDrawer
                      @ruckage So you can play DS on the pi?
                        A Former User @CodeDrawer
                        @CodeDrawer Yeah, you can using lr-desume. There used to be a version of DraStic for the Pi, but something happened so you can't use it.
                        I heard that desume isn't the best on raspberry pis, even overclocked.
                        • ruckageR
                          ruckage @kbronctjr
                          Ah, I see. The theme was only really designed for displaying the standard single images that are usually scraped. There isn't really much else I can do about that short of removing the 'mising art' image completely but I personally like to have it. In your case you can just replace the 'missing.png' file found in the layouts folder with a blank image (transparent png) to remove it completelly.
                          K 1 Reply Last reply Reply Quote 1
                            jcook84 @ruckage
                            @ruckage
                            I-It's beautiful! Completely worth the wait! THANK YOU!!!
                              A Former User
                              I have updated to the newest Retropie but am still not getting the newest carousel. I updated the RetroPie Install Script(v4.2.3) and told it to update all installed packages and nothing.
                              Anyone have any advice? Am I missing something obvious?
                              M ruckageR 2 Replies Last reply Reply Quote 0
                                myG0sh
                                Thank you so so much for this beautiful theme!! I even can download it via the retropie-setup so a bunch of non-tech-friends of mine already managed to install it!
                                With the first "thank you for the update, dear programming and designing god", it always comes along an annyoing "but..."
                                so my "but" looks as follows:
                                i changed the overscan so the black border is the monitor itself. Im using a Naviskauto CH1004S car monitor with a resolution of 1024x600 so its 16:9
                                I only experience this problem with composite out, hdmi works great. The reason why i ask here is, maybe someone knows what to do in combination with this theme because other themes look the same, no matter composito video out or hdmi out
                                edit:
                                i already tried:
                                • all sdtv_mode, sdtv_aspect and framebuffer_width/height settings in /boot/config.txt
                                • resizing the system_art.png in theme folder
                                nothing helps
                                  myG0sh @A Former User
                                  @LiveFastCyYoung said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                  you need to download the "official" version called nes-mini. You find it under Retropie-setup -> Configuration/tools -> esthemes -> install nes-mini
                                    A Former User @myG0sh
                                    @myG0sh Yeah I did that. Still nothing.
                                    Attempting to update RetroPie from sources as opposed to binaries and see if it helps. ¯_(ツ)_/¯
                                    • ruckageR
                                      ruckage @A Former User
                                      Hi, that should work. Probably a silly question but you did update the theme as well?
                                      Failing that try uninstalling the theme, restart retropie and then install the theme again.
                                      • ruckageR
                                        ruckage @myG0sh
                                        @myG0sh said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                        Hi,
                                        First, the theme is only really designed to work at 1080p so unfortunately it will never look right at other resolutions.
                                        From looking at the picture it looks like that is a 480i 4:3 image that is being displayed, this would make sense as I believe that is the best you can get through composite (no HD resolutions), this would explain why nothing is lining up correctly (you can see the background is hanging of the edge of the screen).
                                        I am planning a 4:3 version but I still can't guaratee that it will display correctly on that screen through composite.
                                          myG0sh @ruckage
                                          @ruckage
                                          thanks for the quick reply. So would maybe a HDMI-to-Composite Adapter be my solution for this specific problem?
                                            A Former User @ruckage
                                            @ruckage The theme definitely updated. I have the new, smaller missing box art image.
                                            Still missing the new carousel though.
                                            Also noticed the folder icons for folders starting with # is missing now. Did that change in this version?
