    nescasediybuildtheme
    1.3k Posts 210 Posters 3.6m Views
      mediamogul Global Moderator @ruckage
      @ruckage
      They actually appear in the order they are defined in the es_systems.cfg (which you are correct is ordered alphabetically by default). To have a system appear first you just need to move it to the top in es_systems.cfg.
      Yeah, I've toyed with the idea of creating my own order a few times, but I always land on it more trouble than it's worth.
      Still don't really get why Kodi needs it's own section personally
      I do it for the same reason @DigitalMonkey does; just because it looks nice. However, there's no great reason other than that and personally, It wouldn't bother me to keep it in the 'Ports' menu.
        Syhles @lilbud
        @lilbud
        Are you talking about the black pocket logo? Right now there's three on screen and I'm using a phone.... and the only that seems off is the pocket logo. Are you using svgs or pngs for the logos?
        Also that theme looks so clean I'm looking forward to a download.
        • ruckageR
          ruckage @lilbud
          @lilbud said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          @ruckage So my theme shares the carousel idea with your theme, (Big square icons instead of logos.) Like this one,
          So I would use this code,
          • <carousel name="systemcarousel">
            <type>horizontal</type>
            <pos>0 0</pos> <!-- Currently only y value is used -->
            <size>1 .354 </size> <!-- currently only height value is used -->
            <color>00000060</color>
            <logoScale>1</logoScale>
            <logoSize>0.364 0.354</logoSize>
            <maxLogoCount>5</maxLogoCount>
            </carousel>
            But the logo would appear stretched and squashed
          First, you only have one value in the <size> tag - that will cause a problem.
          Also, you've commented:
          That isn't true (unless the windows version is totally different but I believe it's based on the same source as retropie.)
          Does the same issue occur on both windows ES and retropie ES?
          What resolution / aspect ratio are you using?
          • DigitalMonkeyD
            DigitalMonkey Banned @mediamogul
            @mediamogul said in Cardboard Mini NES + Nes mini and Famicom mini themes:
            @DigitalMonkey
            Plus adding it to the main menu makes it the first 'system' you see after booting up.
            By default, the systems appear alphabetically. Anyone who has any systems before 'K' will still have to scroll to it. I have 39 systems in the carousel with Kodi being one, so it takes me quite a bit to get there.
            Strange.
            On Mine its the default (first one you see at start up). Didnt do anything special just this - ['Kodi as its own system'] https://github.com/RetroPie/RetroPie-Setup/wiki/KODI
            Have all the console systems installed too.
            • ruckageR
              ruckage @DigitalMonkey
              @DigitalMonkey said in Cardboard Mini NES + Nes mini and Famicom mini themes:
              @DigitalMonkey
              Strange.
              See my post above. When you added the system to the Es-systems.cfg you must have added it to the top. Systems appear in the same order that they are defined in this file.
                lilbud @ruckage
                @ruckage A few things
                It is actually x = 1 y =0.354, the formatting looks weird.
                This isn't the actual code, just what I remember of it since it didn't save.
                16:9 aspect, running on the pi.
                Here's a hint,
                This theme is like the flat theme, but i've SWITCHED some things up :)
                S ruckageR 2 Replies Last reply Reply Quote 1
                  Syhles @lilbud
                  @lilbud
                  I'd make your <size> field larger than your <logoSize> field personally.
                  • ruckageR
                    ruckage @lilbud
                    Here's a hint,
                    Ah, I see - didn't notice the space (for clarity I would put 0.354). Not sure why they would appear stretched. Test the theme on the windows version of ES to rule out any problems with retropie (es_toolkit v1.1 by @mattrixk).
                    If you don't mind uploading it somewhere, even temporarily, I would be happy to check it and see if I can fix the problem for you.)
                    lilbudL 1 Reply Last reply Reply Quote 1
                      lilbud @ruckage
                      @ruckage Okay, I fixed the scaling issue, but I've run into a new one.
                      Is there a way to have a selector scroll on the carousel instead of the logos scroll.
                      (I guess I can't keep this secret.)
                      The theme I am making is a Nintendo Switch theme for ES
                      I want the carousel to move like this:
                      ruckageR B 2 Replies Last reply Reply Quote 0
                      • ruckageR
                        ruckage @lilbud
                        No, not possible I'm afraid.
                          bjose2345 @lilbud
                          @lilbud There is someone doing this in the AM forums,
                          http://forum.attractmode.org/index.php?topic=1615.0
                          • ruckageR
                            ruckage
                            I've finally finished all the icons and made the carousel images - and it works :D (on windows at least - will try the rpi next).
                            Here's a video of it in action.
                            S herb_fargusH K 3 Replies Last reply Reply Quote 12
                              Syhles @ruckage
                              @ruckage
                              Everything looked really clean.
                              • herb_fargusH
                                herb_fargus administrators @ruckage
                                @ruckage even my wife is impressed with this and she isn't much for gaming
                                S 1 Reply Last reply Reply Quote 5
                                  Syhles @herb_fargus
                                  @herb_fargus
                                  Ruckage has won, he achieved the coveted wife seal of approval.
                                  TMNTturtlguyT ruckageR 2 Replies Last reply Reply Quote 4
                                  • TMNTturtlguyT
                                    TMNTturtlguy
                                    Wow! This is super cool!
                                    • TMNTturtlguyT
                                      TMNTturtlguy @Syhles
                                      @Syhles I didn't even know that was possible! Congrats @ruckage that sure beats the "oh cool" with an eye roll I usually get!
                                      • ruckageR
                                        ruckage @Syhles
                                        @Syhles said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                        @herb_fargus
                                        :D
                                        Is there some kind trophy I receive to commemorate this?
                                        S 1 Reply Last reply Reply Quote 3
                                          Syhles @ruckage
                                          @ruckage
                                          Herb should be in charge of the trophy his wife gave the stamp of approval. Lol
                                            DragonCrystal
                                            I cant wait for it when the full thing is ready for the raspberry pi, I'll download it in a heart beat!
