    nescasediybuildtheme
    1.3k Posts 210 Posters 3.2m Views
    • ruckageR
      ruckage @dvelop
      @dvelop said in Cardboard Mini NES + Nes mini and Famicom mini themes:
      @ruckage Now favourites has rolled out into the main Emulation Station branch are you planning on supporting that feature?
      I will be looking into it.
      @Syhles said in Cardboard Mini NES + Nes mini and Famicom mini themes:
      @ruckage
      Theme variables are now available as well, you should be able to cut down on some code with it.
      Not sure I'll be taking advantage of that just yet as I only last week re-worked huge chunks of the theme when I added 4x3 support (is that the 4th time I've re-worked large parts of the theme now?) Not sure I can face re-working the code again so soon :( .
      It's a great addition though and I plan to use it in the future. I can see that being an easy way for me to offer alternate icon sets which was mentioned just the other day.
        Syhles @ruckage
        @ruckage
        Makes sense I had to rewrite my personal use theme around 3 times and now I need to rewrite again for theme variables and when the theme restructuring is done I'll probably rewrite it again.
        You should just work at your own pace.
        Also don't forget it isn't just favorites that was added we also received all-games and recent-games.
        • ruckageR
          ruckage @Syhles
          @ruckage
          Yeah, I'm actually reading the topic about it now. Just need to decide on the icons and the background for these new systems (I'll probably use a shared background between them with different colours for each).
            Syhles @ruckage
            @ruckage
            I imagine it'll cut down on time and work which I have no issues with. lol
            Though it may look nice if did something similar to Neo Geo pocket or the wonderswan (whichever has the blue dot background) instead of dots use stars possibly of varying sizes.
            • ruckageR
              ruckage @Syhles
              @ruckage
              Well it won't cut down on work dramatically as the icons will still be time consuming to draw, it's more to give an indication that they a related to one another.
                prosthetichead
                thank you for getting the 4:3 layout working! the theme looks amazing on my arcade table.
                I use the Auto-Favorites menu so I thought I would make a system for it I just cloned the Nes layout and added some edits.
                  PetroRie
                  IMHO the cardboard case looks waaaay better compared to the NES mini released by Nintendo.
                    jonny555
                    Hi there
                    I'd like to mod the gamelist view to look like the nes classic
                    Can the the gamelist be horizontal using carousel like system menu
                    Many thanks
                    I can only see the the gamelist is a text view
                    lostlessL ruckageR 2 Replies Last reply Reply Quote 0
                    • lostlessL
                      lostless @jonny555
                      @jonny555 can't be done. It's a limitation of the current emulation station.
                      • ruckageR
                        ruckage @jonny555
                        @jonny555 said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                        Hi there
                        Many thanks
                        Not possible otherwise I would have done that. A text list is the only option.
                          jonny555
                          Lol i did think that when i asked
                          Im pretty sure it could be possible with abit of trickery is gridview not working anymore or some kind of mask like this and somehow using one title at top and using boxart below
                          • ruckageR
                            ruckage @jonny555
                            No, it's completely impossible with the current version of ES. If it had been possible in any way I would have done it. Grid view would have kind of worked but that was only in an experimental build, never official, and quite buggy - there is no gridview support in the current version of ES. You can only display art for the currently selected game so there is no way around it.
                            If the carousel is ever made available in the gamelist view then I will be the first to take advantage of it for this theme.
                              jonny555
                              It's a crying shame as this would finish of my pi zero nes classic build
                              • ruckageR
                                ruckage @jonny555
                                Well it still can, it just won't be identical to the real NES classic - it will still have a similar look and feel though. You have to remember retropie and all all the software and themes that go with it are free and maintained by volunteers - you aren't always going to get exactly what you want.
                                If it bothers you that much though then perhaps EmulationStation isn't for you and you should try 'Attract Mode' instead (though I doubt that will run well on a pi zero) or just leave it as an actual NES classic for true authenticity (I wouldn't have put a Pi in one if I had been lucky enough to get one).
                                  jonny555
                                  Oh no don't get me wrong im not ungrateful im a skinner myself in hyperspin attract mode coinops i know what kind of time goes into this
                                  It can take over you life lol
                                  This is not a real nes classic it's a very good clone as the internals ie board is not Nintendo original no way id put a pi zero in a real one £50 from aliexpress
                                    mattmanforever
                                    I prefer this game interface over NES Mini's. Love having the game info on the right side. And the NES Mini UI is designed for a system with a limited amount of games anyway.
                                    • ruckageR
                                      ruckage @jonny555
                                      Glad you haven't destroyed a real nes classic. That does look a pretty good fake as it looks like it even has the same wiimote style ports (the only thing off is the logo looks a bit wonky.)
                                        jonny555 @ruckage
                                        @ruckage
                                        Hi yes it is very good clone nearly had me fooled logos are slightly wonky .... it has wii ports to even the box is close apparently its the same factory's who made for Nintendo as there allowed to do this according to famicomworld.com ui is same but its only like 280p the internal board is different some allwinner clone but yes if you looking for a nice 95% match case and controller its worth it :)😁
                                        More pics here and info good fine if you want to complete with pi zero or 3 they will both fit
                                        http://www.famicomworld.com/forum/index.php?topic=13636.45
                                        • E
                                          eisnerguy1
                                          ruckage, I just registered to say how awesome this theme is. I'm getting all of the stuff needed for my retropie setup tomorrow and can't wait to have this theme up & running. Just to clarify, is the carousel view not available anymore?
                                          • ruckageR
                                            ruckage @eisnerguy1
                                            @eisnerguy1
                                            Hi. The carousel will be as you see in the youtube video for the system view - just make sure you have the very latest version of EmulationStation (you will need to update it once you have Retropie up and running). It will look like the images below.
                                            System select view.
                                            Game List view.
                                            E 1 Reply Last reply Reply Quote 1
