    nescasediybuildtheme
    1.3k Posts 210 Posters 2.7m Views
    • MrJordaaanyM
      MrJordaaany
      Hi, have you added 32X or Game and watch systems yet? Awesome theme by the way, one of my favorites to use.
      • greekmanxG
        greekmanx
        no 32x yet only one I have been waiting on myself
        • E
          eisnerguy1 @ruckage
          @ruckage Thanks! Got it all set up! Just trying to get my SNES30 to connect via Bluetooth now >_<
            roci
            Awesome theme!! Love it :)
            1 thing though I saw that moonlight was missing from your system list. Will it be okay if I make it for you and upload it here for others? If you like it you may add it to the theme :)
            Your choice
            Greetings!
            • ruckageR
              ruckage @roci
              @roci said in Cardboard Mini NES + Nes mini and Famicom mini themes:
              Your choice
              Greetings!
              Thanks, but I'd rather do all the systems myself so that everything looks as I want it to. Steam is already on my to do list (see first post in this topic).
              • E
                EvilDindon
                Hey,
                I love the simplicity of your theme !
                Will release soon my own retropie preloaded image with your theme if you don't mind ?
                I have some work before though, because I want to create my own png's instead of low quality boxarts.
                This is what my custom art will look like (have to create one for each game)
                • E
                  EvilDindon
                  ruckage, I have a question regarding the png's i want to create.
                  What is the optimum size for them, If I don't want ES to resize them and lose quality ?
                  I found myself that it was 464x464 isn't it ?
                    roci @ruckage
                    @ruckage aah sorry didn't see it, was looking for the word moonlight :)
                    • ruckageR
                      ruckage @EvilDindon
                      @evildindon said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                      Hey,
                      Your screenshots look nice, I like them. You aren't doing that by hand though are you? It would take forever. You should either code something to compose those images (I often do that myselft). Or universal XMl Scraper could probably achieve a similar effect.
                      And yes, the image area is 464x464 at 1080p.
                      I'm a little concerned by you saying that you are releasing a pre-loaded retropie image. I'm assuming by that you mean an image containing roms - that's frowned upon around here.
                      • HexH
                        Hex
                        @ruckage I dont want to come out as nagging you but I would really appreciate DOS system support. My setup has 4 systems, Dos, GB, NES and SNES. The theme looks incomplete as dos in always on carousel as Black box.
                        ruckageR E 2 Replies Last reply Reply Quote 1
                        • ruckageR
                          ruckage @Hex
                          @hex
                          It will probably be in the next batch but can't say when exactly - I have quite a few things I'm working on at the moment and so my time is divided.
                          • E
                            eisnerguy1 @Hex
                            @hex I actually made some simple custom stuff for dosbox yesterday.
                            https://www.mediafire.com/?j7ea21pi12o1h3j
                            Still need to tweak some of the colors. @ruckage, your version will probably be much better than my attempt :P
                            • E
                              EvilDindon @ruckage
                              @ruckage
                              Thanks for reply.
                              No, an image containing only artworks !
                              I can create batches in paint shop pro for that, yes.
                              Universal XML scraper is not bad but you can't really do what you want.
                              • E
                                EvilDindon
                                Oh btw, will your theme support the new ES features (favorites, all games, last played, etc.) ?
                                ruckageR 1 Reply Last reply Reply Quote 1
                                • E
                                  EvilDindon
                                  Testing out some other layouts :
                                  The solution for taller sprites : cut-out.
                                  • ruckageR
                                    ruckage @EvilDindon
                                    Those layouts look good, though it looks like it would be a very manual process as you'd have to position the screenshots by hand so that the characters are the focus, are you planning on doing all games for all systems or just select games?
                                    Yes, I've been working on those amongst other things. Here are the icons for 'Favourite', and 'Last Played' as proof that I am actually still working on the theme ;).
                                    1 Reply Last reply Reply Quote 7
                                    • alexribeirodesaA
                                      alexribeirodesa
                                      loved the theme, I'm using it ^^
                                      but, I didn't have found the MSX stuff, so, made it :)
                                      as I used the hotbit as a kid, I used it as reference for the icon ^^
                                      MSX Icon
                                      https://imgur.com/a/nFS7z
                                      @alexribeirodesa
                                      B 1 Reply Last reply Reply Quote 2
                                        bjose2345 @alexribeirodesa
                                        @alexribeirodesa Really nice the MSX logo, love it. Many thanks dude :)
                                        alexribeirodesaA 1 Reply Last reply Reply Quote 2
                                        • alexribeirodesaA
                                          alexribeirodesa
                                          hello again :)
                                          today I played some MSX, and I really loved icon :D
                                          so, when I'm was playing my brother said "so, we can add some old DOS game too :)" but, as the same the MSX, I didn't have found a DOS, DOSBox or anything like that icon too :(
                                          like the MSX, I used some reference from my old computer, for the monitor I used the Samsung Syncmaster 3 as reference, this guy was my very first color monitor for my PC too ^^
                                          I had some questions about the logo, but I chose to use the IBM as it is the IBM PC platform, not DOSBox, MS DOS or PC DOS. Even RetroPie wiki uses the IBM logo xD
                                          so, made it too ^^ hope you guys likes :)
                                          IBM PC
                                          you guys can get all the stuff at https://imgur.com/a/nFS7z
                                          thanks ^^
                                          @alexribeirodesa
                                          E 1 Reply Last reply Reply Quote 3
                                          • alexribeirodesaA
                                            alexribeirodesa @bjose2345
                                            @bjose2345 thanks \o
                                            I didn't draw for so many year, I'm was just codding, codding and codding :'(
                                            I had so much fun drawing it ^^ I think I'll draw more soon :D
                                            @alexribeirodesa
