    nescasediybuildtheme
    1.3k Posts 210 Posters 2.8m Views
    • zippizZ
      zippiz @ruckage
      @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
      You're not using the latest version of EmulationStation. This theme require the latest version to work so you will need to update it from source.
      To do this in Retropie go to the retropie/config menu and select the following:
      1. Retropie Setup
      2. Manage Packages
      3. Manage Core Package
      4. EmulationStation
      5. Update From Source
        It will take a little while to compile, once it's finished you will have the latest version of ES. Restart the system and the theme should work.
      Thanks, you are right I was not.... actually I did not dare to install it, I have been working on a project and needed the gamecon-driver to work and I belive there is a bug or something... anyhow, I was afraid to update, before I could get the gamecon-driver to work...
      Did not get it to work, so had to do a (way to big) workaround, so I will give this a try now and cross my fingers =)
      • ruckageR
        ruckage @zippiz
        @zippiz
        Updating just emulationstation on it's own shouldn't affect anything else so you should be okay.
        • zippizZ
          zippiz @ruckage
          Well, its been going for more than half an hour maybe even close to a hour and is 29% now, thats more than a "little while" ;) Haha, I was thinking maybe it would take 15min or so...still so new at this.
          Why would the theme need this btw?
          ruckageR J 2 Replies Last reply Reply Quote 0
          • ruckageR
            ruckage @zippiz
            @zippiz
            It' probably slow because you're compiling on a pizero which isn't that fast - it doesn't take too long on rpi3.
            EmulationStation has had lots of changes and improvements the last few months and my theme takes advantage of many of them - the downside being that as these features aren't in the older versions of ES the theme won't work in them.
              jcook84 @zippiz
              @zippiz
              pi zero takes forever to compile anything
              (BTW, looking forward to your clone NES in a controller "how-to" video. If postal tracking is to be believed, I should have mine tomorrow!)
              • F
                FabianVG @ruckage
                @ruckage thanks man, I'm offering my sincerest apology, I haven't updated in months. Like I said I'll just wait for everything gif to come and I'll be sure to donate to support a great theme.
                  mahcneto
                  Thank you for making this awesome theme :)
                  I can't update ES at all. Whenever I try it says "Could not install package(s): libvlc-dev libvlccore-dev vlc-nox"
                  Is anyone else having the same issue?
                  • HyruleslinkH
                    Hyruleslink
                    Hi there. Great theme! This is probably the best RetroPie theme I have seen yet! I really like the touches you made to the games menu for Gameboy and Virtualboy. I see that there is an option to change the carousel icon to the US SNES logo. I saw that all I have to do is change the name, but where and how do I do that?
                    • ruckageR
                      ruckage @mahcneto
                      @mahcneto
                      Sorry, I don't know what could be causing that. As It's not a theme specific issue you would be better off asking the question in the Help and Support section of the forum where more people will see it.
                      • ruckageR
                        ruckage @Hyruleslink
                        @hyruleslink said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                        Hi.
                        There are 2 ways to do it.
                        Option 1:
                        Go to the nes-mini theme folder.
                        Find the SNES folder within it.
                        Open theme.xml in a text editor
                        Change this line:
                        <path>./carousel_logo.png</path>
                        to
                        <path>./carousel_logo_US.png</path>
                        Save the file.
                        Restart EmulationStation
                        Option 2:
                        Rename: carousel_logo.png to carousel_logo_EUR.png
                        Rename: carousel_logo_US.png to carousel_logo.png
                        E HyruleslinkH 2 Replies Last reply Reply Quote 2
                        • E
                          elahrairah @ruckage
                          @ruckage hey brah, any idea when you will have a new update for this excellent theme?
                          • HyruleslinkH
                            Hyruleslink @ruckage
                            @ruckage Thanks that seems easy enough. How do I find the nes-mini folder? In the File Manager?
                            • E
                              elahrairah @Hyruleslink
                              @hyruleslink use winscp to get into your pi and go to /etc/pi/emulationstation/themes folder.
                              There you'll find the nes-mini theme with all systems.
                              • PokeEngineerP
                                PokeEngineer @ruckage
                                @ruckage
                                In your theme, did you make the "NESCyrillic_gamelist.ttf" font yourself or did you get it from somewhere? If you did get it from somewhere, where might that be? I'm asking because I noticed it was different from the regular NES Cyrillic font.
                                Don't sweat it.
                                  TitQuentin
                                  Hi! Thanks for this great theme!
                                  But it's possible to remove number "played" or leave it to 0? I dislike this ....
                                  I try to edit xml file but I don't found...
                                  Thanx for help!
                                  • ruckageR
                                    ruckage @PokeEngineer
                                    @pokeengineer said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                    @ruckage
                                    Sorry for the late reply. The gamelist font is a modified version of a font I found on bitfontmaker2, I changed several characters and also the baseline height (necessary at the time to make it work correctly in this theme).
                                    PokeEngineerP 1 Reply Last reply Reply Quote 0
                                    • ruckageR
                                      ruckage @TitQuentin
                                      @titquentin said in Cardboard Mini NES + Nes mini and Famicom mini themes:
                                      Thanx for help!
                                      Not easily I'm afraid and if you did you would just have a blank space instead. Does it really make any difference it being there?
                                      • PokeEngineerP
                                        @ruckage
                                        Thanks. :)
                                        Don't sweat it.
                                        • TheWanderingRiotT
                                          TheWanderingRiot
                                          @ruckage
                                          Greetings ruck, hope I don't sound like a bother with this since you're really busy tweaking with this amazing theme, but do you think you could curiously do the Sega Mark III, Capcom Play System, and Megadrive Japan, even if the latter two is just a logo work to your previous stuff if you can please?
                                          I'll do the honor of donating to your beerfund right away if it pops up on your to-do list. I look really forward and patiently to see how this awesome gem shapes up! :)
                                          • ruckageR
                                            ruckage @TheWanderingRiot
                                            @thewanderingriot
                                            I've added them to the list, however CPS and Megadrive Japan will be lower priority as they are already supported in some form. Having said that as Megadrive Japan will only need a different logo that may be done sooner.
