    nescasediybuildtheme
    1.3k Posts 210 Posters 3.4m Views
    • SgtJimmyRustlesS
      SgtJimmyRustles
      @ruckage See what I mean here? The text isn't centered.
      Check out /r/SBCGaming for Retropie, Recalbox, OGST (Odroid) talk and more!
      http://www.reddit.com/r/sbcgaming
      Hop on the Dicscord as well and chat about all things Retropie (or recalbox, lakka, etc)
      https://discord.gg/JdXc6nx
      Check out our Podcast!
      PokeEngineerP 1 Reply Last reply Reply Quote 0
      • PokeEngineerP
        PokeEngineer @SgtJimmyRustles
        This post is deleted!
        • ruckageR
          ruckage @SgtJimmyRustles
          @sgtjimmyrustles said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          @ruckage said in Cardboard Mini NES + Nes mini and Famicom mini themes:
          @sgtjimmyrustles
          I'll try and help but I'll need some more info first.
          What resolution setting did you use in the layout.xml file?
          What monitor/TV are you using?
          What resolution is the TV/monitor?
          And finally how are you connecting the raspberry pi to the TV/monitor?
          Hey, so I used the 1280X960 that was there. That's what resolution the monitor is. I'm using a HDMI to dvi adapter. It's a Hanns-G monitor. I'm uploading a screenshot to show you.
          Looking at the screenshot I think you'll find that your monitor is actually 1280x1024 (not 1280x960). That is a 5:4 resolution and isn't currently supported I'm afraid.
          SgtJimmyRustlesS 1 Reply Last reply Reply Quote 0
          • SgtJimmyRustlesS
            SgtJimmyRustles @ruckage
            @ruckage Thanks for at least letting me know. I thought this was 1280 x 960. Ah well, hit me up if and when you do add support for it.
            • ruckageR
              @sgtjimmyrustles
              A workaround would be to force the pi to output a 4:3 resolution that your monitor supports. Most monitors support several resolutions, I'd expect all monitors would support common resolutions such as 1024x768, if you're lucky it may even support 1280x960 but you'd need to look up the specs of your monitor first.
              • MydriazeM
                Mydriaze
                Hello,
                I'm really impressed by the talent some people have. Unfortunately, I'm not as skilled as people here. I would like first to thanks Ruckage for his work. That's absolutely beautiful.
                However, I have a pretty straight forward question about the nes mini themes: Is an option or a workaround to have parralax scrolling of the game, like the picture below?
                Thanks for your answer.
                greekmanxG ruckageR H 3 Replies Last reply Reply Quote 0
                • greekmanxG
                  greekmanx @Mydriaze
                  @mydriaze unfortunately no it is not possible with emulation station
                  • PokeEngineerP
                    PokeEngineer @greekmanx
                    @greekmanx
                    Well, not entirely... I mean, someone could hack it into ES.
                    greekmanxG 1 Reply Last reply Reply Quote 0
                    • greekmanxG
                      greekmanx @PokeEngineer
                      @pokeengineer I thought someone asked ruckage already and he said no
                      • MydriazeM
                        Mydriaze
                        Thanks evreyone for your answer.
                        • PokeEngineerP
                          @greekmanx
                          That was GridView, since the PR for GridView hasn't been merged yet...
                          • ruckageR
                            ruckage @Mydriaze
                            @mydriaze @greekmanx @PokeEngineer
                            I'm a little confused as to what's being asked here, what do you mean by 'parralax scrolling of the game'?
                            If you mean having a carousel for the gamelist (like the system view) then no, that's not possible with EmulationStation currently.
                            If you mean having the secondary scroll bar with the small icons showing all systems then again that's also not possible with ES.
                            If I've misunderstood and you mean something entirely different then let me know.
                            PokeEngineerP MydriazeM 2 Replies Last reply Reply Quote 0
                            • PokeEngineerP
                              PokeEngineer @ruckage
                              @ruckage
                              It was the first one you mentioned that @Mydriaze wanted.
                              • MydriazeM
                                Mydriaze @ruckage
                                @ruckage Yes, it was an horizontal scrolling of the game. :) Thanks for your answer by the way, and thanks for your work.
                                  Sarai
                                  Any way we could have support for Kodi as a system on the main menu instead of inside ports? I followed this guide to get mine running but in your themes I get a black screen since it doesn't support Kodi.
                                  ruckageR 1 Reply Last reply Reply Quote 2
                                  • ruckageR
                                    ruckage @Sarai
                                    @sarai
                                    Kodi is on the to do list (see first post in this thread).
                                    • CybermenC
                                      Cybermen
                                      I'm looking forward to a new update, maybe with Scummvm and nes/snes mini. Thank you for the great work.
                                        mrwasi
                                        Question.
                                        I have downloaded Portable EmulationStation for Windows and the NES Mini Theme doesn't work. Is there some alterations I have to do for the source code to get it to show up for the windows version?
                                        Any help would be great.
                                        • greekmanxG
                                          greekmanx @mrwasi
                                          @mrwasi I run mine with portable es on windows and snes mini and nes mini and Famicom mini all work great
                                            mrwasi @greekmanx
                                            @greekmanx The images don't show up for me when I change themes. Was there anything you had to do?
