    Need help with adding n64 texture packs.
    retro piemupen64plusmupen64plus.cfgtexture packs
    6 Posts 4 Posters 4.9k Views
      meav33
      Im trying to follow this tutorial: https://github.com/RetroPie/RetroPie-Setup/wiki/Optimization-for-Nintendo-64 for adding high reslolution texture packs to retropie (esp mario 64) i added the texture pack in the right directory, but when the script asks to make the necessary changes in the mupen64plus.cfg im stuck.
      Enable hi-resolution texture file loading
      LoadHiResTextures = False
      doesnt exist in my config even so i have launched mario with rice already
      and even so i can edit the line
      Use high-resolution texture packs if available.
      txHiresEnable = False
      it doesnt make a difference if set to true and also resets itself after each reboot of the pi.
      Can someone help me?
      I'm using the latest retropie on an raspberry pi 3
      • H
        Hawk1218
        Same issue,
        I modify /opt/retropie/configs/n64/mupen64plus.cfg file.
        I change
        to
        txHiresEnable = True
        but file /opt/retropie/configs/n64/mupen64plus.cfg are always overwritten with txHiresEnable = False
        Everything worked well in January 2017 before an update.
        Can someone help us?
        Thanks in advance.
        • hooperreH
          hooperre
          I'm actually having the same issue. Hi res packs were working in Mario 64, Star Fox, and both Zeldas.
          4B ~ RPi PSU 5.1V / 3.0A ~ 32GB SanDisk microSD ~ 128GB USB
          • L
            liquidzoo
            I have been able to get the High Rez textures working in OOT under Rice by just adding the Rice line to the end of my cfg file (and making sure I have a Rice texture pack) - but the Lens of Truth doesn't work under Rice and for whatever reason my GLide plugin bugs out after about 10 minutes every single time.
            Haven't tried Mario (though I installed the texture pack the same way, just haven't tried to play).
            hooperreH 1 Reply Last reply Reply Quote 0
            • hooperreH
              hooperre @liquidzoo
              @liquidzoo Man. I still haven't been able to get this to work again like it was about 2 months ago. You added the Rice config line to mupen64plus.cfg right?
              • L
                liquidzoo @hooperre
                @hooperre Yes. I added this to the very bottom of my mupen64plus.cfg file:
                [Video-Rice]
                LoadHiResTextures = True
