    HELP!!! Osoyoo 3.5" TFT Touchscreen with Retropie NOT Working!
    retropietfthelpnot workingtouchscreen
    1 Posts 1 Posters 1.5k Views
      Crushertt
      Hello,
      This is an issue many previously have had, however I am determined for this to work.
      I have a Raspberry Pi 2 and a Osoyoo (Kedei) 3.5" TFT touchscreen (version 6.2). It is one of the cheapest on eBay and as
      expected, does not come with much information, therefore I have surfed the internet looking for answers.
      Link to product: http://www.ebay.com.au/itm/3-5-LCD-Touch-Screen-Display-Module-w-Case-for-Raspberry-Pi2-Pi3-Pi-3-Model-B-/351802332204?hash=item51e90d942c
      Firstly, let me explain what I have done:
      For my first two attempts, I thought that as the special Raspbian works with the screen that Retropie would if it is installed on top of it.
      Attempt 1:
      Installed Osoyoo's special Raspbian which works fine.
      Attempted to update it, making the screen not work
      Attempt 2:
      Installed Retropie which displays loading screen (logo)
      Touchscreen goes black, normal monitor displays Retropie
      Attempt 3:
      Installed Retropie
      Installed drivers (v6.1.3 for v6.1,v6.2,v6.3) (http://kedei.net/raspberry/raspberry.html)
      Used this tutorial: https://github.com/jgamblin/OsoYooTFT
      Retropie displays loading screen (logo)
      Attempt 4:
      Attempted to use Adafruit's Running OpenGL-based Games & Emulators on Adafruit PiTFT Displays (https://learn.adafruit.com/running-opengl-based-games-and-emulators-on-adafruit-pitft-displays/pitft-setup)
      Got stuck with:
      Code: Select all
      sudo bash pitft-fbcp.sh
      (It couldn't find the file or directory)
      Attempt 5:
      Installed Retropie
      Attempted to use some Chinese driver install tutorial
      Short story is that it didn't work
      I am a novice with Linux, however if I am prepared to try anything at this point. I know the screen has a rubbish refresh rate and is not good for this type of thing, but if someone can help that would be AMAZING!!!
      What I want to know:
      -I have seen videos of it working, but is it possible I can get it working?
      -Framebuffer is a solution to this, but how do I do it?
      -Can someone provide a simple step by step instruction on how to do this? :D :D :D :D :D
      As well, I have heard that people SSH to their Raspberry Pi. I don't know how to set this up on Windows 10 if it is required to get this to work.
      For anyone who can help, I thank you. This has been a huge learning experience.
