    Stumped. How to get Tekken/Tekken 2/Tekken 3 psx iso's running on a RP3??
    psx emulationpsx-rearmedroms not workin
    5 Posts 2 Posters 11.4k Views
      joeljoel1947
      I have about 150 psx iso roms running on my RP3 but cannot for the life of me get any of the Tekken games to run or even boot. All three have several "tracks" that are .bin files as part of their un rar'd files as opposed to one big iso file. What exactly is the trick I am missing in getting these games to work in RP3 using the PCSX-ReArmed emulator? Or is a different emulator needed? Thanks!
        dankcushions Global Moderator @joeljoel1947
        @joeljoel1947 you should generally use the lr-pcsx-rearmed emulator, not pcsx-rearmed standalone (maybe you are already the lr- one as it's the default).
        do you have a correct cue file?
        do you have a correct BIOS
        personally i would always recommend obtaining a .pbp (PSP eboot version, athough run fine in the psx emulator), as there's no need for cue files, and everything is in the one file.
          joeljoel1947
          OK I tried a different rom site to download and now all 3 work! Oh happy day! Don't see a way to delete this thread otherwise I would....
            joeljoel1947 @dankcushions
            @dankcushions ---thanks for the reply! I am using the lr-pcsx-rearmed one, just left off the lr prefix. Got all 3 working now, but thanks for the reply!
              nice! have fun :) for some reason tekken 3 used to crash after the ending cut-scenes in arcade mode, but other than that it worked ok.
              we don't delete threads here :) technically this should have been in help & support, asked as a question, and now marked as solved. i've done that :)
