    Daphne / Dragonrise encoder issues
    daphne joystickdaphnedragonrisezero delay
    46 Posts 13 Posters 13.1k Views
    • U
      ULTRA-MAGNUSS @Clyde
      @Clyde I know this is an old thread but I've seen you post recently and hope you will reply. I'm confused on exactly what the fix was for this. I'm very uncomfortable messing around with configurations and got confused with the multiple threads and clarifications on the changes. Can you look at your Daphne config and tell me what exactly was changed to fix this. I have Dragon Rise Encoders and have the exact same issue with Left and Right not working only on Daphne. It isn't clear on what to change and what not to change. I saw grant2258 suggested making a change to the daphne.sh but his replacement code referenced his user name and wasn't sure if that's what everyone is supposed to put. Help on this old issue, which is new to me, would very much be appreciated. I really want my Daphne to work correctly on my retropie.
      • U
        ULTRA-MAGNUSS @ULTRA-MAGNUSS
        @ULTRA-MAGNUSS Nevermind, I just stumbled on another thread that was more recent providing simple commands to run from grant2258. It's working now. Now I just have to rotate my sticks and remap the controls for all other emulators since the up and down is inverted and I'm done.
          Clyde @ULTRA-MAGNUSS
          @ULTRA-MAGNUSS Glad to hear that. Care to share a link to that other thread in case someone else with this problem only finds this thread?
          • U
            @Clyde
            I am in no ways taking credit for this.
            @grant2258 Posted this fix in Jan 2019
            "I have fixed a long time ago just do this to compile it and install.
            cd /home/pi/RetroPie-Setup/
            git clone https://github.com/grant2258/daphne-emu.git tmp/build/daphne
            sudo ./retropie_packages.sh daphne depends
            sudo ./retropie_packages.sh daphne build
            sudo ./retropie_packages.sh daphne install
            sudo ./retropie_packages.sh daphne configure
            sudo ./retropie_packages.sh daphne clean"
            After I ran those commands, left and right now work correctly. I wish there was a way to make Up and Down not reversed for Cobra Command but it's normal for Space Ace so I guess I just have to deal with Cobra Command's up and down reverse scheme. Thanks grant2258 for the fix.
              @ULTRA-MAGNUSS said in Daphne / Dragonrise encoder issues:
              @Clyde
              I didn't want to imply that you were. 😇 Thanks for sharing it anyways. (Although a simple link to grant's post would have been sufficient – I found it now by searching the forum for the first sentence in your quote. 😉 )
              • U
                @Clyde sorry that wasnt really directed at you. That was just for letting everyone know that I didnt want grant to think I was taking credit for his fix. All is good :)
                ClydeC G 2 Replies Last reply Reply Quote 0
                  @ULTRA-MAGNUSS I don't think anyone would think you're taking credit if you cite your source with the name of the author. Cheers 🥂
                    grant2258 Banned @ULTRA-MAGNUSS
                    @ULTRA-MAGNUSS not worried about credit at all glad its working for you unfortunately thats the way these games are mapped on the hardware youll find the same issue with a lot of flying games down goes up.
                      kmorreison
                      Pls any help me to compile this to retropie 4.5.15??? and send me some heeeeelp?? :S my joy fail...
                        drewjbx @kmorreison
                        @kmorreison working fine as of retropie 4.6. 9
                        • 2
                          22marco77 @grant2258
                          @grant2258 When I carry out the procedure it asks me for githilub credentials, once entered it tells me that it cannot connect to your github. Please help me I have the right and left axis reversed
                            mitu Global Moderator @22marco77
                            @22marco77 The repository mentioned no longer exists on Github, that's why you get the error.
                            I'll lock this topic, since the original project doesn't exist anymore. Use Hypseus, now part of RetroPie.
                            • mituM mitu locked this topic on
