    Famicom (not Mini) build (WIP)
    famicomfamicom minines
    264 Posts 11 Posters 164.0k Views
      edmaul69 @FlyingTomahawk
      @FlyingTomahawk keep it in there as long as you like. I am now curious about how well it will work.
      FlyingTomahawkF 1 Reply Last reply Reply Quote 0
      • FlyingTomahawkF
        FlyingTomahawk @edmaul69
        @edmaul69
        Thanks for your patience.
        Me too, looking forward to the final result.
        If that works I'll get me a pub-yellow SNES for $3-4 bucks, bleach it and put my second Pi Zero in there.
        • FlyingTomahawkF
          FlyingTomahawk
          Guys hold on to something.
          Remember the co-worker of mine which is the ultimate Hard-off guide? Well he knows that I am looking for Famicoms. This is the picture he send me.
          Yes! 4 Famicoms coming my way! More than enough for builds or scientific purposes.
          He bought all 4 em.
          obsidianspiderO K 2 Replies Last reply Reply Quote 1
            obsidianspider @FlyingTomahawk
            @FlyingTomahawk you really are going to make a sofa out of Famicoms…
            They're all quite "pub yellow", I hope they were cheap.
            FlyingTomahawkF 1 Reply Last reply Reply Quote 1
            • FlyingTomahawkF
              FlyingTomahawk @obsidianspider
              @obsidianspider
              Yup, cheap. They're junk.
              You don't like pub-yellow? It's part of their history. :-))
              If the current bleach experiment works I'll have 4 "white" Famicoms. ;-)
                @FlyingTomahawk pub yellow may be for some, but not me. I'm very eager to see how the bleach experiment works out.
                • FlyingTomahawkF
                  FlyingTomahawk
                  3rd day.
                  Did it get any better? You guys tell me.
                  Here one the first picture.
                  I know the light is different so hard to really tell.
                  I would have to take it out or take it to the exact same place and re take the picture.
                  But I think the pub-yellow has faded a bit, right?
                    @FlyingTomahawk It looks whiter to me. How are the stickers and red plastic holding up?
                    • FlyingTomahawkF
                      @obsidianspider
                      They look good thus far.
                      Red plastics seem to be unaffected by it.
                      The red Famicom logo on the front also looks undamaged or same as it was at the very beginning.
                      Let's see how that looks after 1 week.
                      Worst case, stickers I can print and reapply.
                      • space cadetS
                        space cadet
                        Definitely working. I'm going to do the same with my brown nes case ; )
                          @FlyingTomahawk looking good to me.
                          • FlyingTomahawkF
                            FlyingTomahawk @space cadet
                            @space-cadet
                            If you give this a go try to get this.
                            wide haiter ex power
                            I think Amazon sells it.
                            It's not just bleach but also smell remover. It doesn't smell like bleach but more like soap.
                            • FlyingTomahawkF
                              FlyingTomahawk
                              Not sure it is good visible but when moving the eject switch you can see a thin line of its old color.
                              I think it would have been better to remove the 2 stickers and the one that points to the plug on the front before bleaching.
                                @FlyingTomahawk it looks really good. The white under the clear decals matches the console now.
                                • FlyingTomahawkF
                                  FlyingTomahawk
                                  Its even becoming more white than under those decals that is why I think I should have removed them. But I'm gonna get 4 more Famicoms so plenty of chance to improve.
                                  I am positively surprised that it worked that good in such short time even with such cloudy weather.
                                  I'm gonna keep it a bit longer in there till I get the other Famicoms then I'll just swap and continue the withening process with the same liquid. Let's see how many Famicoms can be bleached.
                                    @FlyingTomahawk feel free to remove the clear decals if you need. I will try to find replacements. If they arent there i am not really bothered by it. If it was a new system i would have removed all the clear instructional decals. I remove them off of all my stereo components, tv's and computers too.
                                      Have you tried using the 8bitdo controllers with the Zero W yet?
                                      • FlyingTomahawkF
                                        @obsidianspider
                                        No not yet.
                                        I only setup the Zero W with the roms and Famicom-mini theme and that's it.
                                        I haven't switched on those FC30 controllers yet.
                                        However I found a solution to my controller charging problem.
                                        I found a 3-1 microUSB hub that could be very useful. It was cheap so I ordered one.
                                        Example here
                                        So the male plug from the panel mount microUSB goes into the female of the HUB then the male from the hub into the Mausberry or Pi directly and the charging cables (USB->microUSB) connect to the 2 remaining USB female plugs.
                                        Make sense? It would be awesome if it works since it would be a solderless solution.
                                        obsidianspiderO edmaul69E 2 Replies Last reply Reply Quote 1
                                          @FlyingTomahawk Solderless? Where's your sense of adventure? ;)
                                          I'd be curious how the hub handles a big power load put through it, but there's one way to find out…
                                            @FlyingTomahawk if i end up with those bluetooth controllers i thought about just have the the charging cables come out of the original controller cable holes. That way i dont have anything big and bulky hanging out of the back. And it will kind of resemble the original controllers when they are plugged in.
