    ProjectRetroPie V4.0.3 64 GB controller problem
    controllersnes controllerretropie 4.0.2config editor
    5 Posts 3 Posters 1.8k Views
    • E
      Everett1954
      I have the ProjectRetroPie 64GB image (Project Retrobution) and have a problem using a generic SNES game pad.
      It works on the menu screen but not with any of the emulators. I had deleted the es_input.cfg file, rebooted and reconfigured the game pad.
      Pressing the menu and select together does not get me back to the menu also.
      Is there something else I need to configure or delete?
      Is this image set up for a particular controller? If so which one?
      E herb_fargusH 2 Replies Last reply Reply Quote 0
      • E
        Everett1954 @Everett1954
        @Everett1954 Should say Retropie Ver 4.0.2
        • herb_fargusH
          herb_fargus administrators @Everett1954
          @Everett1954 we don't support 3rd party images. Especially those illegally distributing ROMs. Ask for help from who you got it from or start from a fresh image from our site.
          • E
            Everett1954
            Sorry, didn't mean to break any forum rules. You can remove if you need to. I can always ask a generic controller question.
              mediamogul Global Moderator @Everett1954
              @Everett1954
              You can do so and someone may be able to help. However, you'll always be working at a disadvantage in regard to troubleshooting any problems going forward, as you will never be sure exactly what was changed in the image that could be a contributing factor. This will not only exhaust your own time, but also that of others trying to help you.
