    Help with Simple Scrape Removal?
    scraperemovescraperemoveretro pie 4.1scrape data
    3 Posts 2 Posters 1.8k Views
      KANE81
      I am new to retropie. I have read several forums to try and remove my scrape data.
      these instructions seem to be what I need but I don't know how or where to apply.
      /home/pi/.emulationstation/gamelists/
      select the relevant console from the list and just delete the games you require from the gamelist.xml file then rescrape.
      How do I do this?
      Would I take my micro card out of retro pie and plug it into my computer to locate the xml file?
      or is this something I do in the pi?
      If this is code in pi then I am lost. [link text]([link url](link url))does anyone have step by step instructions?
      • herb_fargusH
        herb_fargus administrators @KANE81
        @KANE81 it would do you well to learn the terminal, very useful skill.
        You can access the terminal over SSH:
        https://retropie.org.uk/docs/SSH/
        You can also access your files under sftp with something like winscp or filezilla.
        Or over samba shares from Windows on your network if your pi is connected
          KANE81 @herb_fargus
          @herb_fargus I really appreciate the advice. I am even more lost now ha! but I would like to learn how to navigate the terminal more I just don't have any friends that could walk me through it. I will check out your link. thanks!
