    Help with Joystick Config and Understanding Retropie Controllers
    hori fightstick
    28 Posts 5 Posters 13.0k Views
      meleu @chan
      @chan did you read this post of mine above? :-)
        chan @meleu
        @meleu lol forgive me xD
        i will deep a little. hehe
          chan
          @meleu nice job. it works with roms in arcade folder and using your script.
          The only thing is if u can say me how to econfigure buttons for all roms cause the buttons are really moved :p
            meleu @chan
            @chan this is the easiest way:
            https://retropie.org.uk/docs/RetroArch-Configuration/#core-input-remapping
              chan
              @meleu impo men.
              i´m into quick menu controls and i cannot change "user 1 burron A:" or anything
              im only able to change controls in other menu. Under settings - INPUT - Input User 1 Binds
              do u know why i am not able to do it?
                meleu @chan
                @chan what exactly do you mean with "I cannot change"?
                You press left/right on the d-pad when the "user 1 button a" is active and nothing happens?
                  chan
                  nope, it seems freeze.
                  And up in that menu, it appears the USB controller d PAd, but not the THT xxx (who is the joystick) so when i try to find it, im only able to see the Nintendo Retropad and the super nintendo buffalo retropad, but not the THT when i navigate with left and right (and none appears too).
                  Im able to see the THT in the menu of input that i referred in the other post
                  Is there a "manual" map in order to change it with a keyboard? where it supose to be that config file? only for fba
                    chan @chan
                    @meleu ??
                    Help with Joystick Config and Understanding Retropie Controllers:
