Issue with controller (hotkey) on PC x86
Hello everyone.
I've been using retropie on rpi3 for about 7-8 months now and it's great. But i have a used PC that would probably give me a bit more performance in some systems and i was hoping to move to that.
It's running Ubuntu x86. I ran the install script and installed the base packages. (4.2)
I ran emulationstation and setup my joypad, just like on my pi3 (im using the same one on both). It's a logitech f710
It worked fine in emulationstation, but not at all in any emulator, so i switched the joystick order in the configuration so that my controller would be the 1st, and keyboard 2nd.
Now it works in the libreretro cores... BUT, it's like the hotkey is pressed all the time (when it's not... i have it set to L3).
Now I read that you have to run the retropie_package.sh with the hotkey parameter... it says that the hotkey package is not available...
How do I fix, is that package available in the Ubuntu build ?
Thanks!
