    Problems with the PCSX-Rearmed
    pcsx-rearmedretropie 4.2missing fileraspberry pi b+raspberry pi 0
    7 Posts 3 Posters 4.8k Views
      ToThrane
      Hello
      I am using RetroPie 4.2 on my Raspberry Pi B+/Zero
      USB Keyboard
      Ethernet
      1 amp power supply
      I have tried getting the PCSX-Rearmed emulator to work for about 2 weeks now. I had it up and running and play PS1 games no problems on RetroPie 4.1.20, but i updated the software and all my emulators and now the PCSX-Rearmed do not work.
      The Bios are in the right folder and my games are bin/cue.
      I tried:
      Install a new image (RetroPie 4.2)
      Install the emulator again
      Updated from binary/source
      Install a older version of RetroPie (3.8, 4.0 and 4.1)
      Tried a Basic install
      I updated the RetroPie-Setup.script
      I have my computer connected and can look through the shared folders, and found the emulators.cfg file and it say:
      pcsx-rearmed = "pushd /opt/retropie/emulators/pcsx-rearmed; ./pcsx -cdfile %ROM%; popd"
      I then used the RetroPie's file manager and found the path, but it does not contains the pcsx file
      Does anyone have any ideas
        dankcushions Global Moderator @ToThrane
        @ToThrane it's lr-pcsx-rearmed. the standalone emulator is not installed by default.
          ToThrane
          @dankcushions it's not the Lr-PCSX-Rearmed. As i mentioned i install the PCSX-Rearmed. The emulators.cfg file contains both path:
          lr-pcsx-rearmed = "/opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-pcsx-rearmed/libretro.so --config /opt/retropie/configs/psx/retroarch.cfg %ROM%"
          default = "pcsx-rearmed"
          The libretro emulator works but the non libretro does not.
            BuZz administrators
            The binary for rpi1 is broken (must have failed when rebuilding optional packages) - im rebuilding. You can install from source in the meantime.
            I would recommend the libretro core though over the standalone emulator.
              ToThrane
              Okay @BuZz, ill try to install from source. The only problem i have with the PSX Libretro is it really slow.
                BuZz administrators @ToThrane
                @ToThrane They use the same codebase so should be no performance difference, unless you have changed some settings (eg turning off dynarec)
                  ToThrane
                  Thank you @BuZz. It help installing from source. I does not know why the Libretro i slow, mabye i have change something.
                  It solved the problem thanks
