    Arcade Controller - Button/USB Question
    arcadecontrolsconfigure filearcade controls
    37 Posts 4 Posters 17.7k Views
    • caver01C
      caver01 @THRobinson
      @THRobinson I have that USB port on my cabinet. Works great, but designed to be used with a corresponding Netrick hole. My cab has a pair of holes in one of the recessed plates (roadcase) but you could easily measure and drill. It is a hefty port for sure. Very strong.
      As for the USB cabling behind it, this got a bit out of hand in my build, so since I posted my project, I have gone back and soldered up custom USB cables for everything. I bought mini, USB-A and B, and micro plugs, shielded 4-conductor usb wire and heatshrink to make all of my own USB cables. The side benefit is that I have been able to make some paracord cables for personal use as well as repair a bunch of lightning cables. SO, the USB components have definitely come in handy.
      I think Ultimarc or Groovy Game Gear has a corded USB port that is a little lighter than the Netrick.
      THRobinsonT 1 Reply Last reply Reply Quote 0
      • TMNTturtlguyT
        TMNTturtlguy @THRobinson
        @THRobinson I would go for a more simple solution for USB ports, you would have to see if you could get this delivered to you. Stick with standard USB cables this way. amazon For power I would simply run the power through the box and not provide a plug point. If you wanted to have a power supply plug i would use one of these, however they don't have mounting screws amazon.
        Per your previous post, i am concerned about the weight of this box on a lap. What are you building the box out of? 1/2 or 3/4 MDF? that stuff is heavy. The monitor will also be heavy for a lap, a 15" desktop flat monitor has a lot of weight when you sit it on your lap, they are heavier than a laptop. Combine that with the box and controls, this is going to be bulky and heavy. How do you intend to play the joystick and buttons on your lap, the controls will end up being very close to your stomach and hard to use, and if this is sitting on player 1's lap, how does player 2 view the screen if setting next to them? Not trying to ruin your plans, just asking some questions. Maybe a quick sketch might help us better understand your ideas for the build. Thanks
        • THRobinsonT
          THRobinson @caver01
          @caver01 said in Arcade Controller - Button/USB Question:
          Ya... seems like heavy duty stuff and I saw a few images of it mounted from the inside, but I didn't want to drill into the wood and have it at what looks like about 1/8" thick ... instead I may use a dremel/router and inset it at the back 1/8"... though likely I'll get lazy on that part and just screw nail it in and call it a day. :D I had a few ideas for the external ports, but for the price, this is as cheap and way easier. Just drill holes and slide it in, screw and done.
          Soldering actually would make things easier I think, cleaner and tidier for sure. Shame those Neutricks didn't have just solder joints one one end. I'll check those two other sites out.
          @TMNTturtlguy - I was originally looking at those same panel mount cables on eBay. China was cheap, price triples in N.America but lately my luck has been so bad with China stuff that I won't buy from there, especially off eBay/Amazon. Plan was a small metal plate on the back screwed in, hole for the port, and bolt the plug to the plate.
          Monitor idea is gone... previous plan was a small bar-top, but shifted to a 2-box controller... Box1 has all the buttons and RaspPi and plugs into the TV HDMI to play... if a 2nd player wants to play, they connect to Box1 via USB and Box2 only has the basic buttons and a PCB board inside. 90% of the time Box1 will be used for solo play. Original idea was to design graphics and make it out of 1/2" MDF with glued in braces inside for screws. Having gone to school for design, that would have been fun to do and have printed on vinyl. But, now I am thinking nice quality 1/2" hardwood, clearcoated with the smoke grey buttons and smoke grey bubble ball top, and prob red 24mm buttons at the rear for the aux buttons and two on top for coin/player to add some colour.
          I know, easier solution is 1 box, and 2nd player can use the PS3 controller via bluetooth but, lets face it, arcade buttons and joysticks are more fun.
          I have a sketch I am working on now in Illustrator. Been printing it out and pretending it's real to get a placement I like. Spacing is all sorted for buttons/joystick... think it was a Sega layout and moved the joystick left another inch or so, just debating overall size of the box now. I have placeholders to scale of the PCB board and RaspPi and the plate size of the joystick so I can sort out where things will fit so hopefully when done it's straight forward.
          I don't have it here with me (at work... working very hard) but can post it later.
          Laptop wise, I hear ya... control box isn't ideal in the lap, but, no coffee tables, may have to pull up a chair or stool to the couch, I dunno... kind of a 'too bad' factor for that because no room for a full cabinet like I wanted, bar-top is cool but also a storage issue when not in use. Coffee table wise, we just don't want one. Be tripping over it constantly.
          When no one around and just me, I'll be at my TV (not the family room one) in which case I'll be in a lazy-boy with the feet up... should be fine in that situation.
          • TMNTturtlguyT
            @THRobinson How are you connecting to the TV? Are you going to try a wireless hd connection? or are you still planning on a wired HDMI? Have you thought about simplifying the entire build and just putting the raspberry pi in a case next to the TV and then build 2 really nice arcade control boxes? This way the pi is portable and can plug into the wall and TV cleanly. No issues with weight or cooling. Then just get usb extension cables so the control boxes can be located further away from the TV. Now you have nice light weight control boxes and get rid of all of the cost and complexity of putting the pi inside of control box 1. There are a ton of cool design builds for this out there. If you want to take the system with you, it is just one small extra piece to carry the pi itself.
            • THRobinsonT
              THRobinson
              Back of Box1 will have 4-24mm buttons recessed so not accidentally pressed... plus two ports on the left... one for the USB power, and a female HDMI. Then I'll just get a good quality long HDMI cable to plug in at both ends (Box1 and TV).
              I have the RaspPi now in a small case, typical free kit case. Nice that it's so small, but also kinda dumb... too small/light and never stays put when plugged in and cables moving.
              I debated what you're saying... box at the TV and 2 ports for USB at the front. Then make 2 identical controllers, but, then you now have 3 boxes not 2. Less portable IMO, because if just 1 player, you have 2 boxes, an HDMI cable, a USB cable for power and a USB cable for the controller, instead of 1 box and a power/HDMI cable.
              Upsides/downsides to both really... if I went 3-box... I'd have to build a new Pi box. That plastic little case is just too light.
              Then again, separate box means that the LEDs are back in play.
              Dammit TMNTturtleguy... now I gotta go back to debating again. :D
              TMNTturtlguyT caver01C 2 Replies Last reply Reply Quote 0
              • TMNTturtlguyT
                @THRobinson SORRY! Just trying to throw out some ideas and ask some questions, I have about 4 builds going of various shapes and sizes and have already done all the homework you are doing now! Just sharing what I learned so you can get the best custom box that meets all of your needs! I am sure whatever you decide to do, it will turn out great. Another thing you might want to look into is the guys on here that make retro boxes in old NES and SNES consoles. They have great ways of wiring ports and connections from the pie to the case so they look almost exactly like the old 80's 90's boxes, sometimes you can't even tell they have been modded! They do the soldering as you have suggested, you might learn some things from their builds. @japanwings
                • caver01C
                  caver01 @THRobinson
                  @THRobinson I like your interactive planning here. I know it is ultimately your decision what to build, but it is fun to collaborate. I have a friend who wants something similar to what you are building, so going through the design iterations is a great exercise that probably benefits other readers as well.
                  Arcade controls in your lap is a bit of a contradiction in some respects, but I can see how it might work. However, you need to be thinking about how it will feel to have both a USB and an HDMI coming out the side. Seems like that HDMI might have the tendency to come out, while a micro USB grips a bit better. We use laptops at work with HDMI connected for meetings and I gotta tell ya, you don't really want to move them around too much--and that's on a table, not your lap!
                  Finally, cords coming out the side seems like a hinderance. It depends on your chair, but I can see this rubbing against chair arms, hitting your knees etc. while a cord coming out the back, toward the TV would me more conducive to "arcade controls in your lap". Just two more cents for ya. Take it or leave it, but a fascinating project.
                  • THRobinsonT
                    THRobinson
                    @TMNTturtlguy haha, no worries... I'm in the planning phase which is why I like using forums... you get other ideas and hopefully avoid headaches on stuff like this.
                    Staring to think, the more elaborate my idea gets, the more wires and cables get involved and lost the LED lights. Basically, a 3-box setup would be like having an NES system again more or less. Plus I gain the LED option again, which is the absolute least important part of the build, but also fun. Plus I can add that mausberry (or similar) shutdown button to the console.
                    Put inside the box the RaspPi, a powered Hub, I also have a new 80mm PC fan sitting in a box at home I bought for a case but never used. Put some venting in the box. Maybe use an adapter to the USB hub if enough power?
                    Modify a USB bracket on the front for USB cables. I still like the idea of having USB cables that can be removed on both ends.
                    Only factor that I can't change... is being in the lap. Maybe bring the dining chairs out and use as tables... otherwise, no options there. Else I'll be at IKEA for hours debating a coffee table, that I'll then have to bring around with me depending which room I play in. :D
                    Well... time to ponder... re-price some parts... then wait a month for everything to finally show up. :D
                    • TMNTturtlguyT
                      @THRobinson I like this plan a lot! Seems a lot cleaner. I think if you just have a single game pad on your lap it will be prefect! The box won't be to big so sit on your lap and play. I also like this idea because you can easily expand to 4 player with either 2 more joystick boxes, or other controllers. Lot of flexibility. Can't wait to see some photos!
                      • THRobinsonT
                        THRobinson
                        Well... may be a while depending on parts shipping. Other purpose of this project is that I use to really love wood working, then when my folks moved and downsized, that nice big garage of tools was no more. So, I haven't really gotten back into it in 25yrs. Usually stuck fixing the cars. :D
                        So... be a while for photos... if no photos... then my wood shop skills have declined too much for me to want to brag about my work. :D
                        Box on the lap I think will be fine... may even work better if I go wide but thin... don't need a box 8" high, just enough for wiring and buttons at the back edge. Wide and deep would be more stable on the lap, then drop some weight making it thin.
                        Oddly... not finding as many LED buttons as I had hoped on the few sites I'm looking at. eBay/Amazon has a lot of light up kits, decent price, all China no name brands. I was originally going for the Seimitsu PS series in Smoke. Guess that series has no LED option on focusattack.com. I'm in Canada and found a few Canadian sites for parts but annoyingly, everything I click on has 0 stock or I need 12 and they have 5, etc... always good to buy local, if local has stock that is. :D
                        Ah well, when at home I'll search some more. Hard when at work. I'd like to stick with 1 brand if I can so that colours and styles match. Seimitsu or Sanwa... never used either before so no preference.
                        • TMNTturtlguyT
                          @THRobinson just an FYI - not sure how amazon works in Canada? I am a prime member and I got the Easyget LED buttons in 2 shipping days. They are from china, but they are stocked in US warehouses and available for US prime members in 2 days. The buttons are popular, so sometimes there is a note that states there may be a few day delay.
                          • THRobinsonT
                            THRobinson
                            Not sure... Amazon.ca is as bad as eBay.ca lately.
                            I contacted an eBay seller a few days ago. Item said located in Texas, but shipping was free from China. I live about 1.5h from the border to the USA, but because I am not in the USA, they won't ship from the Texas warehouse, rather it will come in from China.
                            Amazon... ordered stuff as a part of an Xmas gift, Oct 27... eta was Dec 9, no prob... Feb 9th it finally showed up, about 2 weeks after I finally gave up and repurchased the items locally at about 3x the price.
                            NewEgg is the same... actually just got a refund today. Bought a cheap 32GB SSD drive to use as a boot drive for my HTPC. $20... faster and quieter than my old HDD. 2 weeks over due, just given a refund because MIA. I actually emailed the seller to find out where it's shipping from and they said China but assured me 8-15 days... that was a month ago.
                            Never had bad luck until the past year.
                            That said... the parts total has jumped up a lot... hopped onto eBay and the buttons I want are only sold by China sellers, same sellers are also on Amazon.ca so, doesn't matter which way I go. I ended up flooding them with questions though. Buttons I want are sold in sets of 10, I need 12... another set has 1 player, 2 player and coin, but need another coin button. No sizes, so, not sure if 30mm or 24mm... few cases they show the Zero Delay PCB board in a kit, but when you click the images, the board is different in one photo than the other... so sadly, had to email like 6 of them for details and suspect most of the replies won't make much sense. :D
                            Cases I decided I'll head to the dollarstore. See what they have. Last I was there, they had some nice 1/2" thick Bamboo cutting boards, where it's all nice strips glued together as a single board. Thinking top/left/right would be nice in that, then the front/back maybe a darker wood, like cherry lightly stained? This weekend I'll be wood hunting.
                            Likely the top surface will be a light wood, like bamboo or beach... so the smoke grey seimitsu buttons would look nice. Otherwise those smokey grey/blue with gold rings would look nice too all lit up with the matching coin/player buttons, though maybe too much bling with the gold and such.
                            • THRobinsonT
                              THRobinson
                              Got a nice idea sorted out, got a nice plan for the box using various strips of different wood such that the strips integrate with the buttons, etc... should be good.
                              Lot's of eBay replies today, most nonsense and most unhelpful. Opted to just forget the LED's and get a better brand of buttons and such. The Seimitsu PS series, was going to go Sanwa, but buttons don't have the threaded body which for wood, would be the better option. The clip in ones are fine for acrylic/metal tops but will wear the wood down eventually and pop out.
                              So... ordering parts tonight I think (really adds up when I see the exchange rate, but again I tried 5 Canadian sites and stock is just horrible).
                              Just to clarify... back to the USB thing. Since having no LED lights, would I still need a powered hub? Doesn't make the build harder just a bit pricier. Plus, I've avoided hubs for years simply because back when they were new, I remember how many issues they had... use the mouse and keyboard quits, plug in a memory stick and mouse quits. I just want to make sure that when plugging in the joystick boxes I'm making, that the RaspPi doesn't get confused and makes me remap the buttons every time. That's the one thing I don't think was ever answered in this thread... does RetroPie save the config file for the controllers and remembers the setup, even when a controller is intermittently used/plugged in.
                              Again, not a harder build with a hub, just more costly. If I do use that 80mm fan I think the hub is a must again, but if no fan just a few vent holes... non-LED controls should be fine without a hub, right?
                              • TMNTturtlguyT
                                @THRobinson Without the LED and with no fan, there is no need for a hub. If you put on a small fan like a 5v .14amp fan, you can run that off of just the #4 and #6 pins. This is a small fan that you would want to mount to blow air directly onto the top of the pi itself. I would put a few heat sinks on and blow air directly onto the board, and then allow the case you make to vent that air out. A bigger fan would be best with its own power supply.
                                As for usb hubs, i would get the one i referenced in an early post from the pihut. It is out of england I believe, had to pay the conversion from pounds, but it was fairly reasonable and it works well with the pi. You should not have any issues with the controllers, once they are configured the pi will remember the controllers name and it should work every time even if you unplug it. No different than turning off a blue tooth device and turning it on.
                                • THRobinsonT
                                  THRobinson
                                  Ha... realized that was a charging hub only... no USB cable. :D
                                  I have nothing against ordering from the UK, but exchange and shipping turns it into $27CAD, which isn't a lot.. and I'll probably buy that one. Looking at NewEgg and Amazon, specs are sparse, and some don't come with the AC Adapter, so adding that is the same as buying the UK one that's been tested on a RaspPi.
                                  Fan is this one from Arctic Cooling... was for my 12yr old computer case, but before I installed it I said naw, and bought a new HTPC case since it was for a media server anyways. Not in front of me right now so not sure the specs... NCIX says 3-pin, Arctic Cooling site says 4-pin, not sure if a model change or wrong specs.
                                  Anyways... 80mm, be good for a Pi build. Plan was to mount the Pi off the ground an inch or two and below the 80mm fan by an inch or two, totally open space all around the Pi. Pi has heat sinks, not sure how much they do, but, air vents on either the sides or bottom, basically suck the heat off the Pi's heat sinks. But, larger than the 30mm fans I see on eBay.
                                  Specs at Arctic cooling though do show 12/7/5v options
                                  https://www.arctic.ac/worldwide_en/arctic-f8-pwm.html
                                  But, 3 or 4 pin... not two.
                                  • THRobinsonT
                                    THRobinson
                                    Thought I'd post, in case people looking for ideas. They have lots for car dash kits, short leads, flush mount, HDMI, USB, Dual-USB etc... not shabby. Actually for the back of the console, the extra USB port may be handy for an extra hookup like a keyboard or Rii controller.
                                    http://www.ebay.ca/itm/Auto-Car-Dashboard-Flush-Mount-USB-2-0-Extension-HDMI-to-Mini-HDMI-AUX-Cable-kit-/172159468891?var=&hash=item281581055b:m:mjQUNybm-6pkiOlp8AB2moA
                                    I think I may use these on mine... same size approximately as the arcade buttons (3mm difference) I think it'll be easier to make work on 1/2" thick wood than these styled plugs. At least for the HDMI on the rear of the box...
                                    http://www.ebay.ca/itm/HDMI-male-to-Female-AV-audio-panel-screws-mount-cable-0-3m/381769893944?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140620091118%26meid%3Dc8c14b9fe7c84f06b75a7e684acaf687%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D172159468891
                                    • THRobinsonT
                                      THRobinson
                                      Fine tuning the list... know what I need for the most part, just pricing sites and seeing who has stock, but a few small items I gotta get off eBay.
                                      I was looking at something like this as a power indicator light, hook it up to the GPIO so when pressed it launches a shutdown cmd and when the Pi is shut down, LED goes out.
                                      Of course, 12V... so can I put something like this in between? Or will the Pi have enough to power the LED just maybe half as bright? This video implies that the 12V LED will work though... has links in description showing the same button on Amazon as well as others... (link below)
                                      Then at the back, I wanted a power button like this. Then I can use a regular computer cord, and a master power switch to cut power to both the Pi and the USB Hub else the case fan would run non-stop. Plus, bonus fuse, which in a small area like here with constant power issues, may be a good idea.
                                      80mm fan I think may need to be running off the USB hub, which may be a pain and just worth grabbing a 30mm RaspPi fan that runs off the GPIO instead so when I press the power button on the front of the console, the fan shuts off when the Pi shuts off. Then just leave the power running to the hub which probably won't hurt anything I don't suspect.
                                      Any feedback? Once sorted, I hope this time tomorrow, I'll have everything on order.
