    Ir-FBA Controller problems
    fbacontrols
    4 Posts 2 Posters 1.2k Views
      Kristopherson05
      Hi,
      I'm using Ir-Fba and i'm wondering how to edit the default controller config. I know how to edit individual games but I can't seem to make any defaut settings. Please help, thanks.
        meleu @Kristopherson05
        @Kristopherson05 This is the best way I know to achieve what you want:
        https://retropie.org.uk/docs/RetroArch-Configuration/#core-input-remapping
          Kristopherson05
          @meleu My config wont stick. When I try to edit the FB Alpha.rmp file and save to core remap file It only saves the config for the specific game, so if I try to go on a different game, the old config file is there ( which is the B button for every control). So what I'm trying to achieve is to make one file that's good for every game (more or less) in the final burn alpha emulator. Does this answer your question?
            @Kristopherson05 Have you noticed that there are two options in that menu?:
            • Save Core Remap File
            • Save Game Remap File
            When I choose "Save Game Remap File" it does exactly what you want to do. And it works flawlessly for me (and many others). If it isn't working as it should be for you, I suggest you to delete the .rmp file and try it again.
