    Mad Catz SFV Alpha Arcade Stick Compatible?
    controllermad catz alpha
    14 Posts 5 Posters 5.0k Views
    • BeanB
      Bean
      Hi,
      As per the title really, is the Mad Catz SFV Alpha arcade stick compatible with RP3 with RetroPie 4.2?
      Heard that earlier versions (SFIV?) for the PS3 had issues and required internal modding.
      Many thanks
      • XVOX
        XVO
        Why won't you try it for yourself?
        • BeanB
          Bean
          don't own one, or know someone who does, and wanted to minimize the risk of buying one and it not working (though i have a ps4 so wouldn't be totally useless but main use was going to be pi).
          was hoping someone on here had already tried one :)
          • BeanB
            Bean
            Well, just for completeness for anyone who searches this topic...
            Couldn't get confirmation that the Mad Catz was compatible, it has gone up from £35 to £60 and Mad Catz has gone bust so not a sensible option anymore.
            I got a Mayflash V2 which I can confirm works brilliantly in FBA and MAME 2003 using the lr emulators. Thinking of adding a Venom stick as a 2nd and to get PS4 compatibility (they are basically the same stick)
              mediamogul Global Moderator @Bean
              @Bean
              Just as a word of caution moving forward, third party wireless console controllers are always a gamble outside of their own ecosystem. The drivers written for Linux are almost always designed around what is publicly known about the official controllers and since this is also true of the companies designing third party controllers, the two very often don't overlap well.
              edmaul69E BeanB 2 Replies Last reply Reply Quote 0
                edmaul69 @mediamogul
                @mediamogul i can say that both the wii and 360 madcatz street fighter iv arcade sticks work on the pi. However i recommend replacing the buttons and joystick with sanwa part if the fightstick you get isnt already using them. I use a wii one myself.
                  @edmaul69
                  Mad Catz's reputation was getting to be pretty good. I really think there was an effort to improve the quality of their controllers. It's a shame they had to close down.
                    @mediamogul thanks for ruining my day... :) i did not know this. As a person who worked in the video game industry, i used to hate madcatz but i agree that they truly were changing. There were several great products made by them. As far as arcade sticks, i think they were the best. Hori used to be the one and only to get a stick from but that opinion has long since changed for me. I prefer a madcatz fightstick. I do like how they sold parts to customize the professional line of fightsticks.
                      @edmaul69
                      Those were my father's dying words.
                        @mediamogul and i think those were my father's wedding vows. :P
                          @edmaul69
                          Ha!
                          • BeanB
                            Bean @mediamogul
                            @mediamogul The Mayflash V2 is wired so no concern there :)
                            and thank you edmaul69.
                              roodrigoc
                              Hi,
                              It works in Retropie 4.4.2, I had to remove the xboxdrv driver from the system to work.
                              pi@retropie:~$ sudo lsusb | grep -i mad
                              Bus 001 Device 002: ID 0738:8180 Mad Catz, Inc.
                              pi@retropie:~$ sudo dmesg | grep -A1000 "new full-speed"
                              [ 965.849530] usb 1-3: new full-speed USB device number 16 using xhci_hcd
                              [ 965.991677] usb 1-3: New USB device found, idVendor=0738, idProduct=8180
                              [ 965.991693] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                              [ 965.991704] usb 1-3: Product: Mad Catz FightStick Alpha PS4
                              [ 965.991712] usb 1-3: Manufacturer: Mad catz Inc.
                              [ 965.997686] input: Mad catz Inc. Mad Catz FightStick Alpha PS4 as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:0738:8180.0006/input/input16
                              [ 965.999232] hid-generic 0003:0738:8180.0006: input,hiddev0,hidraw0: USB HID v1.11 Gamepad [Mad catz Inc. Mad Catz FightStick Alpha PS4] on usb-0000:00:14.0-3/input0
                                roodrigoc
                                My computer:
                                ZBOX CI323 nano with Retropie 4.4.2
                                https://www.zotac.com/us/product/mini_pcs/zbox-ci323-nano#spec
                                Debian 9 AMD 64
                                Kernel 4.9
                                LXDE 9
