    What way should i put psx roms onto usb to work on Raspberrypi3
    psxromsbin.ecm
    2 Posts 2 Posters 694 Views
    • epdE
      epd
      All other roms work fine, but when i put the psx rom files onto the usb nothing shows up. I downloaded cue files for all the psx games, but im not sure what the next step is..
      The file types for all the psx games i have are .bin.ecm
        dankcushions Global Moderator @epd
        @epd .ecm is not supported. see the documentation for supported formats: https://github.com/retropie/retropie-setup/wiki/Playstation-1
