USB Controller Problem (Dual Strike)
My USB Controller (Dualstrike in PS3 mode either in PC or MAME mode) does not work. It is recognized, but holding a button does not work. What do i have to setup?
I installed retropie image 4.2 on rpi3 -
@funkybunch Normally only the a/b/x/y buttons are getting detected, so if you haven't tried these
I tested again, but this time i tells the controller to start explict in PC mode (without autodetection). Now it works, but i have to find a solition for the ps3 mode to use my controller with the original ps3.
I tested my joysticks a while in PC mode and I got nearly the same problem as in recalbox. Sometimes a button or a move to any direction is recognized two times. Curiously with retropie fewer than with recalbox. I'm totally confused.
I think the big Problem is the dual strike device. I think the device is not famous enough so nobody has built a fix for it.
Does anyone got the same device and can help me?
Here is a link to the device strike-devices.net -
@funkybunch I'm getting double inputs as well sometimes... It detects (for example the up axis) it twice if you move the stick up and down... That's kinda weird
@DarkWolf Do you use the same USB controller? It's really weird. When i use a regular ps3 gamepad (which should do the same as the ps3 controller), a keyboard oder the cheap zero delay interfaces from china (nearly everybody use) there are no double inputs.
@funkybunch This happens with playstation 4 and xbox one controllers, but it is rare
@DarkWolf mhhh i have not test the ps4 controller yet. With my Arcadestick and retropie i think it is approximately every 10th step. With recalbox i got the trouble more often. (that is the reason i give retropie a try again)
